Best way to remove mill scale? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-04-2008, 01:13 AM   #1 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
Now that I've got my Torchmate plasma table up and running I've obviously been going through a lot of flat plate. I've also been practicing a lot with the TIG, and to get good welds you have to take that black coating off of the plate first. I've always loved my 36 grit sanding disks for shaping and smoothing parts, and they work great to remove the scale when they are new, but they quickly get polished smooth and stop working. My wire wheel doesn't do any better. What are you guys using to get your steel clean?
Dallas Ashley
Your Source for: CNC Cutting & Engraving, Cages, Custom Suspension, Complete Vehicle Builds, and more!
Co-Dog #4432-KOH 2011 #88-KOH 2010, Crew Chief - KOH 2009, 2008
StinkBug is offline   Reply With Quote Quick reply to this message
Old 12-04-2008, 05:12 AM   #2 (permalink)
Jimbo*'s Avatar
Member # 36486
I have a friend who makes water tanks for livestock, and uses one of two methods: he either sandblasts the plate, or drags them around the lower part of his yard, which is blowsand, cleans the rust and scale off quickly.
Senators and Representative should be made to wear Nascar style jackets--so that it is crystal clear who OWNS them
Jimbo* is offline   Reply With Quote Quick reply to this message
Old 12-04-2008, 05:35 AM   #3 (permalink)
darkstar's Avatar
Member # 13047
a roloc sandpaper disc on a die grinder works great, but I wouldn't want to do a big piece of plate with it, that's for sure.
if you find yourself needing to do this on a large scale, woulnd't it be easier just to buy cold rolled?
Surplus industrial supplies for sale. Lots of good stuff for your rig, cheap: fasteners, automotive electrical supplies, etc:
darkstar is offline   Reply With Quote Quick reply to this message
Old 12-04-2008, 05:57 AM   #4 (permalink)
Member # 14528
Use different steel. When I have an important project (mine ) I order P&O steel. I think it stands for pickled and oiled and it looks clean and bare. There is no millscale. Thats what I use on my Plasmacam adn the place that cuts some stuff for me with a laser uses it too. Ask your supplier about the steel used for water, laser, plasma cutting.
Bruce T is offline   Reply With Quote Quick reply to this message
Old 12-04-2008, 06:00 AM   #5 (permalink)
Member # 9994
go to Home Depot and get a gallon of Behr concrete and rust remover. its in a black jug with white and purple label. essentially, its phosphoric acid with some detergent.
edit: i just looked at the Behr website and don't see it. i'll get the product # off the jug i have tonight and post it up...they may have changed packaging.
i mix it 1 part Acid to 2 parts water in a 5 gallon bucket. soak the parts for 30 minutes and it will take off all the mill scale and slag. you might have to lightly rub over them with a scotchbrite or rag to get it completely off.
next, dunk into a bucket of water mixed with baking soda to neutralize the acid and rinse them off.
wipe them dry.
i usually hit the parts with a light coat of WD-40 and wipe with a rag to keep them from flash rusting. the WD-40 is so light it doesn't really affect welding.
you are essentially Pickleing and Oiling the parts...
Matt
1984 CJ-8
1986 CJ-7
1981/1992 CJYJ
1994 RAM 1500 4x4
Custom Fabrication Parts:
jeepnmatt is online now   Reply With Quote Quick reply to this message
Old 12-04-2008, 10:15 AM   #6 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
So far it sounds like my options are either buy different steel, or do what I'm already doing, cause all of those solutions would take even longer.
The down side of getting different steel is that my local, super friendly, cheap supplier is very limited on what they actually stock. I'd probably have to order from a place like Industrial Metal Supply, which is a hell of a lot more expensive, and about 30 miles farther away.
EDIT. Damn, just called all the suppliers I know of locally and apparently 3/16 cold rolled is just about impossible to find without a special order. Sucks too, cause I like workin with CR a lot more anyways.
Dallas Ashley
Old 12-04-2008, 01:12 PM   #7 (permalink)
Member # 9994
this the the Behr stuff:
http://www.behr.com/behrx/act/view/p...ioners&catId=3
its in a new package.
this takes about 20-30 minutes of soaking, but if you leave the parts in longer they still come out fine.
Matt
1984 CJ-8
1986 CJ-7
1981/1992 CJYJ
1994 RAM 1500 4x4
Old 12-04-2008, 01:42 PM   #8 (permalink)
willymutt's Avatar
Member # 4927
Send a message via AIM to willymutt Send a message via MSN to willymutt Send a message via Yahoo to willymutt
I've just used a Dotco with a sanding disk. The good disks will last quite awhile.
2009 RWE Buggy - Lots of broken parts
willymutt is offline   Reply With Quote Quick reply to this message
Old 12-04-2008, 08:31 PM   #9 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
WTF is a Dotco? I just googled it and came up with about 50 different tools. Everything from Buffers, to die grinders, to drills.
Dallas Ashley
Old 12-04-2008, 09:56 PM   #10 (permalink)
Member # 43124
I've always used just a regular grinding wheel/disc for mill scale and a 36 grit pad for everything else. Just ease over it with the grinding disc and if it has too much base metal reduction or grind marks take the 36 grit pad and smooth it out grinding in the same direction until all the marks are gone.
99 Frontier in pieces, 406 mogs, doubler, atlas 4 speed, 40s with other random parts. Build thread------->
frontier2k1 is offline   Reply With Quote Quick reply to this message
Old 12-06-2008, 12:03 AM   #11 (permalink)
Member # 103945
What I've recently found to work great are the 3M Clean & Strip wheels, they're kinda spendy but they work great. If you need to remove a really large area it might get a bit tedious, but they do work fairly quick.
I don't think that I could go back to anything else now for just cleaning around weld joints. I just use a right angle air die grinder, just make sure to spin the wheel off the material, not into it. Otherwise it'll shoot big chunks of the wheel off and they hurt. You can get them as a normal wheel or as a roloc style wheel. I haven't tried the roloc, but I'd like to.
I really recommend at least trying one of these. You can pick them up at any hardware store or even walmart. Here's a link to what I'm talking about.
http://www.amazon.com/gp/product/B000BQURDI
Good Luck,
Jordan
jschulze is offline   Reply With Quote Quick reply to this message
Old 12-06-2008, 09:03 AM   #12 (permalink)
Member # 9679
This is what one of the guys at the station used when they made a new griddle out of 1/2" plate. Basically soak it in vinegar.
http://www.armourarchive.org/essays/...and_rust.shtml
77fixer is offline   Reply With Quote Quick reply to this message
Old 12-06-2008, 09:27 AM   #13 (permalink)
Member # 62686
A torch works pretty damn well...
FrkyMnky1487 is offline   Reply With Quote Quick reply to this message
Old 12-06-2008, 12:13 PM   #14 (permalink)
Member # 54522
just get some sheet metal, that shouldnt have the hot rolled black finish. that black junk is a B&tch to get off even on square tube it takes forever with a 36 grit flap disc. hitting it with a flap disc will probaly leave a a unflat surface also.
86 4runner 7MGE bobed, exo, SAS on 38s, 5.29, fully locked with duals/4.7 and 30spl longs
dopeassjackson is offline   Reply With Quote Quick reply to this message
Old 12-06-2008, 01:42 PM   #15 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
I'm not sure what your definition of "sheet metal" is, but I've always known it as that thin stuff your cars body is made out of that crumples up if you lean on it to hard. Not the stuff you'd use for mounting your suspension. I've already searched a number of local suppliers for cold rolled plate, or P&O, and none of them stock 3/16 or 1/8" plate. I could have them special order it, but I'd need to buy about 5X the amount I need, which would cost me an extra $1k or so. Not exactly pocket change.
Dallas Ashley
Old 12-06-2008, 02:04 PM   #16 (permalink)
Member # 123597
i use 120 grit flap disks
Loose07 is offline   Reply With Quote Quick reply to this message
Old 12-06-2008, 04:28 PM   #17 (permalink)
Member # 67907
Cabinet sand blaster
The Beepster
Jeepermat is offline   Reply With Quote Quick reply to this message
Old 12-06-2008, 04:49 PM   #18 (permalink)
Member # 54522
o 1/8th i was thinking you where useing some thinner metal. you might check an online steel place for small ammounts.
Old 12-06-2008, 05:45 PM   #19 (permalink)
Member # 111714
sandblast it, or use a torch. I don't have any experience with any of the chemicals these guys are talking about, but it sounds like something worth trying. sanding disks wear down pretty fast on mil-scale, that shit is hard!
Tyler C is offline   Reply With Quote Quick reply to this message
Old 12-06-2008, 08:04 PM   #20 (permalink)
darkstar's Avatar
Member # 13047
I've never tried this, but a zirconia-alumina belt on a 6" hand-held belt sander should make pretty fast work of cleaning a full-size sheet...
Old 12-06-2008, 09:30 PM   #21 (permalink)
Member # 52710
Muratic acid. You can get it from Home Depot.
Slowly building:
jpmassey is offline   Reply With Quote Quick reply to this message
Old 12-06-2008, 11:52 PM   #22 (permalink)
AZUndertaker
azhayseed's Avatar
Member # 89449
I use those 80 grit quick change sanding discs for my angle die grinder, they seem to work much better than the flap discs but you will need a good supply they seem to wear out pretty quick. these may be what others are refering to as rolock I'm not sure
John Brock
Rocking J Offroad Race Team #777
We want to thank our sponsors for their continued support
Rocking J Offroad, LLC.
Crossedup Customs
Ruffstuff Specialties
JRat Offroad/ Sixty9 Axle
Yukon Axle and Gear
azhayseed is offline   Reply With Quote Quick reply to this message
Old 12-07-2008, 08:51 AM   #23 (permalink)
Member # 9994
do NOT use Muriatic Acid, it causes hydrogen embrittlement on the surface of the material.
Use Phosphoric Acid.
also, there is a difference between "Sheet" steel and "Plate" steel. sheet is primarly measured in "gauge" and plate in decimal or fractional inches.
7ga sheet is nearly the same as 3/16" plate
11ga sheet is about 1/8"
i don't know the thicker guages off the top of my head...
i think plate is a little cheaper than sheet because plate is typically hot rolled and sheet is cold rolled.
give the phosphoric acid a try...its easy and quick unlike standing at a blasting cabinet or running a grinder over the sheet.
1984 CJ-8
1986 CJ-7
1981/1992 CJYJ
1994 RAM 1500 4x4
Old 12-07-2008, 11:22 AM   #24 (permalink)
willymutt's Avatar
Member # 4927
Dotco is what we call an angle sander with Roloc disks on it. The 3M ones are better than the cheaper ones but they are the only two brands I've used.
Old 12-07-2008, 12:50 PM   #25 (permalink)
Member # 52710
Maybe if you leave it in there for a long time....
Phosphoric acid also cause hydrogen embrittlement, its just a weaker acid.
Slowly building:
