brake line flares - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-19-2009, 08:22 AM   #1 (permalink)
Member # 764
brake line flares
I did quite a bit of searching last night and did not get a definitive answer. Is there a difference between a metric inverted flare (double flare) and a standard double flare.
I plumbed my cruiser brake lines along time ago using premade pieces from the auto parts store but used standard fittings with adapters. I bought a cheapo flare tool and successfully did a buddys jeep so while I have the cruiser apart Id like to fix up the brake lines to be the correct length and eliminate the adapters and I hope to buy some pre-made metric lines, cut to length and re-flare the one side and the hope is that metric and standard double flares are the same.
thanks.
arndog
1966 FJ40
arndog is offline   Reply With Quote Quick reply to this message
Old 08-19-2009, 08:38 AM   #2 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
Yes, they are different. The metric flare is called an ISO "bubble" flare and is formed differently than your standard 45 degree double flare.
Google ISO bubble flare for more info. Flaring kits are available to do the bubble flare. Stay away from the el cheapo kits though, the only thing they will produce is frustration.
Azzy2000 is offline   Reply With Quote Quick reply to this message
Old 08-19-2009, 08:54 AM   #3 (permalink)
mudtoy67's Avatar
Member # 30359
When I did mine I just bought metric lines and then re-flared the ends that needed standard fittings. They were just a hair loose on the metric line, but I never had any problems with leaks.
BDR
67 FJ40 "Last Minute" -
97 XJ
Texan. Saved my neck twice... once after he was dead.
mudtoy67 is offline   Reply With Quote Quick reply to this message
Old 08-19-2009, 09:05 AM   #4 (permalink)
Member # 77768
Not sure what's considered a "cheapo" kit, but I have an OTC bubble flare kit that seems to work well. It was <$25 at Summit Racing.
Tom Rowe
Four wheel drive allows you to get stuck
in places even more inaccessible.
62 88 reg
67 NADA x2
74 Air Portable - The Antichrist (tag 6A666)
95 D1
95 D90
Antichrist is offline   Reply With Quote Quick reply to this message
Old 08-21-2009, 09:50 AM   #5 (permalink)
Grocery Getter
ErikB's Avatar
Member # 59
Just because its metric doesn't mean its bubble.
Toyota uses a standard inverted double flare on 3/16" line. The tube fittings are the only difference- 10mm threads vs. 3/8".
So yes, the tool you used for your buddy's jeep will also work for your cruiser.
Old 08-21-2009, 11:28 AM   #6 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Yup, just 'cause it's a metric brake fitting does not make it a bubble flare. 45* is 45* is 45* if it's double flare, you can use the same tool. Your SAE sized clamping bar might not grip the tube quite as well, but IIRC most Toyota lines are the same or very close to 3/16" lines.
guidolyons is online now   Reply With Quote Quick reply to this message
Old 08-21-2009, 05:13 PM   #7 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
I mis-read his original question. Thought he was asking the difference between metric bubble and SAE double flares.
You can take your and shove it up your ass.
Old 08-24-2009, 03:32 PM   #8 (permalink)
Member # 764
ErikB right on the money, thanks guys
arndog
1966 FJ40
