QC tool post for an Atlas 10" - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-16-2009, 08:48 AM   #1 (permalink)
Member # 48682
I'm considering upgrading to a quick change tool post for my old Atlas 10" lathe. Here's what I'm trying to figure out:
Aloris ($$$!) vs. generic knockoff (are Phase II's any good?)
Wedge vs. Piston style
AXA size vs BXA size.
Any advice or comments from experience w/above is greatly appreciated.
BumpyDodge is offline   Reply With Quote Quick reply to this message
Old 07-16-2009, 09:19 AM   #2 (permalink)
Member # 116245
I bought my QCTP from tools4cheap.net - it's a great way to run a lathe. I like mine, would do it again. It's an import set.
I'm about 98% happy with it. I got the wedge style - supposedly they offer more accurate repeatability than the piston style. Seems like everyone over at PracticalMachinist shuns the piston style.
The only part I'm not happy with are the screws that hold down the cutting tools. The screws are soft metal, and when you hunker down on them to get things really tight, the allen heads can waller out. A couple of the included allen head screws are now worthless, but there are enough of them included with the kit so that I can just replace them with the 'extras'. But in the long run, I'll need to replace the allen head screws.
You'll need to cut/notch the baseplate to fit your lathe, it's not a big deal if you have a mill, but it can be done with a saw, grinder, etc given enough patience and ingenuity.
Mine's a BXA on a 13" South Bend.
cabletech is offline   Reply With Quote Quick reply to this message
Old 07-16-2009, 09:23 AM   #3 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
I would keep an eye out for a good used setup. Check craiglist often for machinist tools listings. In my experience the CL ads with the least info, that are the most vauge, have the best stuff
I recently picked up my first QC tool post setup from an ad just like that. "Macheenist tools fer sale" no other info.. I called and he said he had a bunch of old machinst stuff, "drill bits... and other stuff".
I walked out of there with an Aloris wedge CA (14-20") QC setup and 8 tool holders for $150. These normally sell for over $800 from what I've seen. I also walked out with 2 large buckets full of hundreds of tool bits and carbide inserts, a small milling vise, 2 huge cast iron squares and a bunch of 50 taper tooling.
If I was buying new, I dont think I could pony up the cash for Aloris. Phase II seems to be good stuff from what I've read. Another thing to remember is that the tool holders come up for sale fairly often.. so you dont have to buy a complete set all at once.
Azzy2000 is online now   Reply With Quote Quick reply to this message
Old 07-16-2009, 09:28 AM   #4 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
Good point. I forgot to mention that I had to mill the Aloris base quite a bit to fit the compound on my old Reed Prentice 16" lathe.
Old 07-16-2009, 10:14 AM   #5 (permalink)
Member # 13395
Good advice. I bought an Induma mill with Mitu DRO this way. The ad said "milling drill press".
1994 FZJ80 with Mitsubishi 4D3 power
1980 Land-Rover crew cab with 6BT power
HandBuilt is offline   Reply With Quote Quick reply to this message
Old 07-16-2009, 01:33 PM   #6 (permalink)
billybob_81067's Avatar
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
Phase II seems to be good stuff.
AXA would be the size suitable for that lathe. I've got a Phase II AXA on my 9x20 Jet lathe, and I have another one bought for my Atlas 10" as well... Haven't put it on yet though. Put a CXA on our 16" South Bend Lathe.
billybob_81067 is offline   Reply With Quote Quick reply to this message
Old 07-16-2009, 09:19 PM   #7 (permalink)
Realsquash's Avatar
Member # 2578
I've got a Phase II QCTP on my 13" South Bend, a wedge style, and it's really nice. As far as chicom tools go Phase II are actuallly pretty good. If you have a mill it's also pretty easy to make your own toolholders. For what it is and what it's going to be used on the Aloris is way overpriced.
Andy
Realsquash is offline   Reply With Quote Quick reply to this message
Old 07-16-2009, 10:49 PM   #8 (permalink)
Member # 48682
Thanks for all the help. Phase II wedge "AXA" size it is. Now to find a good deal on one!
Old 07-16-2009, 11:43 PM   #9 (permalink)
Member # 52387
Hell I went with the piston style myself... don't see any reason to pay more for a wedge style. I can tell you that when you tighten down that piston style that toolpost isn't going to budge a damn bit. And as for perfect repeatablility... hell I'm not running a production shop... I'm just happy that I don't have to set my bit on center every time anymore!
Old 07-17-2009, 04:58 AM   #10 (permalink)
Member # 105383
+1
I have the Phase II AXA size piston type on my Logan 10"
I will add that even perfect repeatability of the toolpost wouldn't matter on a 50 year old lathe....
i.e. your going to have to fiddle with everything anyway as your need for accuracy increases on certain jobs.
RLC Welding and Fabrication
Louisville, KY
(502)403-6832
Winch bumpers for 73-98 Full size Chevy, 87-97 Ford F-series, Bronco, Ford Explorer and Rangers, Jeep xj and zj, Nissan xterra, and MORE!
jamscal is offline   Reply With Quote Quick reply to this message
