Husky Rancher 455 chainsaw rebuild? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-26-2010, 09:15 AM   #1 (permalink)
randal106's Avatar
Member # 97420
I have a Husqvarna Rancher 455, Wont run.
Its only got about 60PSI on my compression gauge, whats the stock numbers on one of these saws, I assume about 140.
Anyone ever rebuilt one before? it seems like a pain in the ass to pull the head off....
Yep
randal106 is offline   Reply With Quote Quick reply to this message
Old 08-26-2010, 10:29 AM   #2 (permalink)
Member # 23027
With that saw it's probably not worth the money to rebuild if you've wasted the cylinder and piston. Check out arboristsite for all the information you could ever want. Just know going in that is a "homeowner saw", not a "pro" model and you may get rediculed if you start asking a lot of novice type questions or act like hot shit. It's very similar to how this site used to be in fact, except more of the people there actually do things other than surf the internet.
CAC91 is offline   Reply With Quote Quick reply to this message
Old 08-26-2010, 02:18 PM   #3 (permalink)
Member # 32841
Send a message via AIM to cybergeek23851
Before you get too hasty, how does the cylinder look? Pull off the muffler, remove the spark, and shine a light down through the top of the cylinder. If you have access to a small sized bore scope, you can get away with just removing the spark plug. If the cylinder has a mild case of galling, clean it out with something like scotch brite and kerosene. Then make sure the bore is good and clean and not out of spec. It may take a mild honing, but if it's clean and in decent shape, you got very lucky, and all you'll need is a piston and ring. If the cylinder is clean, and all you would really need is a new ring, some very mild honing to break up the glazing, and some gaskets.
Here are some of the parts you *might* be looking at.
49 MM OEM(Husqvarna) Piston and cylinder for a 460 Rancher... bolt on big bore kit, basically.
http://www.baileysonline.com/itemdet...2+05+01&catID=
Gasket set:
http://www.baileysonline.com/itemdet...1+26+01&catID=
OEM piston for a 455(47MM).
http://www.baileysonline.com/itemdet...02&catID=10977
Piston Ring (47MM)
http://www.baileysonline.com/itemdet...8+90+29&catID=
Piston Ring Compressor:
http://www.baileysonline.com/itemdetail.asp?item=10429
Cylinder Hone
http://www.baileysonline.com/itemdet...C+48&catID=100
cybergeek23851 is offline   Reply With Quote Quick reply to this message
Old 08-26-2010, 04:54 PM   #4 (permalink)
Member # 26821
should have bought a Stihl.....
youll hear that alot over on AS
uninformed is offline   Reply With Quote Quick reply to this message
Old 08-26-2010, 05:15 PM   #5 (permalink)
Member # 71711
I do lawn and garden equipment for
a living and I see this a lot.
Figger the price of the saw new divided in 1/2.
Add up part's cost toss in a little for labor.
If you reach that number go buy a new saw.
You might be surprised what some part's cost.
A needle and seat kit for a Honda push mower runs $22.00.
A complete rtr carb.'s only $19.00.
Did a trimmer this week new carb. at $138.00.
88sammi Waggy 44,s 538,s 5to 1 tcase yj front spring,s toy p/up rear spring,s turned backward,s saginaw power steering 36" tsl,s full cage
zukidave is offline   Reply With Quote Quick reply to this message
Old 08-27-2010, 03:06 AM   #6 (permalink)
Member # 26821
check ebay for parts and also Bailey's online....
also consider ditching it and buying a used pro saw
Husky 346xp
Dolmar 5100s or 5105
Serg
Old 08-27-2010, 06:17 AM   #7 (permalink)
Member # 82644
Jonsred
[QUOTE=xjdoug;9487015]this is like watching a kid stick his finger in a light socket.... sooner or later he's gonna figure out why the rest of us arent doin it...[/QUOTE]
hadfield4wd is online now   Reply With Quote Quick reply to this message
Old 08-27-2010, 08:54 AM   #8 (permalink)
Digger
RDR800's Avatar
Member # 30673
Last I heard Jonsered and Husky were made in the same factory. I have bought alot of stuff for my saws from Baileys, including their bigbore kits.
Lead, follow or get out of the way.
RDR800 is offline   Reply With Quote Quick reply to this message
Old 08-28-2010, 05:49 PM   #9 (permalink)
randal106's Avatar
Member # 97420
Looks like the ring is collapsed, piston looks good, just a little blow-by and carbon, should clean right up. the cylinder is a little scored, but nothing that will stop it from running after a new ring.
that thing was a pain in the ass to get apart.
Yep
