Member # 16522
Welding around threads
This is probably very n00bish but I've always had bad experiences welding threaded things (nuts, weld in bungs). Whats the proper procedure? Figure I could start my skills out from scratch
-Brian 01 4 door Taco- soon to be 3 link on tons with 40's |
anti spatter spray, and I will run a die down them if I need to when finished
[QUOTE=anvil] your very informative reply has been noted. I think this is the same type of logic you used to draw your conclusion. Place banana in your ear. Observe that there is no alligators around. Conclude bananas placed in ears keep aligators away. [/QUOTE] |
#5 (permalink) | |
Christian hater arg!
Member # 29527
Plus anti spatter to keep dingle berries off the threads. And there's no reason to get carried away. Two quick tack welds on high heat seem to do the trick just fine. |
SHOOT TO THRILL!
Member # 26382
anti-spatter/ nozzle spray, have a bolt in the threads if it is a female or a nut on the threads if it is a male, make sure ALL plating is removed from near the weld area chase the threads with a tap or die after welding to clean up.
87 4runner d44f/9"r full width, 5.38/5.43/ARBs, superior shafts, ctm's, twin stick 4-1 dana 300 behind toy t-case, allpro springs f/r, 39.5 iroks on aluminum trail ready bead locks ΜΟΛΩΝ ΛΑΒΕ I'm just a peckerwood who lives in the hills with too many guns. Last edited by 300sniper; 04-22-2007 at 07:28 PM. |
As stated above a brass bolt works wonders for holding a nut in place while welding. Also those cheap foam earplugs work great for plugging small holes while welding, grinding, and painting. If it melts while welding just run a tap through the hole.
A note: if you get weld spatter in the nut try to knock the booger out with a punch first, normally the booger will seriously tear up a tap. |
#11 (permalink) | |
I welded up 4 adjustable legs for my table and just snugged the nuts with some bolts to center the nut on the hole and had no issue with spatter.
[I]-Ryan[/I] [URL="http://4wdtoyota.com"]4WD Toyota[/URL] |
#12 (permalink) |
Doublewide engineer
Member # 6971
If you just need to protect threads in a piece you're welding, then I use earplugs. They get a lil crispy if you weld right next to em, but punch em out with a scribe and the threads will be just fine.
I'm the "tack tack tack" welding nazi. http://www.pirate4x4.com/forum/showp...&postcount=218 ![]() "I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside |
#13 (permalink) |
Member # 16522
Thanks guys. If you put the bolt in and tack weld the nuts, you wait til the nut is cooled down to remove the bolt, right?
#14 (permalink) |
Member # 64930
I usually try to keep the bolt moving during cooling. I've had beter experiences with it that way. It seems to keep the bolt from sticking. And like said before: don't tighten the bolts that will warp the threads. And if it has to look good, use a TIG.
#15 (permalink) |
Member # 3245
For good measure I usually use a bolt with copper (hi-temp) anti-
seize on it.
Never subscribe to a conspiracy theory when the stupidity theory will suffice. |
