Grinder grading of steel?
At one point and time I found, somewhere, an article about using a grinder to determine the grade of steel you have but I can not seem to find it searching either here or google. Anybody have a good link to one? I have a bunch of pins and I want to get an idea of what they are made of so I can decide if they will be strong enough for something stupid.
Be yourself, by yourself. |
#2 (permalink) | |
Addicted to Gear Oil
Member # 56050
Google "steel spark test"
http://shopswarf.orcon.net.nz/spark.html http://en.wikipedia.org/wiki/Spark_testing_metals
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016 |
Member # 47722
Having another piece of steel that you "know about" helps to compare the spark types.
I only say this cause I have ground ALOT of types of steel, and those pictures and terms that were linked on those pages are easy for me to understand, but if I was a newb it would all seem very similar. The differences are actually quite subtle. I would tell a less experienced person to compare steel pins and their strength by putting them in a chop saw with abrasive wheel and cutting them all the way through. You won't have to look at sparks to get a fairly accurate idea of it's strength quickly. Again, compare it to something you "know" about.
Professional Driver. Closed course. |
Member # 46229
You should use a clean or virgin grinding wheel. Any residual metal from other uses might spark off and give an erroneous spark pattern.
I agree it takes some practice to be able to correctly identify steel using s spark test. |
