Dial-Style in-lb. torque Wrench - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-11-2009, 07:41 AM   #1 (permalink)
71PA_Highboy's Avatar
Member # 73465
All,
I am rebuilding a pair of 60's and need a torque wrench for setting the R&P. Since I am learning how to set the R&P with this unit any pointer about good/bad would be nice to know.
Any suggestions for vendows with reasonably priced units?
I have seen them around this price point, but have no experience buying one of these wrenches.
http://www.flexibleassembly.com/Prod...nches/1502LDIN
http://www.toolsource.com/dial-torqu...-p-105072.html
http://www.thetoolwarehouse.net/p-46...-d2f150hm.aspx
Yes, I searched, but the majority of applicable posts are from 2005/6, and while the wrench technology hasn't changed significantly, many of the mfr's have.
Your input is appreciated.
Got Ford?
68 &69 Bronco, 69 & 70 Mustang, 94 Ranger, 71 F250 4x4, 2 94 Lincoln Mark VIII - BF RI
This country is trying to childproof the world when they should be worldproofing their children.
71PA_Highboy is offline   Reply With Quote Quick reply to this message
Old 09-11-2009, 08:11 AM   #2 (permalink)
Member # 45530
http://www.toolsource.com/beamtype-t...b-p-71321.html
I use this at home, it's work for a cheap-o, but I sure do miss my snap-on dial style wrench at my old shop. If you are going to be doing more than a few a year, I'd spend the extra coin on one of the ones you listed. If you are only going to be doing a few a year, the beam style wrench will work
Panthers65 is offline   Reply With Quote Quick reply to this message
Old 09-11-2009, 08:22 AM   #3 (permalink)
Member # 66858
You should borrow a good one, unless you are going to be doing a lot of this work.
Member
Deep Woods Extreme 4X4 Club Of Southern NH.
LASER is offline   Reply With Quote Quick reply to this message
Old 09-11-2009, 08:29 AM   #4 (permalink)
Member # 73465
I would borrow one, but I only know of 2 people who have them locally and they are both pros... I will borrow a friends tools, but never the ones they use to make their living.
Rural living does have some drawbacks.
Laser, do you have on I could borrow?
Thanks!
Got Ford?
Old 09-11-2009, 09:00 AM   #5 (permalink)
Member # 17042
For the money, this was a good buy for me. I'll only do a few a year so I didn't need a $200 torque wrench.
http://www1.mscdirect.com/CGI/NNSRIT...36984&PMT4NO=0
It's an Armstrong deflecting beam with a small range and small increments. For $65 it works great. The only thing is that it is a 1/4" drive so I have to run an adapter to an adapter to get my pinion nut socket to fit.
[QUOTE=Myanarchy;9475039]maybe if more kids got involved in projects we'd have less kids living in projects:flipoff2:[/QUOTE]
76scoutman is offline   Reply With Quote Quick reply to this message
Old 09-11-2009, 09:18 AM   #6 (permalink)
Member # 118363
I also used a beam style. They are cheaper and I was able to pick one up at the local bike shop for $50. Like scoutman said you will need multiple adapters. It should definitely get you close enough for pinion bearing preload IMHO.
xj42 is offline   Reply With Quote Quick reply to this message
Old 09-11-2009, 09:36 AM   #7 (permalink)
Member # 62545
That's the one I've got and it has worked great on a few axles. I do agree though, if I was doing more than mine and a couple buddies' axles I'd want the one that is more coin.
[COLOR="Sienna"][SIZE="1"]-Bill
NAXJA NAC President , '97 Jeep XJ, D60s, 39.5s, Coilovers, etc[/SIZE][/COLOR]
RCman is offline   Reply With Quote Quick reply to this message
Old 09-11-2009, 11:16 AM   #8 (permalink)
Member # 3374
http://www.performancebike.com/bikes...=torque+wrench
kbud is offline   Reply With Quote Quick reply to this message
Old 09-11-2009, 09:01 PM   #9 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Get one of the Park Tools beam style ones (listed above) ~$40 or if you really want a dial style, check pawn shops. I got a Mac tools dial indicator in/lb torque wrench at a pawn shop for $60 when I did my R&P swap
guidolyons is offline   Reply With Quote Quick reply to this message
