If I had a mill, and wanted to cut an 80 degree V notch how would I do it? If It was a 90 degree notch, I could just tilt the head 45 degrees and use an end mill, but I need a notch that is less than 90... Do I do the same with but with a 60 degee cutter and just tilt the head 10 degrees one way and then 10 the other?
Because the bottom of the cutter would be cutting at 90', not 80'. Best case with your setup would be to use a tiny cutter and cut a relief at the peak of the groove.
A formed cutter with an 80' angle would likely be the easiest but not necessarily the least expensive. Think shell mill.
Our tool room at work is privileged to have a very skilled cutter grinder hand so custom profiled tools are usually no problem for me..but..
If he's off and I needed to make a cut like your describing I would take a end-mill to the pedestal grinder and clear the flutes at an included angle less than the 80* your trying to attain....make a cut with the bottom of the E-mill then flip the part ...cut again to your desired angle.
Don't know if this would work for you, but you could cut a grove with an endmill straight down along the length of your part. Then using a smaller end mill tilt the head 40* and cut one side. The bottom of the endmill would be in the grove and clear of the opposite side. Turn part around and cut the opposite side. You'd have to do some figuring to figure out what cutters and depths you need, but it'd give you an 80* slot.
I think this is the answer. Cut a small slot right in the middle of the V, then tilt the head. It wont give me an 80 degree sharp pointed V, but it will let me get a 80 degree V with a 1/4" or so flat spot in the middle.
Aren't production drill/mills 90 included? Seems like w a steady hand you could grind 'em back to a semblance of 80. But yeah, depends upon just how deep/wide you need this v-groove to be and if you can buy a drill/mill large enough.
It takes a pretty skilled person to free-hand sharpen the bottom of an Emill... and have it do anything other than rub :laughing:
Also the max flat you could achieve would be half of the cutter dia. on one side of your "V".... it would look more like a check mark than a "V".
I thought about this thread at work today, I had to make a 70* included "V" in a bar of alu.... roughed as much out as I could with a standard 3/4" rougher and used a fly cutter to finish.
Like mentioned above, I am trying to replicate a lower V die for a press brake. I cant seem to find any of the 4 way ones online to buy...
Although, the lower part of the die doesnt really need to be a V, It could just be a rectangular notch out of a piece of steel. the only thing that matters is the width at the top and the depth needs to be great enough to get to 90. The V's make it easier to get 4 different widths on a single block of steel though.
At work we've gotten decent results doing v slots using carbide spot drills and they come in various angles. Of course we really don't do that any more because it's slow and sucks ass. Now we just order any tools we need.
Edit: Oh and it also doesn't give you a sharp V it more of a flat bottom
