So I bought a CNC mill for the home shop - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-13-2008, 08:09 PM   #26 (permalink)
Realsquash's Avatar
Member # 2578
I just got in from the shop and have some progress to post! We had a few good weekend days without rain so I had to get take care of some other things and didn't make much progress on the mill... until this weekend.
I was able to fire it up tonight without the PC and with just the X axis powered up and it worked as expected. I can't force the motor to move more than a couple of encoder counts.
I ended up with about 75vdc for the servos, close to the 80 volt max rating on the Gecko drives.
I had to build an e-stop and servo power switch box. I will be using it for other indicators and switches in the future. I reused the contactor that ran the servo power with the old hardware. The electrical box is a $7.95 A/C disconnect with everything inside removed. The Allen Bradley switches came from Ebay.
Here's a shot inside the control cabinet. Lots of extra space in there. You can see various power supplies on top. 5 and 75vdc, a stepdown transformer for 120vac to run the PC and fans. Below that shelf is the breakout board and the geckos. I have a smoothstepper paid for and should be shipping this week, so that will give me more I/O for the limit and home switches among other things. It's not nearly as messy as it looks here. All I have to tie down is the encoder and limit switch cables.
Andy
Realsquash is offline   Reply With Quote Quick reply to this message
Old 04-19-2008, 07:22 AM   #27 (permalink)
Realsquash's Avatar
Member # 2578
It runs!!!! I have to wire up the VFD and the limit switches today, but I got Mach3 all configured and the PC installed and it runs! Hooray!
Andy
Old 04-19-2008, 07:59 AM   #28 (permalink)
fj40guy's Avatar
Member # 9576
Andy
Fantastic.... get out there and start making chips.....
Hmmm, with CNC it is probably out there making chips while you surf Pirate!
Beautiful young people are accidents of nature, But beautiful old people are works of art. Learn from the mistakes of others. You can't live long enough to make them all yourself.
fj40guy is offline   Reply With Quote Quick reply to this message
Old 04-19-2008, 09:01 PM   #29 (permalink)
Realsquash's Avatar
Member # 2578
I need to stock up on useful things like a vise, hold downs, cutting tools, and some more measuring tools before it can make parts for me... but it runs! The first real parts I want to make are some Mog 406 wheel/brake adaptors to run chevy 8-lug stuff. And a new knocker for my back door!
Andy
Old 04-19-2008, 09:17 PM   #30 (permalink)
Member # 14848
Looking good man! Glad to see one of us is making progress!
Did you bother taking the time to draw a new wiring diagram, or are you just "winging it"? If you drew anything up, I would be interested in seeing your limit and e-stop circuits. I started drawing a diagram for mine in Acad, on the assumption that eventually something is going to go tits up, and I am never going to remember how I wired it, so it will hopefully help. In reality, the drawing is mostly done in it's first generation, however it takes up 35x17 inches of Acad virtual space, and is fairly difficult to track anything down in as well! I am going to take some time soon to seperate it into modules so it is printable and makes more sense!
Anyhow, looks great, gotta post some video when you get chips flying.
Later,
Jason
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case
1988 Bronco,in progress
Wicked_S10 is offline   Reply With Quote Quick reply to this message
Old 04-19-2008, 09:34 PM   #31 (permalink)
Realsquash's Avatar
Member # 2578
I have all the wiring diagrams scratched onto graph paper I did have a plan when I started, and my cabinets worked out really well so things came together pretty well.
The estop isn't 100% done. I want to wire it up to Mach knows when it's been hit and I need to wire it into the VFD, but right now I just use it to power the servo and encoder power supplies. The green momentary runs a latching relay for one side of the A/C and the estop is on the other side. It's simple and it's how the original was done, too.
Andy
Old 04-19-2008, 09:59 PM   #32 (permalink)
Member # 14848
I am on the other end then, I have everything in place so e-stop shuts down the VFD, All BOB IO, drivers, and signals Mach as well through one of the PP inputs. It sounds like you are already short on inputs though, due to the servo encoders, so my scheme wouldn't help you anyhow.
The thing I am having trouble wrapping my little brain around is how to set up the VFD to trigger an e-stop on a fault. Seems easy on the face of things, as most VFD's have a relay or two which can be programed to signal a fault condition, but my hang up, is mine signals a fault when it is not running. If I put the fault relay in the e-stop circuit, until mach starts the spindle, the drive will be in fault condition, and until the e-stop is satisfied, mach won't come out of e-stop. There are ways around it, but nothing I really like, it involves someway of bypassing the VFD relay to take it out of e-stop, and then rembering to switch it back in when the machine is up, or using a seperate input for it, of which I only have one left...
Have you thought about spindle shut down with the axis drives still running? I don't really see anyone even mentioning it remotely in their builds/retrofits, but it seems to me it should be incorperated. Especially on a machine the size of which we are working on. You could easily serriously damage something if the spindle shut down and the axis' were still running and doing heavy cutting at the time... I think probably a lot more than just a broken EM.
Later,
Jason
Old 04-20-2008, 06:36 AM   #33 (permalink)
Realsquash's Avatar
Member # 2578
My goal with the e-stop is to make the spindle and the table stop moving. Since I am using servos, a runaway table is much "easier" than it would be for steppers. Killing my servo power supply takes care of that. As for stopping the spindle, I want the VFD to know when the estop has been hit so it stops. It has some dynamic braking built into it, but the spindle motor currently has a magnetic brake on it that I am trying to decipher. I think I might be able to run it on DC, or maybe I can find a replacement that isn't 3-phase. In any case running the estop to the VFD's estop signal should be fine for me. I don't plan on putting anything else on the estop. In this case, when the estop is hit the ways will stop instantly and the spindle will take a smidgen longer to spin down, so the part maybe be hosed but the endmill should survive.
As for I/O, I have one of the first Smoothstepper boards, so I have I/O galore The drivers I have take the encoder signals, they don't run straight to the PC.
Andy
Old 04-27-2008, 09:19 PM   #34 (permalink)
Realsquash's Avatar
Member # 2578
Well I ran the first program on it today! I got the VFD wired up and working nicely with Mach as well. I made that roadrunner they send out with Mach about 50 times, doing various tuning. I got it running around at 180ipm with pretty good acceleration. I do have some kind of electrical noise on the Z axis limit switch once in a while so I need to figure that out. It might not be noise, it could just be the old contacts being weird. It only happened once. Here's what's left:
1) install the Smoothstepper
2) wire up a real err/res circuit so mach knows about gecko faults
3) mount the PC somehow. There is enough room on the cabinet but it will get really dirty sitting there.
4) buy tooling!!!!
Andy
Old 06-19-2008, 08:26 PM   #35 (permalink)
Realsquash's Avatar
Member # 2578
I thought I'd update ya'll on the mill project:
I've been using the Smoothstepper for a while now. I've run the mill for 1/2 days at a time cutting roadrunners out of the air for various testing reasons. I'm very happy with the Smoothstepper.
I am not so happy with my Geckos, however. They seem to like to fault for no reason. They also seem to like to stay faulted for no reason, too. I have a brand new one that is now stuck in a fault state and I cannot get it to react to save my life. So now I have one that takes two reset pulses to start up, one that will not start up at all, and one that faults for no reason but will reset fine. The 4th one (yes I bought another one to mess with) is on the Z axis and likes to make X and Y fault when connected to the power supply. Disconnect it and the problem goes away. Some kind of electrical noise I'm sure.
I'm going to place an order for Granite Devices VSD-A drivers tomorrow. I considered these drives when I started out but I thought Gecko was the gold standard. The GD's have much more functionality and seem like more robust parts. I don't need to hassle with a seperate encoder power supply with them, they will use my differential encoders, they will run a higher voltage, they have PID tuning software that runs over USB (no scope needed for PID tuning), etc. They just look great. They are 2x the cost of the G320, however, and they are going to cost 10x as much to ship. And I have to rewire all the drivers. Dammit!
Andy
Old 06-19-2008, 10:46 PM   #36 (permalink)
Member # 12429
Andy
Wow, $355 a piece + shipping hope they are worth that... let me know
Edit: WOW, talk about a HUGE DISCOUNT for Hobbey..
" 3-5 168 EUR " That's insane!
Todd W is offline   Reply With Quote Quick reply to this message
Old 06-19-2008, 10:59 PM   #37 (permalink)
Realsquash's Avatar
Member # 2578
Yup, if it were not a hobby boy it would be expensive! I saved a lot of money on the machine purchase so it doesn't hurt quite so bad. Hopefully they work out better for me. The hardest part will probably be negotiating with Gecko, but I've heard they are good on the customer service end of things.
Andy
Old 06-20-2008, 07:04 AM   #38 (permalink)
Mechanos's Avatar
Member # 6704
...And a new knocker for my back door!
Andy
Please do NOT post pics of this.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote Quick reply to this message
Old 06-20-2008, 08:03 AM   #39 (permalink)
Member # 1889
Hey, if you didn't throw out the old axis drive motors or other control stuff, I might be interested in them... I've got one that still runs on what looks like the stuff you took off.
Scott@Rockstomper is offline   Reply With Quote Quick reply to this message
Old 06-20-2008, 09:04 AM   #40 (permalink)
Realsquash's Avatar
Member # 2578
Haha you might be suprised.
It's still collecting dust in the shop. A few people have asked about it but I haven't been motivated enough to try and figure out what I could sell it for.
Andy
Old 03-15-2009, 02:29 PM   #41 (permalink)
Member # 95134
I just bought a wells index 810
Well this is odd. I just bought a Wells Index 810 that is missing electronics. I intended to replace the electronics and drives so i thought i would do a little research. I never would have thought another member would have already done exactly the same thing. I am going to start on this in 3 weeks. Any tips for me? What is this hobbey place where discounts can be had? Can i have a pictures of every square inch of what you have wired up. It would really be a huge help not to have to research and just install and wire and parts.
Singleunderheadcam is offline   Reply With Quote Quick reply to this message
Old 03-16-2009, 08:52 AM   #42 (permalink)
Realsquash's Avatar
Member # 2578
Hah! I learned a lot, too much to probably put into this post, but:
- The 810 uses DC servos with optical encoders. The screws are something like 5 TPI iirc (I can doublecheck that). The spindle motor and servo power supply were both 3-phase, but everything else ran single phase 110. I am running a VFD for the spindle (3HP) that is controlled by Mach. I reused a step-down transformer to get 110vac and that runs my breakout board (Campbell designs combo board), Smoothstepper, way oil pump, and probably a few other things I'm forgetting. The servo power supply uses some huge toroid transformer I got on the interweb, about 76 vdc and lotsa amps. The servo supply and VFD are both using single phase 240vac.
- I started with Gecko 320 servo drives and they had a lot of problems faulting on startup. Once they were up they ran great, no issues there, but if I messed up and faulted one they would not reset. It got bad enough I couldn't even use the machine, so I swapped them out for Granite Devices VSD-A drivers. Night and day difference! Zero problems, software tuning, etc. The G320 faulting was a "common" issue and Gecko didn't know what was doing it. Well they finally figured out why, you need to run a 47k resistor between the negative motor output and incoming power ground. Needless to say the G320s are on the shelf. Granite Devices has built a new drive, the VSD-E and I would HIGHLY recommend taking a look. They also give hobbyist pricing. Knowing how nice these are now, I never would have bought the G320.
- The VSD-A drives use differential encoders, the G320s do not. The encoders on the 810 are actually differential but inside the housing only 1/2 the leads are connected, so they worked with the G320 only. I popped the covers open and sure enough the PCB inside had everything it needed for differential operation. I just ran wires from the screw terminals on the housing to the right locations on the PCB, just like the factory would have. the labels on the housing are even there for differential operation. I had to use the 'scope on them to be sure which was which, I can dig up my notes about the wiring if you need to make this change.
- I have been using a SmoothStepper since the first run was produced, and it's a huge improvement over the parallel port for Mach. Mach with the PP would just crawl. With the SS it is smooth and the PC doesn't seem to even be busy now.
Ahhh what else am I forgetting... Basically I cleaned out the whole electronics cabinet and replaced it all. Any questions?
I've got more pix, I'll try to find them. I can always take more
Andy
Old 03-16-2009, 09:23 AM   #43 (permalink)
MC
Nose to grindstone
MC's Avatar
Member # 21997
Send a message via Yahoo to MC
Can you run those drives with the amount of power those servos need to puish the cutter? Isnt that the reason the oem axis amp cards were so big?
MFGS of the STAR-LAB CNC machines
The finest CNC plasma tables
Made in the USA by Bulltear and can be found online at
and at local welding stores
Hypertherm and Thermal Dynamics
We also make parts for AMC
MC is offline   Reply With Quote Quick reply to this message
Old 03-16-2009, 10:33 AM   #44 (permalink)
Member # 49108
Hey, How much were the Granite Devices VSD-A drivers? Did you order direct from Finland? How long did it take to get them? How much for the breakout board? Thanks, Dave
suprdave737 is offline   Reply With Quote Quick reply to this message
Old 03-16-2009, 11:32 AM   #45 (permalink)
Realsquash's Avatar
Member # 2578
Well that depends what you're trying to do. The G320's are 80vdc/20a. The VSD-A is 150vdc/15a. The motors on my 810 are rated at 120vdc/24a (verified), but they were only being driven at 48vdc (again this is coming from memory). Amps=torque, volts=speed. My mill cranks along pretty well and certainly works fine for what I do with it. I am able to do 100 ipm rapids with conservative accelleration and haven't had problems cutting anything. But I also haven't tried to max it out yet (shop rebuild all winter).
The reason the OEM drivers were so large was because they were 1970s technology. They had a lot of discrete components and it was all through-hole stuff and that just takes board space. In this photo you can see the 3 driver boards down below with a fat power supply capacitor:
Andy
Last edited by Realsquash; 03-16-2009 at 11:33 AM. Reason: verified 120vdc/24a motors
Old 03-16-2009, 11:41 AM   #46 (permalink)
Realsquash's Avatar
Member # 2578
I paid $549 Euro at the time for 3 VSD-A, the USB adapter for programming, and UPS shipping. I had them in under 2 weeks, but that was due to UPS. That's about 175 euro per drive, 50 euro for shipping. That's just over $700usd right now...
I bought a pricey bob but I don't remember the cost. It was a couple bills for sure. It has a nice PIC-based VFD controller and all the I/O for 4 axis, relays to control coolant and lube, and charge pump for e-stop with Mach. It also has a power supply on it so you don't need to worry about that, you just run 120 or 240 to it and you're done.
Andy
Old 03-16-2009, 04:57 PM   #47 (permalink)
Member # 52710
Did you end up using the Campbell break out board? Or did you use the granite devices break out board...
Slowly building:
jpmassey is offline   Reply With Quote Quick reply to this message
Old 03-16-2009, 07:38 PM   #48 (permalink)
Realsquash's Avatar
Member # 2578
Using a Campbell Combo bob. Granite didn't have theirs going when I bought my drives.
Andy
Old 03-17-2009, 04:32 PM   #49 (permalink)
Member # 95134
Misc
Now that you switched to the granite devices are you able to upgrade to a larger power supply?
Is the granite devices BOB in your opinion better than Campbells?
how do you shop for a VSD? are there specs that you need to match on the motor?
do you remember the size of your stepdown transformer or the amps for the power supply?
Old 03-17-2009, 07:46 PM   #50 (permalink)
Member # 9988
1500VA for all three servos?
How much current are you pulling at the start of a rapid from dead stop?
[Insert Sig Here]
Goat is offline   Reply With Quote Quick reply to this message
