Member # 24876
Anyone done structural pan deck??
I'm looking for a way to fasten structural pan deck to steel trusses..
I know these guys make it, this is what i'm looking for http://www.us.hilti.com/holus/module...ANGE_OID=36606 But NOT hilti
[COLOR="Lime"]'85 Toyota ext cab. 4 cyl. 5.29s. Chromoly birfs. dual cases. hi-steer. OBA. front ARB. rear welded. cage.[/COLOR] |
We always spec for them to weld it.
GET INVOLVED - Join the Blue Ribbon Coalition SIGN THE PETITION - SAVETHEHAMMERS - #85 '93 Chevrolet 6.5TD K2500 NV4500 Std. Cab Longbed 170K '85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild) |
Member # 113019
If your talking about corrugated decking in which a concret floor will be poured on it, you need to get a thing called a button punch (they look like a big set of bolt cutters with a dimple instead of cutting blades) and join the different sheets together. When those are buttoned together you use an arc welder and spot weld the decking to the beams/trusses from the top (burn through the decking). Welding the deck is tricky at first cause the decking is so much thinner than the beams/trusses. I dont have any pictures, sorry.
BTW: This shit is miserable work when it's 120 degrees in the dead heat of summer in Phoenix!
"Big Blue" 1977 F-150 ,"Goldie" 1999 F-350 |
Member # 24876
Found a company named Pneutek, It's a pneumatically driven pin. Similar to a powder actuated gun but with pneumatics no license is needed..
We'll see how it turns out
