JD2 mounting problem - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-23-2010, 03:11 AM   #1 (permalink)
Member # 47954
No garage and no concrete, paved driveway or dirt. How to mount the thing ? Rebar through the base and into the ground, say 4' ?
2 Jeeps with subtle changes
itsakeeper is offline   Reply With Quote
Old 05-23-2010, 05:48 AM   #2 (permalink)
Member # 54522
do a air over hyd conversion. in the end it will be cheaper and easier.
86 4runner 7MGE bobed, exo, SAS on 38s, 5.29, fully locked with duals/4.7 and 30spl longs
dopeassjackson is offline   Reply With Quote
Old 05-23-2010, 08:31 AM   #3 (permalink)
Member # 45530
X2
http://copperheadfab.com/index.php?a...&productid=164
http://www.harborfreight.com/8-ton-l...ack-94562.html
+few hour and some scrap steel
Panthers65 is offline   Reply With Quote
Old 05-23-2010, 08:38 AM   #4 (permalink)
Member # 50132
Originally Posted by Panthers65 View Post
I would skip the copperhead fab deal and build your own. Very easy to do and can be done way better than the one mentioned. The HB ram works great tho
bigS-dime is offline   Reply With Quote
Old 05-23-2010, 09:37 AM   #5 (permalink)
RLC Welding
Member # 105383
If you don't want to or can't go hydro bolt it to a piece of 2" square tube that fits into the receiver hitch of your truck.
You may have to extend it/orientate it/ build some contraption with additional legs but it's been done before.
RLC Welding and Fabrication
Louisville, KY
(502)403-6832
Winch bumpers for 73-98 Full size Chevy, 87-91 F-series, Ford Explorer and Rangers, Jeep xj and zj, Nissan xterra, and MORE!
CNC Plasma cutting!
jamscal is offline   Reply With Quote
Old 05-23-2010, 09:55 AM   #6 (permalink)
Member # 2395
Just build a stand and mount it to a piece of 1 1/8" plywood. As long as you are standing on the plywood when you are pulling it will work great.
Dustin is offline   Reply With Quote
Old 05-23-2010, 10:17 AM   #7 (permalink)
Snowbird13's Avatar
Member # 44136
For those of you telling him to do air over hydro, he has no garage. Therefore, he probably doesn't have an air compressor big enough to run the HF ram. I know mine takes a shit ton of air.
Hammers Thread post #1388
Tellico Rallypost # 285
Snowbird13 is offline   Reply With Quote
Old 05-23-2010, 12:56 PM   #8 (permalink)
Member # 54522
i ran my ram with a 25gal compressor on my first cage. it did ok, better with a 60gal.
make a winch mount jig like one guy did to bend tube.
Old 05-23-2010, 01:09 PM   #9 (permalink)
Member # 9152
He could use the jack handle to run the ram without air.
Why kill them with kindness when you can use an axe?
78bronco460 is offline   Reply With Quote
Old 05-23-2010, 02:54 PM   #10 (permalink)
Member # 47954
Jd2
good tips so far and the links too; I do have a 26gal compressor in the basement, welder, plasma, etc... usually do my work outside on nice days; and I already have the bender, jsut trying to figure out how best to mount it
I have a long stroke jack like the one in the links but its manual not air. - anyone done this ? how does it compare with the JD hydo/air conversion ?
would the bender really stay mounted on plywood ? last time I used it in a buddys garage it took quite a bit of force to bend 1 1/2" tube - I can see knocking myself over with the bender on top of me
Old 05-23-2010, 03:23 PM   #11 (permalink)
Member # 9152
Here's a picture of the way I mounted my PT105 with a HF ram and a crappy engine stand:
http://www.supermotors.net/getfile/4...e/p1010080.jpg
EDIT: I been bending conduit vertical for 25 years so this setup works better for me.
Old 05-23-2010, 03:38 PM   #12 (permalink)
Member # 54522
cool idea. the thin wall of the engine stand strong enough for 8 tons?
Old 05-23-2010, 03:58 PM   #13 (permalink)
Member # 2395
I'd use the thick 1 1/8" stuff through bolted with big washers. I guess it depends on the bolt pattern on the base of your stand. You could always dig a 2' x 2' footing and sink some anchor bolts into it. That could always be dug up and filled back it when you go hydro.
Old 05-23-2010, 04:07 PM   #14 (permalink)
Interweb Wheeler
section525's Avatar
Member # 14692
Send a message via AIM to section525 Send a message via Yahoo to section525
My temp-ghetto-ness.
EDIT: Don't need the weights down there. They were there from before I parked on the rock slider.
The Grocery-Getter '96 Explorer V8 SAS
section525 is offline   Reply With Quote
Old 05-23-2010, 04:25 PM   #15 (permalink)
Member # 9152
The bender and ram are mounted to 2" x .250 structural tube... the only thinwall is the base.
Old 05-23-2010, 04:28 PM   #16 (permalink)
Member # 67907
I would go with the air/hydro setup.
Another way would be to dig out an 1.5'x1.5'x8" and pour a small slab. I did this off the side of my old driveway so the bender wasnt always in the way. Sink lots of rebar into it, and you should be good.
The Beepster
[url]http://www.pirate4x4.com/forum/showthread.php?t=727456[/url]
Jeepermat is offline   Reply With Quote
Old 05-23-2010, 08:25 PM   #17 (permalink)
Member # 158459
I have a similar but different situation!! My bender is at the folks house and the house is built on pile-ons about 14' off the ground and you drive up on 2x6 decking to park underneath the house! This being said, I made a "cross" underneath the base that I fab'd for the bender out of 2x6 boards and countersunk the bolt heads so it would be stable. It works great for the 1/2" to1" stuff I bend while I stand on a couple of the boards. I really think it would be a struggle on a 2" piece but I have just put it up against a pile-on under the house for a 1 man operation before!! It works until I have a pad to permanenty sink this beast too!!
Goodsportz Racing is offline   Reply With Quote
Old 12-07-2010, 09:34 AM   #18 (permalink)
Swag Sales
dozer_xj's Avatar
Member # 90594
I have this same problem! Any more ideas?
I can put your business, personal and/or club name on shirts, hats, coolers, koozies, pens, jackets and more! Just ask! Get with me on your industrial safety needs as well!
Andrew Dial
Jedco Sales Inc.
jedcosales.com
PM me or email andrewd@jedcosales.com
We are family owned and in our 30th year! Big enough to get great products and prices. Small enough to know who you are!
dozer_xj is offline   Reply With Quote
Old 12-07-2010, 08:41 PM   #19 (permalink)
snowracer's Avatar
Member # 141697
as i have to work out of my old mans shop i have to make sure i can dismantle me bender when not is use. i came up with a mount on a steel saw horse that i can put the bender on.
works good as i have bent close to 300feet with it like this. when pulling real hard it might move an inch or so, plus i can hold the top tube with one had and the other on the bender handle for hard pulls
THE HAYWAGON
R.I.P
THE HAYWAGON HAULER
1979 F250 going from hauler to wheeler
snowracer is offline   Reply With Quote
