How to heat water for radiant floor heat? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-10-2008, 03:23 PM   #1 (permalink)
Member # 28084
A friend is building a shop and is considering using radiant heat. After seeing the "What I'd do different thread" I am trying to convince him it is a good idea. At the very least he should put the tubing in the slab.
But his question was "How do I heat the water?".
I now have the same question. What are the most efficient, least expensive initially, most green, and most creative ways to heat the water? How much $$$ do you have in your setup?
He was originally planning to use a wood stove for heat. I guess a wood fired boiler wood be an option.
What about a used oil fired boiler?
Geothermal?
Radiant solar?
Electric water heater powered by hamsters in a wheel?
Lets hear your ideas/experiences.
Orion
'72 K20 on 35s
K2Orion is offline   Reply With Quote
Old 02-10-2008, 04:08 PM   #2 (permalink)
Member # 67907
One at work is a gas powered boiler unit. One at my house is also a gas powered boiler.
The Beepster
[url]http://www.pirate4x4.com/forum/showthread.php?t=727456[/url]
Jeepermat is offline   Reply With Quote
Old 02-10-2008, 04:36 PM   #3 (permalink)
Knee Grow
jstarnes's Avatar
Member # 12575
Location: It puts the lotion on its skin OR it gets the hose
ground source and a takagi
or radiant roof collectors and a takagi
She said her name was Bambi, I said thats a coincidence darlin cause I was just thinkin about skining you like a deer then wearing your face like a mask as I do my little kooky dance
jstarnes is offline   Reply With Quote
Old 02-10-2008, 04:53 PM   #4 (permalink)
Member # 105044
You can use any of the tankless water heaters or you could use a regular hot water tank for the floor and for the sink or water ever. Using a heater for both uses would be the most universal and easiest to install
It's my reality, i'll do what I want to!
stssts is offline   Reply With Quote
Old 02-10-2008, 06:17 PM   #5 (permalink)
Member # 72829
I've seen the boiler method used also, but the one I saw was wood fueled. It headed both the house and the shop.
1974 Scout II "Yellow Jacket"
1981 Ford Mustang "La Poitrine" SCCA Solo C Prepared
gustav129 is offline   Reply With Quote
Old 02-10-2008, 07:11 PM   #6 (permalink)
CJ
Member # 71
I am going to run a boiler for the floor and a plate and frame heat exchanger for the domestic.
I still do not know what brand of boiler I am going to run yet.
I know someone with a Munchkin that has had zero problems except a board that went bad because a mouse got in the panel and nested in there then pissed all over the board.
I know someone with a Baxi that likes it.
I may go with the Larrs mini therm because I can get it from work.
So I will be watching this thread since I have not made my mind up yet. There are too many choices.
Matt
81 CJ7
CJ is offline   Reply With Quote
Old 02-10-2008, 07:17 PM   #7 (permalink)
Member # 19695
Send a message via AIM to bighair Send a message via MSN to bighair
it really depends on your area.. Some areas natural gas is cheap, others propane is cheap and others using electric is cheap.. I'm in Canada and our power is fairly cheap, so I went electric. I have a tankless water heater I was going to use, but apparently the pump I was using didn't have a strong enough(it was free) flow rate to activate the heater so I put a 50 gallon tank heater for this winter as it was Dec when I finished it. and didn't want my pipes to freeze from the cold. this summer I'll get a 3speed pump for 80$ and try it.
You only need moderate heat for the system to work so a tank heater works fine just not as efficient. the ideal setup would be solar or even thermo where it's a natural heat but at that point $$ comes into play. I got to admit, the heat is nice might of added 40$ to my powerbill a month, and that's running my tools an the heater for the garage.. no too bad I'd think.
93 YJ 4.0L
XJ rears leafs
Waggy fronts
HPD60 front
D60 rear
Custom 231/D300 doubler
cable shifted twin stick
37" Pitbull rockers
work in progress
bighair is offline   Reply With Quote
Old 02-11-2008, 12:54 AM   #8 (permalink)
Member # 99830
last house I worked on ran a gas boiler. worked really well.
romoranger is offline   Reply With Quote
Old 02-11-2008, 07:43 AM   #9 (permalink)
Member # 107373
How big is the shop and how well insulated.
Use a natural gas fire hot water heater.
1wook is offline   Reply With Quote
Old 02-11-2008, 10:48 AM   #10 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
I've been thinking about adding roof collectors to my system. I figure that I can likely keep the workshop above freezing with just the roof collectors during the day - if not substantially higher - and then supplement that with an instant hot water system for when I'm actually out there. Things will stay above freezing for a couple days down into the teens just from the solar gain from the windows.
Geothermal could be an option, but the install cost is usually pretty high if you need wells - unless you have enough land and a backhoe to do a coil system yourself.
GET INVOLVED - Join the Blue Ribbon Coalition
SIGN THE PETITION - SAVETHEHAMMERS - #85
'93 Chevrolet 6.5TD K2500 NV4500 Std. Cab Longbed 170K
'85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild)
PAToyota is offline   Reply With Quote
Old 02-11-2008, 11:41 AM   #11 (permalink)
Member # 42546
I'm useing 2 60 gallon water heater (way it was set up not my idea) basicly too seperate systems in one building its a 40 by 80 pole barn with 16' celings and insolated good like 19 walls and 30 celing . It heats great with around 100 deg inlet temp water and is always 68 to 70 deg inside and is cheap to heat free gas. We set it up with gas so if we ever lose the free gas we could convert it over to propain pretty easly.
big specht is offline   Reply With Quote
