HF tall underhoist stands any good? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-20-2009, 11:00 AM   #1 (permalink)
Realsquash's Avatar
Member # 2578
Send a message via Yahoo to Realsquash
http://www.harborfreight.com/cpi/cta...emnumber=41860
I'm in the market for some tall stands, one that go 36-48" high or so. This goes 49-93". It looks like it would be cheaper to cut down a few of these than to buy the more expensive, but still Chi-com quality ones. Has anyone messed with them?
Andy
Realsquash is offline   Reply With Quote
Old 11-20-2009, 11:21 AM   #2 (permalink)
Member # 77424
Very nice for the price and sturdy - not HF sturdy, actually sturdy.
Any Seven Offroad
adampfisters is offline   Reply With Quote
Old 11-20-2009, 11:30 AM   #3 (permalink)
Member # 77424
You may also want to look into pipe stands, they should be about the same price and you won't have to cut them down.
Any Seven Offroad
Old 11-20-2009, 12:03 PM   #4 (permalink)
Realsquash's Avatar
Member # 2578
I've looked into them and can't seem to find a place around here that has any in stock. I always wait until I need something to buy it and now I need 4! I've called a bunch of places around here and they are dumbfounded.
Andy
Old 11-20-2009, 12:26 PM   #5 (permalink)
Member # 77424
There are some on Ebay but they are more expensive (like 80 a pop)
Do you need them just for one project? Just build some at the height you need out of square tubing.
Any Seven Offroad
Old 11-20-2009, 12:34 PM   #6 (permalink)
Realsquash's Avatar
Member # 2578
I think I could use them for a bunch of projects but I need to use them on the next project in line I thought about making them but I spend a lot of time at work and commuting and don't have much time to mess around at home anymore.
Andy
Old 11-20-2009, 06:39 PM   #7 (permalink)
Shotgun Fabworks
carwash's Avatar
Member # 21939
Send a message via AIM to carwash Send a message via Yahoo to carwash
I've got a set of pipe stands that are the height you are looking for. Look around for a good deal on the, they are crazy sturdy and well built. I have seen them go for as cheap as $60 a pair or so if you dig...
carwash is offline   Reply With Quote
Old 11-21-2009, 08:24 AM   #8 (permalink)
Member # 12499
I have one of the stands like the one pictured-but not bought from HF.
Now that they are on sale, I've been thinking of buying a pile of them, keeping some as they are for underhoist use and cutting four of them down to suitable size for frame work. At $60/each, it's hard to beat having them done and not having to fab them up.
Wrenchin' to riches!
If you want peace, prepare for war.
PTSchram is offline   Reply With Quote
Old 11-21-2009, 08:42 AM   #9 (permalink)
GubNi's Avatar
Member # 25927
I've used that one for years and love it.
Dana 60 or 14 bolt disk brake kits $315 shipped --> click here
Dana 70 kits $300 --> click here . . Sterling 10.25 kits $390 --> click here
Dana 60 front 3/4 ton kits $350--> click here
GubNi is offline   Reply With Quote
Old 11-21-2009, 03:11 PM   #10 (permalink)
Realsquash's Avatar
Member # 2578
I picked up 3 of them today! The box says they are 49 lbs, and I believe it. I'm cutting them down tonight so I'll take some pix. They are much higher quality than I would have expected. They have a roller bearing on the keyed acme threads to it's easy to adjust with weight on it.
Andy
Old 11-21-2009, 07:41 PM   #11 (permalink)
Realsquash's Avatar
Member # 2578
Well here we go. I cut all three down quite a bit! It was simple to do. I'm impressed by these things. Here's a few pix (I'm not sorry about the size, suck it).
FWIW all these photos were taken w/o a flash in my shop. 48 T8 bulbs and white walls help!
Original unit before mods. The base was 24" wide and minimum height was about 57":
Close-up of the bearing:
After mods here. I chopped about 18" off the legs and cut about 12" off the center tube:
After mods, fully extended:
Overall I'm very pleased with these. I paid $59.99 each but I had a couple of 20% coupons and made several trips to the parking lot
Andy
Old 11-22-2009, 05:51 AM   #12 (permalink)
Member # 54522
holly hell you did chop them alot. that king dont look wide enough when its fully up. did you take some measurements when new to get the same height to width ratio?
86 4runner 7MGE bobed, exo, SAS on 38s, 5.29, fully locked with duals/4.7 and 30spl longs
dopeassjackson is offline   Reply With Quote
Old 11-22-2009, 07:29 AM   #13 (permalink)
D60
D60's Avatar
Member # 6398
Not bad at all! MSC sells the Ridgid pipe stands quite reasonably and you have the advantage of quick adjustment of the slider/stachion tube, using only the washer that binds. But this approach is pretty cool too
"Take 300 people and on average 290 of them just generally suck at life"
D60 is offline   Reply With Quote
Old 11-22-2009, 09:18 AM   #14 (permalink)
Member # 12499
$60/each and no shipping?
