Member # 99055
over head welding
hey everybody
Ive been working on some projects lately, and in a couple nights im doing some welding on a buddies jeep. ive gotten fairly decent at most positions I run into but have almost no experience with overhead stuff. any good pointers or videos i should watch thanks |
How critical is the weld? I would do the tack tack tack method (pulling the trigger for a good long count and make a circle motion, not just a quick tack), turn the welder up a couple settings past what you need and it will burn in good. I've done a lot of welding like that. A lot of people will say this method is shit but unless you are an excellent welder overhead welding is probably the hardest to do, especially if you are using a mig welder with gas. Or you can try small stitches, just try and stay away from long slow passes (tends to booger up and drip molten metal down your neck). Just my $.02.
Member # 99055
the weld is going to be for the frame end upper control arm brackets for a rear 4 link. ive done the front 3 link, tube fenders, and the rest of the rear, but these brackets are the last ones to go....saved the hardest for last i guess.
thanks for the help |
Member # 8274
Welded upside down with my MIG once, still have the 2 holes in my shoulder where I got goobered on with molten slag...
From then on out I just vowed to only weld looking down. Just flip the project over. ![]() Or TIG. |
Member # 87150
Bump the wire-speed a smidgen, and watch the puddle. People overthink overhead welding, and it's just not that hard, don't get tripped up in your head.
[QUOTE=Dieselmh;11422920]This thread is like McDonalds. It fucking sucks and doesn't deliver. :([/QUOTE] |
Member # 113418
I am seen and heard many people call anything that they have to reach above there head overhead .
Overhead is just flat welding turned upside down. For any but the littlest amount it is time to break out the leathers. Good luck it just takes a little practice. |
Member # 25216
turn up the wire speed just a little bit and push the puddle.
#327 Lambert Motorsports Follow us on facebook here. Help us race in KOH 2012. #327 Build and #327 Pics Thanks to our sponsors: Clayton Off-Road BFGoodrich Extreme Axle Sales |
#11 (permalink) | |
Member # 12499
Take lots of breaks, stay hydrated.
Wrenchin' to riches! If you want peace, prepare for war. |
#13 (permalink) |
Master Apprentice
Member # 56692
Your probably going to want to turn your volts up .5-1.5 from what you normally run, other than that its just like welding flat. The hardest part is getting in a good position.
You welded constantly for an hour overhead? On what? Ive got to wave a flag on this one. Its hard on the body to weld intermittent overhead for 15 min.
1992 Explorer SAS'ed on HPD44/9" W/ 5.13 Locked F/R 36" TSL-SX on DIY Locks |
#14 (permalink) |
We turn up the heat a little for overhead MIG.
Industrial Quality CNC machines at a Hobby Price! USA Quality is job #1 We build CNC plasma tables, click me .................................................. .........![]() American Motors Engine HERE!! 1-651-257-7917 |
#15 (permalink) |
sweet jesus
Member # 104026
What works for me welding uphill is an upside down V pattern and holding for a second on each side of the gap. But like others have stated your voltage and wire speed has got to be spot on hope this helps
#17 (permalink) |
DuCaTi MoNsTeR
Member # 2931
make sure the metal is clean(ground clean of mill scale, paint, oil, etc, etc) and the hot molten drippins will drastically be reduced...i push when welding over head, weaving a bit from side to side(not as drastic as vert up) and dont position myself directly under the weld. leathers are a given for your arms and shoulders, but my settings are identical to flat and horizontal welding. only when welding vert up do i change settings for a given weld type MIG process(i drop wire speed just a bit)
Amongst the best of the toyota vendors: Www.4wheelunderground.com Www.addictedoffroad.com Www.hellfire-fabworks.com |
