Plasma Circle hole cutter.....cheap and easy!!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-23-2010, 06:22 PM   #1 (permalink)
Member # 80076
I've been wanting to cut some holes with my hypertherm 1000 for a while now....I just didn't want to drop the coin on a circle cutter from hypertherm.
My idea of a cheap circle cutter consisted of this...
I just used some scrap steel, thats the reason for the wierd "L" shape.....
I then drilled a 1/4 inch hole for the pivot point. I then put a bolt through the hole to act as a pivot and a place to hold the cutter down..
I then drilled holes the same size of the torch drag tip...just a little bit of clearance so it doesn't bind
Drill your 1/4inch pivot hole and then stick the drag tip in the hole and your ready to rip circles
Here is after I cut two holes with it.....a 2in and 4in hole.
It will cut between 2-7 inch holes in 1 inch increments
Here are some pics of the holes and the drops
Just throwing some ideas out for others to check out instead of buying the $80+ factory circle cutter...
It took me about 30 min to make.....let me hear some opinions.
You were born an original, Don't die a copy
fLaT TiRe is offline   Reply With Quote
Old 03-23-2010, 06:33 PM   #2 (permalink)
Member # 15076
Simlar to the one I made for my oxy torch. Except I used one of those plastic slide compass setups that fits on a 1/2" round rod. The compass setup was about $3 on a clearance rack and it has a nice sharp center point so I only have to center punch the center of my circle and the sharp point stays put somewhat nicely.
MQYJ is offline   Reply With Quote
Old 03-23-2010, 06:37 PM   #3 (permalink)
I make websites!
Member # 12429
Cool idea, could easily be modified too
My 4x4 Blog
Rockwell axles too!
Todd W is offline   Reply With Quote
Old 03-23-2010, 07:22 PM   #4 (permalink)
D60
D60's Avatar
Member # 6398
I've done booty versions like that,too, but rarely do I need to cut in 1" increments, or on whole or half inches. Something infinitely adjustable is definitely more useful. And yeah, I'd sharpen yourself a tip so you only have to center punch.
"Take 300 people and on average 290 of them just generally suck at life"
D60 is offline   Reply With Quote
Old 03-23-2010, 07:42 PM   #5 (permalink)
Member # 80076
I'm using this for cutting holes for frame plates, so it works perfect for that
I used the 1/4 inch bolt with a wingnut on the back with some washers so it will hold the cutter securely.....not very impressed with the center punch method
Old 03-23-2010, 07:51 PM   #6 (permalink)
RLC Welding
Member # 105383
Another quick circle cutter is to cut a thin sliver of tube or pipe in your choice of diameter and tack it to the plate.
Plas around it and you've got a good circle and the 5 second jig falls to the floor.
RLC Welding and Fabrication
Louisville, KY
(502)403-6832
Winch bumpers for 73-98 Full size Chevy, 87-91 F-series, Ford Explorer and Rangers, Jeep xj and zj, Nissan xterra, and MORE!
CNC Plasma cutting!
jamscal is offline   Reply With Quote
Old 03-23-2010, 08:10 PM   #7 (permalink)
Member # 80076
Good idea! I'm going to be using that
Old 03-24-2010, 03:10 AM   #8 (permalink)
Member # 54522
i made one like that but with threaded rod so you could adjust it. it was tits for cutting tail light holes for installing rubber grommet lights.
86 4runner 7MGE bobed, exo, SAS on 38s, 5.29, fully locked with duals/4.7 and 30spl longs
dopeassjackson is offline   Reply With Quote
Old 03-24-2010, 05:53 AM   #9 (permalink)
RLC Welding
Member # 105383
Thanks.
Another trick I've seen it to use one of the ground clamp magnets as the base for the pivot point.
No drill, and more stable than the center punch method.
Louisville, KY
(502)403-6832
CNC Plasma cutting!
Old 03-24-2010, 06:22 AM   #10 (permalink)
Member # 12499
Thanks.
This I like! A lot!
Wrenchin' to riches!
If you want peace, prepare for war.
PTSchram is offline   Reply With Quote
Old 03-24-2010, 07:38 AM   #11 (permalink)
Member # 17042
Here's one that I had saved to my computer of one I wanted to build. Very simple, the point could be a circle welding magnet with a bushing and a wingnut for infinite adjustability.
[QUOTE=Myanarchy;9475039]maybe if more kids got involved in projects we'd have less kids living in projects:flipoff2:[/QUOTE]
76scoutman is offline   Reply With Quote
Old 03-24-2010, 08:03 AM   #12 (permalink)
D60
D60's Avatar
Member # 6398
The production kits come w a center punch, magnet, and bolt-thru option. Bought one for my ESAB several years ago. Wheels support the torch but you still gotta have a steady hand near the edge of the plate.
http://www.welding-direct.com/circutkit.html
If cutting something to cap a pipe the bolt-thru is a PITA because then your drop has a hole in the center which you have to plug or weld up and grind down.
I've worked in shops where the welders cut beautiful circles in 1" and 1.5" plate with nothing but a center prick and oxy/acet, so I guess just like anything else it comes down to skill.
Old 03-24-2010, 07:06 PM   #13 (permalink)
peccavi18's Avatar
Member # 73583
Send a message via AIM to peccavi18
Cutting holes for my taillights and coil buckets we traced around grinding wheels/cutoff wheels. Just find one the right size, we measured and labeled a few even so we could grab them quick. Clamp it down or strong magnet it and trace.
Project Fat Fawk - http://www.pgh-offroad.com/forum/showthread.php?t=7367
peccavi18 is offline   Reply With Quote
