I finally have my mill installed and need advice on Post software. This is for personal use so initial cost and maintenance costs take away from wheeling dollars.
The mill is a '98 Milltronics with a Centurion control. Full 3 axis with a coversational control. It also has the RS 232 port to connect to my laptop to download and run programs. It does not have any way to import geometry at this time.
I have ProE, Unigraphics, and I-Deas 3-D modeling software. I can output most standard file types to be read into a Post program.
I've been contacted by PTC and Siemens (owns UG and Ideas) about their codes. I've also seen Bobcam and Mastercam. Anyone have experience with any of these or any others? What should I watch out for?
i use sheetcam for 2.5d and it works pretty good for me. i only wish i could set the step over smaller than 10%. you can down load the trial version for free but you are limited on how long the program can be. the price of the licence was in pounds and i can't remember exactly what the dollar amount was but i think it was only around $120.
i made this using sheetcam. it missed one small step over on the entire part that ran non stop for probably 3 hours. there is also a screen shot of the cutter path in sheetcam. this was cut using an 1/8" ball mill.
I used to have a milltronics in my shop. The thing was not the best in the world either. Anyway, BobCad worked on it. But with the static ram in the machine being so low you had to keep the laptop hooked up to the machine on large programs. BobCad is not the best program either, but it will get the job done.
The conversational program that came with it doesn't do 3 axis???
Will the RS232 allow you to DNC from a PC??? If it can it's then a matter of figuring out what kind of code it reads. Being a 98 milltronics it should easy enough to find a decent post-processor.
Are you looking for complex surface type programming like for making 3-D molds type stuff or more for sketch some geometry and then machine it, with some steps in the Z axis in different places.
The higher end software does a very efficient job at "highly detailed complex everything" relating to taking a model from many file types to creating a language that just about any machine can read. But it's also expensive and still require quite a bit of time to even get started if your a noob.
Did you get a manual that would tell you what type of code it will read?? I'm guessing it would be like a yasnac or fanuc or some other "language" that the control should be able to interpret. You can usually find a post-processor for just about any CAM software that will convert it to the machine. It's just a matter of finding out the machine language and you might have to manually "tweak" a program to get it to work once it's been posted.
If you have UG / ProE, both have manufacturing. ProE is slightly better than a calculator. UG is one of the best. You need a manufacturing software license to make it work. It has 2 posting products built in, GPM and UGpost. Your control will have to be able to use Gcode to make use of either.
Now that said if you own UG you should have known this....
UG = Siemens, Siemens bought UG 6-9 months ago. The actual product for cadcam is NX, current version is 5, I prefer V4. I'm not sure on the price, I bought mine several years ago. I have a mfg bundle license, I paid a little under 20K. Maintenance is pricey also, around 5K a year for my package.
I have a friend that uses Pro/mfg, it is worse than bad by his account. It is a very good modeler however.
For the maintenance you'll get the best support in the industry. UG isn't supported by a local reseller, they have a tech support group. The tech's are grouped by the portion of the product in use, mfg group, modeling group etc.
As for the Milltronics post, show me a sample of the code.
