32" deep, 13'6" long, 3/16" steel top with backsplash, 1/8" steel shelf, 4 outlets, FREAKING HEAVY.
$150 :bounce2:
Oh, and he has the large metal parts bin cabinets (with the cases that pull out and open up) full of bolts, nuts, washers, studs, all sorts of stuff. I'm getting them for $50 each.
Nice find on both.:smokin: It is like winning the lottery when you find a buy like that. A week or two ago I picked this table up for $50 (7'X3', 1" thick top) :flipoff2:
Well, I decided I didn't like the leg/lower shelf setup...
So, I have 8 sticks of 2" square tubing waiting,
12 of these stainless steel hinges:
6 of these latches:
10 of these feet:
I'm going looking for some aluminum sheet and 1" square tubing when I get time, to build the doors.
I'm building a 2" tube framework, including 10 legs. The table will be turned into cabinets underneath with 4 sections (6 doors for 3 sections, one flat sheet screwed on for the section the pressure tank and such is under), with a shelf near the ground, and one between that and the table.
I'll start a build thread when I get going in a week or two.
A friend of mine works at the steel mill. $0.07/lb on anything I want!
