Member # 6895
220 Plug Tech
New 220 plugs out in my garage and they appear to be 4-wire plug with the vertical lugs.
Questions - 1) What brand plugs should I use? I need three three-wire plugs, one for the mig, one for the TIG and one for the plasma. 2) What's a good source online? 3) What's the conversion between the 4-wire and 3-wire, meaning how do I need to wire a 3-wire plug to work with a 4-wire outlet? Thanks, JD
[url]www.eastofaustin.com[/url] |
Hubbel, Leviton, Pass Seymore, etc all are fine, and you can find those at Home Depot or Lowes.
Your 4 wire recepticles have 2 hots, a neutral, and a ground. The wires are only 2 hots and a ground. So disconnect the neutral wire and cap it with a wirenut then hook the gorund and 2 hots up to your new recepticle.
Jason "Willyswanter" Payne R.I.P. DOZER We'll miss you Noel ![]() Added by PBB: RIP Jason, we already miss you. www.jasonpaynememorial.com |
Why would changing the outlet become a code violation? As long as his outlet and breaker are within wire size specs then he's fine.
Member # 29037
Not if they are in his garage The four prong are normally only used in the kitchen and laundry room where the electronic in the modern machines require a neutral, but the frames need grounding to protect life.
“I will not be wronged, I will not be insulted and I will not be laid a hand on. John Wayne “The Shootist.” |
Member # 29037
More than likely your machine will only have a 3 wire hook up you could change it to a 4 wire plug if you wish just leave the neutral empty, in fact there are plugs out there that will allow you to leave the neutral prong out completely.
Member # 81644
The 3 prongs are used when the appliance uses strictly 220v. The 4 prongs are used when the 220v appliance/device uses 110v as well (like timers, displays, etc). That's why your welder has 3 prongs, and your dryer/stove has 4 prongs.
90 Toy Land Cruiser, 05 Suzuki Z400, 04 Yamaha Warrior, 03 Cannondale Speed 440. |
#11 (permalink) | |
Member # 144
). The 4th provides an extra path to ground, which is a safety thing.
That's because you're a pinko fascist. - Haole I know what antidisestablishmentarianist means |
