Rollcage Design With Inventor - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-01-2008, 05:37 PM   #1 (permalink)
k5krawler's Avatar
Member # 91043
Send a message via AIM to k5krawler
I was wondering with Inventor 08, how exactly do you start to draw up a roll cage or tube bumpers. I understand that you can do pipe runs with it, but I am not exactly sure on how to go about it. Google and the Pirate search didn't really come up with much. Any help would be appreciated.
1991' K5 blazer, 36'' Iroks, Locked Front and Rear
k5krawler is offline   Reply With Quote
Old 01-01-2008, 06:45 PM   #2 (permalink)
Member # 67907
I am no pro, but I like to use the 3-d Sketch. It uses coordinates, for me that was much easier.
To do it open a new .ipt, finish the sketch, right click and select 3-d sketch, then use the line tool to begin drawing.
THis will allow you to create a wire frame that is really easy to use with a bender, using the length tool you can figure out lengths of tubing needed.
If you want to see what it will look like tubed out create a work axis on the end of the line, then draw a circle with radius of the tubing you will be using, finish the sketch and use the sweep tool.
This took me a while to figure out, but I can do it pretty quickly now. If I know the dimensions of something I can whip out a cage in about 30 minutes.
This is something I have drawn using this method.
The Beepster
[url]http://www.pirate4x4.com/forum/showthread.php?t=727456[/url]
Jeepermat is offline   Reply With Quote
