M14X1.25 Compression tester lead ?
Where can i buy just this ? i need 6 of them..
cant seem to track down a site i can buy replacement parts for a tester...
It's not yours unless YOU built it ! 89 s10 4.3 700R4 Dana 300 Dana 44 5.13s locked on 38's |
#2 (permalink) | |
Addicted to Gear Oil
Member # 56050
What brand? Got pics? You can make some from old sparkplugs and air hose quick disconnect fittings if that's the style your compression tester takes.
Maybe Mac tools, Snap on, etc?
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016Last edited by guidolyons; 11-04-2009 at 04:09 AM. |
Member # 48682
Sounds like a crazy project! Compression tester fittings aren't going to work because they are not designed for high flow. It's basically just a little schrader valve. No way you could push a cylinder's full displacement of air through that little valve at operating speed.
Any plumbing supply should have brass check valves - they might flow enough, but are not designed for continuous operation. Maybe use the check valve from an older Ford EGR system? They'd certainly flow enough, not sure about the pressure though. You'd want something like a reed valve for your application. |
i read it on another thread here.. sounded like a stupid idea but in theory it would work oh so awesome.. So i gotta try it out hahah .. its a junk 4.3 so what the hell right ? only thing i have to buy is Check valves.. And i couldnt find anything online except the compression tester leads..
Member # 24876
Why not plumb all the lines together and at the "collector" install a check valve, like a regular compressor. 6 check valves can't be terribly cheap.
[COLOR="Lime"]'85 Toyota ext cab. 4 cyl. 5.29s. Chromoly birfs. dual cases. hi-steer. OBA. front ARB. rear welded. cage.[/COLOR] |
Member # 121833
Because you then have to compress all that plumbing up to the collector and you will not be able to reach a good PSI. Check valves should be as close as you can get to the cylinder.
Mostest Hardcorest Web Wheeler '84 F250 in progress- D60F D70R 12v Cummins NV4500 4sp Atlas |
Member # 24876
Have you thought about how much power its going to take to turn this thing?
#12 (permalink) | |
like i said im not taking this thing seriously i just have most of the stuff and wana try it just to say i did.. if it works then thats awesome one check valve wont work.. the piston compressing will just be pushing air into the cylinder that's on intake.. it'll just run and do nothing..
It's not yours unless YOU built it ! 89 s10 4.3 700R4 Dana 300 Dana 44 5.13s locked on 38's Last edited by Mud Slayer 2.0; 11-07-2009 at 01:06 PM. |
#14 (permalink) |
Member # 130003
Took awhile to get ahold of my buddy that has one of these.
He used air compressor check valves (whoda thunk??). Grainger has 1/2" npt and 3/4" npt. 1/2" are $15.45 each (Grainger part # 4X828) "control devices" model # IC50 3/4" are $23.07 each (Grainger part # 4X829) "control devices" model # IC75 Another idea might be reverse flow check valve for O2 side of torch. They are 9/16"-18 R.H. thread. $7.99 each, grainger part # 3WU27, sure they would flow enough, not sure they would have the "duty cycle" life needed. And there is a post for some % off at Grainger on here |
