Building A Belt Sander? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-10-2008, 03:54 AM   #1 (permalink)
Member # 26216
Send a message via Yahoo to Gummi Bear
I really want one of these:
{See Attatchment, hotlink didn't work}
But it's a little spendy. There are less expensive ones available, I can get one at Northern Tool for $55, but it's not built nearly as well, and the motor is inferior. It'd probably work, but truth be told, I really don't want to add another bench grinder to my collection (somehow I have 4 of the damn things )
Is there a kit, or have one of y'all built one like this before? I've found a couple of setups on knife builders forums, but they still aren't made as well as the Kalamazoo, or have a bunch of wacky bracketry hanging off of them all over the place.
Any thoughts or ideas?
I consider myself a student of the game, it's just too bad I'm in special ed...
Gummi Bear is offline   Reply With Quote
Old 02-10-2008, 10:05 AM   #2 (permalink)
I make websites!
Member # 12429
You can get an attachment like that that has been discussed here before for $117 on ebay then pickup a quality bench grinder on amazon for $105 or $170 depending if youwant 5.5amp or 7.7amp.
My 4x4 Blog
Rockwell axles too!
Todd W is offline   Reply With Quote
Old 02-10-2008, 11:02 AM   #3 (permalink)
Member # 26216
I found the Blue Point one for ~$115 on Ebay, is that pretty much all there is anywhere?
I've got a couple of good 1/2HP American made grinders that are just sitting on a shelf, and not being used. I thought this may be a good use for one of them.
Old 02-10-2008, 05:30 PM   #4 (permalink)
Member # 5368
Send a message via AIM to ABN82MP
$60 if you dont mind Harbor Freight...
ABN82MP is offline   Reply With Quote
Old 02-10-2008, 05:43 PM   #5 (permalink)
Member # 26216
I did see that...
Any idea how they hold up?
Think I could replace the outer drum, and use it for an abrasive notcher?
Old 02-10-2008, 05:47 PM   #6 (permalink)
I make websites!
Member # 12429
Originally Posted by Gummi Bear View Post
I did see that...
No, not strong enough.
You will need 1.5hp + to do abrasive notching.
1.5hp is pretty good, I bet that one you posted is only 1/3hp.
My 4x4 Blog
Rockwell axles too!
Old 02-10-2008, 09:35 PM   #7 (permalink)
Member # 26216
If a 1-1/2 HP is needed, then no, this definitely won't cut the mustard.
http://www.harborfreight.com/cpi/cta...emnumber=93981
Looks like it's a 1/2 HP.
Old 02-10-2008, 10:18 PM   #8 (permalink)
Member # 9655
http://www.beaumontmetalworks.com/
check them out on youtube. many different attachments too.
ive got a PDF drafting drawings to build this machine. then u can use any size motor you want.
email me @ chevota23 at yahoo.ca, or if someone can show me how to attach a pdf so others can download off me???
i didnt break it, i was just testing its durability
gumbom is offline   Reply With Quote
Old 02-10-2008, 10:23 PM   #9 (permalink)
Member # 9655
search for "KMG belt grinder Demo part 1" on youtube
Old 02-11-2008, 09:09 AM   #10 (permalink)
Member # 14848
If you have time, you could do something like I did, see the thread here clicky. It started life as a cheap 4x36 belt sander, it now has a 3hp motor, extended platen to accept a 4x54 belt, and a grooved rubber contact wheel that eats tubing. The thread has a lot of sources for rubber wheels that may work so you wouldn't necessarily have to make one like I did.
As for the sander when it was bone stock, I did notch tubing with it. It absolutely requires alumina zirconia belts (the blue ones) and it was slow going before the rubber contact wheel. Much better now, but for less than $100 with a 3/4hp motor, it didn't do too badly before.
Later,
Jason
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case
1988 Bronco,in progress
Wicked_S10 is offline   Reply With Quote
Old 02-12-2008, 05:26 PM   #11 (permalink)
Member # 9655
heres a link to the pdf download on bc4x4
http://bb.bc4x4.com/showthread.php?t=124305
Old 02-12-2008, 05:44 PM   #12 (permalink)
Member # 14887
I've been thinking of using a serpentine belt tensioner to keep the sanding belt tight.
What do you guys think of about it?
Carey
ScoutIITD is offline   Reply With Quote
Old 02-12-2008, 06:43 PM   #13 (permalink)
Knee Grow
jstarnes's Avatar
Member # 12575
Location: It puts the lotion on its skin OR it gets the hose
it might work ok, but the bitchen sander above looks like it uses a contoured wheel????
She said her name was Bambi, I said thats a coincidence darlin cause I was just thinkin about skining you like a deer then wearing your face like a mask as I do my little kooky dance
jstarnes is offline   Reply With Quote
