Tap Drill Size Important? (29/64 vs. 27/64) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-31-2007, 06:27 PM   #1 (permalink)
Member # 48230
I was in the process of drilling holes for installing some 1/2-20 bolts, and as I was drilling out the tap size (29/64"), I realized that I probably wanted to go with a coarse thread (1/2-13), which has a tap drill size of 27/64". Will 1/32" larger make a difference when threading for a coarse bolt? I could run with 1/2-20, but 1/2-13 would be nicer (less chance of stripping in a gritty environment).
super_kev is offline   Reply With Quote
Old 07-31-2007, 06:51 PM   #2 (permalink)
Member # 30586
what kind of load and in which direction is it going to be on the bolt? If its not much then its probably fine.
rockcrawln is online now   Reply With Quote
Old 07-31-2007, 07:01 PM   #3 (permalink)
Member # 69721
Send a message via AIM to Nitrofueled14
Try each one on a test piece of scrap, couldn't hurt.
1978 F250 Custom - Fun truck
1996 Dakota - Daily driver
Nitrofueled14 is offline   Reply With Quote
Old 08-01-2007, 09:39 AM   #4 (permalink)
Member # 12499
0.030 difference in a 1/2" hole isn't gonna make much difference, but it will be easier to run the tap in.
Wrenchin' to riches!
If you want peace, prepare for war.
PTSchram is online now   Reply With Quote
Old 08-01-2007, 12:16 PM   #5 (permalink)
Member # 95408
You get more thread engagement on a fine thread. They are stronger.
there is .015 differance in thread height between 1/2-13 and 1/2-20. And the hole size will be .031 too big. So if it was me i would stay with 1/2-20.
IMHO.
Randy
1972 Blazer
olchev4x4 is offline   Reply With Quote
Old 08-02-2007, 03:31 PM   #6 (permalink)
solarpower's Avatar
Member # 47722
IMHO.
I agree.
Take into account what your using this for, if you are tapping into thinner material then you will get more threads in your material...I will try to use a fine thread when going into 3/8 and under thick steel...depending on application...
chances are that it needs to be a decent fastener if you are using 1/2 blot/threads so I would just stick with 1/2-20, if you have four or five other bolts holding it then you can probably be safe with going 1/32 oversize...
bit yes .015 per side of thread is alot actually.You will get more stuff in it if you now tap it 1/2-13
Professional Driver. Closed course.
solarpower is offline   Reply With Quote
