Auto Helmet Reccomendations? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-02-2007, 07:02 PM   #1 (permalink)
Master Apprentice
Member # 56692
Im looking at a new Miller Performance Series or Hobart XTV Series auto hood.
It will be mostly used for TIG, sometimes low amp stuff so that is a must.
Anyone have experience with either or can recommend another good hood?
Im not buying any cheap HF stuff, my eyes are bad enough as it is and im only 18.
1992 Explorer SAS'ed on HPD44/9" W/ 5.13 Locked F/R 36" TSL-SX on DIY Locks
sn0border88 is offline   Reply With Quote
Old 07-02-2007, 07:04 PM   #2 (permalink)
Member # 26527
Send a message via AIM to rocksteadyrobk
speedglass
Rocksteady Racing
Buc Nasty--Shortstar TJ 3000 lbs
Dodge 3500 Tow Rig
rocksteadyrobk is offline   Reply With Quote
Old 07-02-2007, 07:23 PM   #3 (permalink)
Member # 48682
The Hornell Speeglas has a delay feature which will keep the helmet dark for a brief moment *after* the arc goes out. This keeps you from frying your eyes when doing a lot of tacks or pulsed processes. Pulsed tig really fawks with some other helmets, so if you ever do pulsed tig - I'd recommend a "high end" (9002v or x) speedglas. Another thing I like about the high-end Speedglas is the way they set up the side vents - the lens never fogs up. The side vents are non-functional on the lower end hornells. I live in GA and it gets pretty hot & humid here, so that was a factor for me. My helmet isn't a fashion statement, so I don't mind the fact that the Hornells are pretty ugly looking compared to a Miller.
Miller's elite will go to lower amperage than their performance series - check the specs if you'd prefer to stick with a Miller helmet.
I haven't tried out a Hobart helmet, so I can't comment on them.
BumpyDodge is offline   Reply With Quote
Old 07-02-2007, 07:28 PM   #4 (permalink)
Member # 1926
Might look at a Jackson Nex-gen EQC. Is has the digital setting and open delay.
'69 FJ40 with very few stock parts.
2000 Cummins with some goodies to make it smoke.....
Trail Gear's Bad Ethics=Bad Business.
fj40charles is offline   Reply With Quote
Old 07-02-2007, 07:38 PM   #5 (permalink)
Master Apprentice
Member # 56692
I dont go real low tig, 15-20 is probably about the limit. I also dont do pulsed, but alot of tacking pieces. If im doing a large number of product I may end up just tacking pieces for the better part of an hour so lifting the hood each time gets old fast.
Ill look into the other helmets, I have a fixed shade jackson now and im happy with it but an auto would defiantly be worth it.
Im not worried about fogging up, it dosent ever get real hot or humid in the shop.
Old 07-05-2007, 02:11 PM   #6 (permalink)
featherflicker's Avatar
Member # 69772
I have used both the Speedglas and the Jackson EQC (the model before the Next Gen).They are both very nice hoods.
The Speedglas is a little lighter and the ventilation is nice, but it uses expensive batteries and the cover lenses are proprietary and expensive.
My Jackson used generic cover lenses and 2 AAA batteries. If you have the large view Jackson hood now It should use the same cover lenses as that.
featherflicker is offline   Reply With Quote
Old 07-05-2007, 02:28 PM   #7 (permalink)
Member # 14848
IMO the Optrel Satellite is the best AD helmet available. It's only downfall is that its ADF's lifespan is typically only 5 years and is not serviceable. I own a Miller Elite, a 10 year old speedglass, and the 5-6 year old satellite. I bought the elite when the Satellite ADF failed, the elite is such a POS that I purchased a new ADF for the optrel.
The biggest problem I had with the elite, is it does not play well with high freq tig, plus I like the shade selection of the optrel much better. I typically do most of my welding somewhere around Din7-8. No other helmet on the market has the shade selection of the optrel.
Later,
Jason
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case
1988 Bronco,in progress
Wicked_S10 is offline   Reply With Quote
Old 07-05-2007, 02:49 PM   #8 (permalink)
Master Apprentice
Member # 56692
did it not work good with hi-freq start or cont? or both?
Old 07-05-2007, 02:54 PM   #9 (permalink)
Member # 14848
Continuous high frequency overlay. The helmet would get scrambled and shift shades light to dark, gradually. It would also occasionally switch to din3 (at rest shade) then to a 13 or so and flicker back and forth, and no, it wasn't because the sensor eyes were being blinded by something, the elite has 4 sensors, and it is virtually impossible to blind them all w/o some electrical tape.
Old 07-05-2007, 07:01 PM   #10 (permalink)
Master Apprentice
Member # 56692
odd, did you talk to miller about that? I really have my eye on the perf. series. I tried one out tuesday and liked it alot.
Old 07-06-2007, 08:13 AM   #11 (permalink)
PARANOID56's Avatar
Member # 5114
Send a message via AIM to PARANOID56
I bought the Miller Elite big window helmet. Love it. I do a lot of production welding using the pulse hi freq and have never had an issue. never been flashed or anything.
what ever you do, buy the best you can afford, as you cant replace your eyes
1971 FJ40 w/ rust Build up
2003 Toyota Taco double cab
2008 Subaru Impreza STI
1998 Honda XR650L
TLCA member #12202
PARANOID56 is offline   Reply With Quote
Old 07-06-2007, 07:30 PM   #12 (permalink)
Brad's Avatar
Member # 3239
Send a message via AIM to Brad Send a message via Yahoo to Brad
I have a Miller Elite big window for my shop and a Jackson for work. Jackson has stood up to every welding process, low amp tig and pulse as well. Ive had the hood for over 2 years and I've never had a problem with it. I keep it on 11 because Im constantly doing different process'. I cant find the exact lense I have but search for posts by me in this forum and you will find a reply with it in it.
B-RAD Fabrication
TDO DYSFUNCTIONAL ROCKCRAWLERS
Brad is offline   Reply With Quote
Old 07-06-2007, 07:41 PM   #13 (permalink)
Member # 34433
miller elite
tonka22 is offline   Reply With Quote
Old 07-06-2007, 10:34 PM   #14 (permalink)
says "yall" alot
45acp's Avatar
Member # 13671
I have the cheapo non-adjustable Speedglas and love it.
Hey kid, are you going my way?
Hop in... we'll have ourselves a field day
45acp is offline   Reply With Quote
Old 07-07-2007, 05:27 AM   #15 (permalink)
Member # 47888
I have the Speedglas 9002X and would recommend it highly. Light weight, big window and seamless transition from light to dark. Add the leather sweat band and you're good to go.
WTF-J - WTF gives you freedom. Freedom brings opportunity. Opportunity makes your future.
THachiya is offline   Reply With Quote
