Ferrule crimper for air hose? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-05-2008, 07:50 PM   #1 (permalink)
hoohaa's Avatar
Member # 55546
I'm sick of using hose clamps on the ends of my air hose. I have not found a good quality clamp yet that will really hold up when I crank down on it with a nut driver.
I want to find a crimper that will let me crimp down those brass ferrules on the end of hose over a barbed end fitting. I've seen them at the welding supply for welding gas hose but those were too small for 3/8" hose.
I'm thinking some sort of ratcheting crimper like what you use for coax cable but stouter would be good. Heck, I could even build one if I knew what sort of pattern I would need. A crimper made out of bolt cutters would be sweet.
What are you using?
hoohaa is offline   Reply With Quote Quick reply to this message
Old 08-05-2008, 08:12 PM   #2 (permalink)
Member # 34702
the one my propane guys uses to make up hoses is like a split die he uses in a vice to crimp the ends on, i'd imagine its similar for an air hose.
EMG7895 is offline   Reply With Quote Quick reply to this message
Old 08-06-2008, 12:26 AM   #3 (permalink)
Wyoming9's Avatar
Member # 113418
Smile
look around or ask the counter people at your welding supply.
I bought a hose repair kit a long time ago it had the fittings to do 3/8th air hose. They should still be around. inert gas hose is the same size I have bands and a crimper for them also that would work.
Have you ever used fuel injection clamps. i think the larger size would fit 3/8th air hose.
Wyoming9 is offline   Reply With Quote Quick reply to this message
Old 08-06-2008, 05:54 AM   #4 (permalink)
Dabbler
actionpaintball's Avatar
Member # 29562
Send a message via AIM to actionpaintball
http://airhosereels.com/hoserepairkit.html
shop around...you find it cheaper (same or similar)-I just found that one quickly to link
A make-it-yourself AC line crimper may also work:
http://www.autoacsystems.com/_store/...hose.html#6350
actionpaintball is offline   Reply With Quote Quick reply to this message
Old 08-06-2008, 09:25 AM   #5 (permalink)
hoohaa's Avatar
Member # 55546
I saw this crimper here: http://www.righttool.com/
Looks like it would be pretty easy to make, and since I haven't seen any under $150 yet it would probably be worth my time to make a set.
Old 08-06-2008, 10:01 AM   #6 (permalink)
hoohaa's Avatar
Member # 55546
Looks like this kit would work and it's $65. http://www.weldingmart.com/Qstore/p000854.htm
Old 08-06-2008, 12:36 PM   #7 (permalink)
Member # 14086
Not as nice as the brass sleeves, but usable, are double ear hose clamps. You can get them, as well as a crimp tool, at Home Depot.
Stephenw is offline   Reply With Quote Quick reply to this message
Old 08-06-2008, 12:49 PM   #8 (permalink)
Member # 104850
Never Mind
[B][COLOR="Yellow"]1987 YJ 60/14 on 40" ltb's [/COLOR][/B] :flipoff2:
SIKJEEP is offline   Reply With Quote Quick reply to this message
Old 08-06-2008, 01:18 PM   #9 (permalink)
hoohaa's Avatar
Member # 55546
Are these in the tool section at home depot or what? I was just there and didn't see these.
Old 08-06-2008, 02:00 PM   #10 (permalink)
Member # 1926
Something like this might work.
http://cgi.ebay.com/AIR-HOSE-CRIMPER...em130238747090
'69 FJ40 with very few stock parts.
2000 Cummins with some goodies to make it smoke.....
Trail Gear's Bad Ethics=Bad Business.
fj40charles is offline   Reply With Quote Quick reply to this message
Old 08-06-2008, 02:24 PM   #11 (permalink)
BiggE's Avatar
Member # 70215
Back when I used to manage a Napa store, we had a crimping kit that we used to fix hoses in the store, and would loan it out to shops to use. I believe it was made by Napa Tire Hardware. It came with the crimping tool, and an assortment of Brass ferrels, and fittings. Sorry I can not remember the part #, but I hope this helps.
BiggE is offline   Reply With Quote Quick reply to this message
Old 08-06-2008, 02:25 PM   #12 (permalink)
Member # 14086
They are in little baggies with the plumbing fittings (bottom row I think). The section where all the brass fittings are. I've never bought them there (I buy from Marshall's Industrial Hardware), but I noticed them while buying other fittings. It looked like they had a full range of sizes. I think I saw the crimper hanging on the wall with the plumbing tools. I have CV joint band crimpers that I use.
Old 08-06-2008, 02:28 PM   #13 (permalink)
Member # 14086
The crimpers...
Old 08-06-2008, 02:47 PM   #14 (permalink)
Member # 14086
Looks like they are called Oetiker clamps.
Here is the technical data sheet...
http://www.oetiker.com/uploads/docum...901098_278.pdf
Old 08-06-2008, 03:30 PM   #15 (permalink)
Member # 21000
Send a message via AIM to CPOM
Originally Posted by actionpaintball View Post
these guys are fucking assholes, just FYI
did not send a few dollars worth of parts and did not answer or return phone calls
[COLOR="DarkSlateGray"]Chris
92 Isuzu Pup, 3800>r150f>dual toy cases
toy 8", isuzu 12bolt, not done yet[/COLOR]
CPOM is offline   Reply With Quote Quick reply to this message
Old 08-06-2008, 03:54 PM   #16 (permalink)
supervert's Avatar
Member # 63840
home depet and lowes have somthing like this that might work http://www.pexsupply.com/categories....D=560&brandid=
supervert is offline   Reply With Quote Quick reply to this message
Old 08-06-2008, 04:00 PM   #17 (permalink)
Member # 30944
Send a message via AIM to CJHeap
The crimpers...
I use those when making up CO2 systems for kegerators. Never had one fail.
You can also use a set of bull nose cutters to crimp them if your careful.
They are a bioch to remove. You can use the bull nose cutters to cut off the crimp though.
[B]Hammers Post 1461[/B]
[B]Tellico Post 160[/B]
[B][SIZE="4"][COLOR="Magenta"] Nikita Khrushchev said[/COLOR][/SIZE][/B][COLOR="DarkRed"][SIZE="4"]"We can't expect the American People to jump from Capitalism to Communism, but we can assist their elected leaders in giving them small doses of Socialism, until they awaken one day to find that they have Communism. "[/SIZE][/COLOR]
CJHeap is offline   Reply With Quote Quick reply to this message
Old 08-06-2008, 04:48 PM   #18 (permalink)
Member # 79052
Originally Posted by fj40charles View Post
We have one of these at work for fixing air hoses. Works slick!
iboc44 is offline   Reply With Quote Quick reply to this message
Old 08-06-2008, 09:05 PM   #19 (permalink)
Member # 1926
Are they still in business? Do they have a phone # where you can talk to a person?
Old 08-06-2008, 10:02 PM   #20 (permalink)
hoohaa's Avatar
Member # 55546
The crimpers...
Sweet. Thanks for the help. This is what I was hoping was out there.
Old 08-07-2008, 12:20 AM   #21 (permalink)
F.I.B.
JeepButcher's Avatar
Member # 57167
I work as a machinist for Greenlee tools and we make ferrule crimpers but all our tools are made for electrical use. Not sure if anything we make wouldn't screw up the nipple.
JeepButcher is offline   Reply With Quote Quick reply to this message
Old 08-07-2008, 08:04 AM   #22 (permalink)
hoohaa's Avatar
Member # 55546
If you send me some samples I'll be glad to check!
Old 08-07-2008, 08:13 AM   #23 (permalink)
Member # 9835
They sell that same tool at McMasterCarr as well as lots of different sized sleeves or ferrules. Around here there is a place that sells imported tools, minibikes, gocarts and stuff that sells a knockoff of that crimper for around 30 bucks. I have tried it against the crimper from McMaster and it works just as well. I have used that type of crimper to repair many dozens of air hoses. It is quick, easy, very durable, and makes a professional looking hose end.
ChiScouter is offline   Reply With Quote Quick reply to this message
Old 08-07-2008, 08:22 PM   #24 (permalink)
hoohaa's Avatar
Member # 55546
If you know of a place to get a knockoff of that tool that works as well as the high dollar type for $30 please share. I'm going to grab a set of Oetiker clamps and crimpers next time I'm at home depot but I'd rather have the type you linked to.
Old 08-08-2008, 07:19 PM   #25 (permalink)
hoohaa's Avatar
Member # 55546
What size oetiker clamps or brass ferrules are you guys using for 3/8" ID rubber hose?
