Member # 14187
Can I use a 10/3 110v extension cord for 220V?
I just upgraded my Lincoln SP100 to an SP 170T and need to again run an extension cord from my house to the street. The cord I have been using is a 10 gauge 3 prong cord. If I lop off the ends can I rewire it to work with 220 plugs?
Member # 14187
Found this on welding web. Over 100 posts on this so it looks like it's working for this guy with his Tig. My welders specs are
230V/60Hz 20 Amps @ Rated Output 208V/60Hz 22 Amps @ Rated Output so it should be OK. http://weldingweb.com/showthread.php?t=11537 Last edited by Blackdog76; 02-01-2010 at 10:46 AM. |
Member # 7753
Yes, the size of conductor sets the amps it can carry. The thickness of the insulation determines the volts it can safely handle. The max volts is usually stamped on the side of the cord in tiny writing.
Member # 54522
i use 12/3 for my 20a plasma. its the same size that the factory cord is made from.
86 4runner 7MGE bobed, exo, SAS on 38s, 5.29, fully locked with duals/4.7 and 30spl longs |
#8 (permalink) | |
Addicted to Gear Oil
Member # 56050
Yes, I used a 10-3 50' "YellowJacket" Heavy duty extension cord from Lowes and added the appropriate ends to match my 220V outlet and my welder. It was cheaper to buy the extension cord and cut off the ends than buy the cable by the foot off the roll. It works great.
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016 |
Member # 69678
i've been running my pro mig 175 for a couple of years now on a 10/3 cord.the cord is 50 foot wired into the panel on a double pole 30 and has a dryer plug on the business end.i've never popped the breaker,even while turned all the way up burning 1/4 material for long periods of time.
78 SII very healthy 327,th-350,np205,35''boggers 71 800B LT-1,400,203/205,FF14,d-60,42'' rockers on beadlocks To my great friend rob,RIP buddy we'll never forget you. |
