Synchrowave 200 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-06-2007, 08:15 AM   #1 (permalink)
Member # 14644
Synchrowave 200
Picking up a synchrowave 200 in a few weeks... anything y'all recommend with the initial purchase? I've done some TIG on steel, AL, stainlesss, TI...just bits at a time. I'm decent, but haven't done any tube work yet with it... I moved and can't MIG at my new house (Rent house) so I need a clean way to weld...plus I want to build a sick dash/console for my nissan, and motorcycle parts... ok, so recommendations??
1986.5 Nissan crawler - dual cases, one tons, 42's...
2003 SV650
1997 F350 DRW PSD
bignissan is offline   Reply With Quote
Old 06-06-2007, 09:18 AM   #2 (permalink)
FF3PM's Avatar
Member # 46229
Depending on how high you plan on turning it up you might consider a water cooled torch and cooler.
FF3PM is offline   Reply With Quote
Old 06-06-2007, 09:54 AM   #3 (permalink)
Master Apprentice
Member # 56692
if you do alot of alu work defiantly get a weldcraft watercooled torch.
1992 Explorer SAS'ed on HPD44/9" W/ 5.13 Locked F/R 36" TSL-SX on DIY Locks
sn0border88 is offline   Reply With Quote
Old 06-06-2007, 04:18 PM   #4 (permalink)
biggin's Avatar
Member # 22183
Send a message via AIM to biggin
get the hand controler with it. we just got the synchro 200 and it was the first time i used the hand controler. I thought it was alot easier than the foot control. its a great machine, enjoy
biggin is offline   Reply With Quote
Old 06-07-2007, 08:03 AM   #5 (permalink)
Member # 14644
Thanks! I thought about the hand controller...seems like it would be easier when doing out of position welds...I don't plan on cranking it up a whole lot, 1/8" steel for the most part, and probably thinner AL for dashes etc.. I can't wait though, I want to weld clean
2003 SV650
1997 F350 DRW PSD
Old 06-08-2007, 04:20 AM   #6 (permalink)
SHOOT TO THRILL!
300sniper's Avatar
Member # 26382
a bottle of argon, tungsten and filler material will get you welding. do you have the power to run it? i needed a 60a breaker for mine. anything less will trip on full power.
i think i am to the point that i want a water cooled torch. i have been messing with 3/16" and 1/4" aluminum and can see where that would be nice.
300sniper is offline   Reply With Quote
Old 06-09-2007, 08:08 PM   #7 (permalink)
pepe's Avatar
Member # 17870
X3 on the water cooled torch. I used a friends air cooled set up last year and that thing gets HOT! I was runing ~ 125 amps.
Keep in mind you will run more amps on Al. You can build your own whatr cooler as your first project. You really dont need a radiatior type, just a large enough volume of water and a pump. Here is a pic of my setup. It had a transmission cooler mounted to the back of the machine so that the air comeing from the welders fan would help cool it. I took the trans cooler off and replumbed everything. After some long welding sessions on hot days I can bairly feal the tank getting warm. And the torch never even gets warm. Soooo nice.
Arguing with a inspector is like wrestling with a pig in the mud.
After a while you realize the PIG is enjoying himself!
pepe is offline   Reply With Quote
Old 06-10-2007, 05:55 PM   #8 (permalink)
Member # 38771
1) Smaller size 9 (or so) flex head torch for getting into tight spots or out of position welding.
2) Short back cap for each torch you end up getting so you can fit into REALLY tight spots.
I agree about the water cooled torch setup too. If your going to be buying a new torch, you might as well get a water cooled one and build a cooler.
Joe
'88 GMC K5, lots of dents
'01 Chevy 2500HD D/A
"It's only sheetmetal!"
Joe_88k5 is offline   Reply With Quote
