putting my air compressor outside??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-07-2009, 08:41 AM   #1 (permalink)
X-Rated's Avatar
Member # 72707
I got a 60 gallon 220v air compressor and need to find a place to put it. I dont really want it in the garage b/c wall space is limited and I dont want it to be loud. I might have to do that in the end, but I am looking for other options.
I have extra siding and shingles so I could do a 4x4 lean to on the back of the garage but I am not sure how to go about it.
I was thinking a 4x4 4" slab, cut the siding at the roof line of the lean to and bolt on a header boad to mount the rafters to. Do I need to cut the siding for the walls as well or can I count something over the siding?
Thanks for the help and ideas
X-Rated is offline   Reply With Quote Quick reply to this message
Old 03-07-2009, 09:31 AM   #2 (permalink)
Member # 37168
I plan on building a shed attached to the house, and was told city building code requires 5/8 sheetrock on the inside shed wall (existing outside wall of the house/garage attached to). They said to just apply the sheetrock over the siding.
Supposed to be a fire break. Made sense to me.
Rowdie is offline   Reply With Quote Quick reply to this message
Old 03-07-2009, 03:08 PM   #3 (permalink)
Member # 107373
Do You have room to put it in the atic?
800, 302, c4, D20, jack stands
1wook is offline   Reply With Quote Quick reply to this message
Old 03-07-2009, 03:40 PM   #4 (permalink)
Member # 54522
what do you need a pad for? i think you could get away with a good oak pallet on some paving stones with plywood going from the side of the pallet and leaned in for a roof/sides. i guess it depends on how you want it to look.
86 4runner 7MGE bobed, exo, SAS on 38s, 5.29, fully locked with duals/4.7 and 30spl longs
dopeassjackson is offline   Reply With Quote Quick reply to this message
Old 03-07-2009, 08:47 PM   #5 (permalink)
Member # 103610
Send a message via AIM to jeep937
I've been wanting to make a "Compressor House" for a while now. I think the pad would cut down on moisture.
jeep937 is offline   Reply With Quote Quick reply to this message
Old 03-07-2009, 10:22 PM   #6 (permalink)
Member # 347
Most of the moisture is in the air already, if you've got it well-ventilated to keep it cool and permit air intake, you're not gonna keep the air dry.
If there's moisture in the ground, it's gonna wick up through the slab unless you use a moisture barrier.
Randii
randii is offline   Reply With Quote Quick reply to this message
Old 03-08-2009, 07:41 AM   #7 (permalink)
Member # 63058
I have a friend whose 35 gallon direct drive compressor was so loud that we couldn't talk while it was running, so I built him a 2 x 6 lean-to on the side of his shop. I used 2 x 6's for the foundation setting on stones with 3/4 inch plywood for the flooring. I built 2 doors to go on the long side. That way he could not only put the compressor in the shed, but also some of the yard tools that were in our way. He lives out of the city limits, so no worries about codes.
Maude - An '87 YJ with a few mods here and there.
Maude is offline   Reply With Quote Quick reply to this message
Old 03-08-2009, 07:13 PM   #8 (permalink)
Member # 76809
Wether you build a pad or just set it on some blocks or even a bed of gravel the most important thing is to make sure that it wont vibrate and "walk" around. The compressor also needs to sit pretty close to level to ensure it will oil correctly.
OKMudn is offline   Reply With Quote Quick reply to this message
Old 03-08-2009, 07:54 PM   #9 (permalink)
Member # 54844
many of my old jobs had them outside. one was just on a 3x3 pad and had a slant steel roof and plywood sides that left aound 12" open near the top
mine was outside in a small enclosure untill it died - and the new one wouldnt fit there
[SIZE="4"][COLOR="Red"]BSW[/COLOR] Racing, Super mod & [/SIZE] [SIZE="4"][COLOR="Navy"] Bitten [/COLOR]Off Road, Pro mod[/SIZE]
BSW Driver: Aaron Whitehead - Bitten Driver: Mike Stokes
BSW Spotter: Adam Kovarik - Bitten Spotter: Dan Kovarik - AKA -
: me fuckers :flipoff2:
build up of the truggy
f250rollinon37s is offline   Reply With Quote Quick reply to this message
Old 03-09-2009, 03:47 PM   #10 (permalink)
nate379's Avatar
Member # 20099
My Dad has his compressor in the 2nd floor of his shop (barn style building) and it's nice that you can't hear it.
The only problem he's had is the upstairs isn't heated so when it's cold it will usually slip the belt. You have to go up there when it first fires up to make sure it's spinning.
nate379 is offline   Reply With Quote Quick reply to this message
Old 03-09-2009, 05:57 PM   #11 (permalink)
X-Rated's Avatar
Member # 72707
i put the floor in and storage upstairs already, and I could probably get it up there, but it is fairly heavy and I am not sure I would want something that dense putting that much weight all of the time in on spot. I know I weigh as much as the compressor and I walk arround up there so maybe that is not really a good reason not to. Draining the tank would be a pain in the ass
If I did a lean to, would want to use the left over siding and roofing I have to make it match. Question is how to get the siding to "meet" on the sides correctly.
Old 03-09-2009, 08:50 PM   #12 (permalink)
Member # 104229
Inside/outside?
Coming from an x aircompressor service tech. "Outside is fine as long as you maintain your machine" If you deal with a cold season you need to run thinner oil, say 20wt. Then in summer run the 30wt. Then toss in the fact you don't get to hear that little "tickeyknockie" of a valve going bad, not to mention the daily tank drain. All boils down to paying closer attention to the unit when you don't get to see it every day. We used to say "out of sight out of mind" That said, I'd put mine in a lean2 if I needed the space,but I'd rember it's one of my favorite tools and maintain it properly.
PROFABBY
PROFABBY is offline   Reply With Quote Quick reply to this message
Old 03-10-2009, 10:38 AM   #13 (permalink)
nate379's Avatar
Member # 20099
Just put an auto drainer on it. My Dad runs thin oil in it, but when it's -40* it's still not enough.
