Brake line inverted flare gone too far.... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-07-2010, 09:06 AM   #1 (permalink)
abrogate's Avatar
Member # 31552
Send a message via AIM to abrogate Send a message via MSN to abrogate
I was wondering if it is possible to create a bad inverted flare by pushing the die to the point where it is bottomed out? I use a hand held hydraulic flaring tool and it makes aesthetically perfect inverted flares, but i would say that one out of three leaks under pressure. Any ideas?
This is the tool i have:
http://www.mastercool.com/pages/flaring_tools.html
71475
[B][CENTER][SIZE="6"][FONT="Impact"][COLOR="DarkRed"]Temet Nosce[/COLOR][/FONT][/SIZE][/CENTER][/B]
[QUOTE=ashmanjeepXJ;7641445]All you will probably ever have in common with this forum is a steering wheel. [/QUOTE]
abrogate is offline   Reply With Quote
Old 03-07-2010, 09:27 AM   #2 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
the only times i have had fittings not seal is if i managed to split the hard line or made the flare to big by have to much line sticking out of the die.
Old 03-07-2010, 09:28 AM   #3 (permalink)
Karnage
spidr's Avatar
Member # 55444
I've got that exact kit, and ever since I started using it, I've never had a fitting leak.
Thanks to BAILEIGH INDUSTRIAL
Krush RT IFS/IRS
Thanks to Epic Polymer Fox Kustoms Inc Pathmaker Productions[/color]
https://www.facebook.com/KrushRacing
spidr is offline   Reply With Quote
Old 03-07-2010, 09:51 AM   #4 (permalink)
bronco75's Avatar
Member # 8512
Send a message via AIM to bronco75
I also have the same kit and use it in my job on a regular basis and it made perfect flares everytime. Only thing I can guess is your either not getting a straight cut of tube of the wrong stick out of tube.
keep up or get left behind
75 bronco trail buggy
60-9 frt build up thread
OutBack Auto 4WD and Fab
MV4W.com
bronco75 is offline   Reply With Quote
Old 03-07-2010, 10:57 AM   #5 (permalink)
abrogate's Avatar
Member # 31552
Hmmm. I wonder what the hell is going wrong then. I guess part of it is that I use a tubing cutter rather than a hacksaw. That being said, I always chamfer the inside of the tubing with a counter sink and then file the end of the tube so that it is clean and bur free. I guess I will keep trying to figure it out.
What type of tubing material are you using? I have been using the steel lines with the coating.
Also, if you swear by the hacksaw method, what TPI are you using? I have never been able to cut the tubing without murdering the ends
Old 03-07-2010, 11:04 AM   #6 (permalink)
Karnage
spidr's Avatar
Member # 55444
I have a tube cutter I keep in the kit, it's all I ever use.
Krush RT IFS/IRS
Old 03-07-2010, 05:17 PM   #7 (permalink)
Member # 79052
Are you cleaning the coating off the area of the tube to be flared? I've had that problem at work with the coated stuff. Also keep in mind it's allot more powerful then a regular flare tool. Don't force the die too far.
iboc44 is offline   Reply With Quote
Old 04-22-2010, 05:04 AM   #8 (permalink)
abrogate's Avatar
Member # 31552
I finally ended up figuring out what I was doing wrong. After the initial flare, I was pushing the cone adapter in too far. This created a scenario where some would seal, but others wouldn't. I looked at a brake line I got from NAPA and theirs had an inverted flare that was barely inverted. I tried that with my tool and it worked first try. Hopefully this helps someone.
Old 04-25-2010, 06:49 AM   #9 (permalink)
BADD SS's Avatar
Member # 154535
Yeah I have the same one and it works great, seems like ya figured it out though! Push connect stuff is an awesome feature too.
2007 Silverado 2500HD 6.0 5 Speed 4x4
2000 Camaro SS Race car, ls1/t56 N/A 10 Sec car, 9's soon!
BADD SS is offline   Reply With Quote
Old 04-26-2010, 04:06 PM   #10 (permalink)
SpineTx's Avatar
Member # 1499
Not to hijack this thread, but would someone be willing to post some pics of some tube you flared to show what is "too much" inversion or not enough inversion?
Pain is your Mind Failing you;
Body Damage is your driving ability failing you
SpineTx is offline   Reply With Quote
Old 04-28-2010, 05:38 AM   #11 (permalink)
abrogate's Avatar
Member # 31552
i'll see if I still have the bad ones in the garage. I might have thrown them away.
Old 04-29-2010, 10:17 AM   #12 (permalink)
SpineTx's Avatar
Member # 1499
Thanks, it is appreciated.
Old 04-29-2010, 11:45 AM   #13 (permalink)
Dabbler
actionpaintball's Avatar
Member # 29562
Send a message via AIM to actionpaintball
X2...never had a problem with my mastercool kit
actionpaintball is offline   Reply With Quote
