Making Dimple Dies - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-14-2010, 09:44 PM   #1 (permalink)
Member # 123182
Making Dimple Dies
Started making a set of dimple dies today. I made a 3/4" one tonight and started the next size but the pump for the lathe coolant took a shit. Took about 2 hours to finish but I think I got the science figured so I should knock em out in no time. I'm going to finish the 1.5" one tomorrow and start on a 1" and 2" one after that.
Any input on popular sizes you guys are using?
I apologize for the phone pics, all I had in the shop...
mulisharider11x is offline   Reply With Quote Quick reply to this message
Old 10-14-2010, 10:36 PM   #2 (permalink)
Member # 87150
Nice, one bit of advice I have is to make 2 sets. Make one with a narrow shoulder like the one you just made, and make one with a big wide shoulder. I bought some cheap dimple dies from a Pirate vendor and they were a PITA because the shoulder wasn't big enough so they warped the shit out of the material, especially thick stuff. I now use Light Racing dimples and they flatten the material out perfectly, though I would like a more pronounced dimple. The narrow shoulder can be nice if you need to dimple in a tight area, still borrow the other dimples back from my buddy who I gave them to every once in a while for dimpling in a corner.
Oh, and make a dimple die for Dzus fasteners, makes stuff look way more bad-ass when it has nicely fit Dzus fasteners everywhere.
[QUOTE=Dieselmh;11422920]This thread is like McDonalds. It fucking sucks and doesn't deliver. :([/QUOTE]
maxyedor is offline   Reply With Quote Quick reply to this message
Old 10-14-2010, 10:42 PM   #3 (permalink)
Member # 123182
How much wider of a shoulder?
Old 10-15-2010, 01:47 AM   #4 (permalink)
Member # 87150
I'll measure the shoulder on the Light Racing dimples tomorrow morning, they flatten the material out perfectly. Though to be honest, I may just be thrown off by the fact that you posted a 3/4" die, which always has a small shoulder.
Old 10-15-2010, 05:10 AM   #5 (permalink)
87JeepWrangler's Avatar
Member # 13959
Send a message via AIM to 87JeepWrangler
pipe sizes, especially because i have one of these
rob
87JeepWrangler is offline   Reply With Quote Quick reply to this message
Old 10-15-2010, 05:15 PM   #6 (permalink)
Member # 54522
your angle looks to be a bit to much. i think i used about 30* and it worked good with out distorting the metal to much.
this is one of the dies i made. one side is a 1/2in and the other is a 3/4in.
dimple dies are a fun project to build. post up pics when you get another one made.
there's also a whole thread on practical machinist on making them.
86 4runner 7MGE bobed, exo, SAS on 38s, 5.29, fully locked with duals/4.7 and 30spl longs
dopeassjackson is offline   Reply With Quote Quick reply to this message
Old 10-15-2010, 10:17 PM   #7 (permalink)
Member # 123182
This Is the 2" die I made tonight. @ 45 degrees. And I haven't had an issue with it warping yet, just taking maxyedor's advice and making the flat shoulder larger. But I did some reading and it seams you need a steeper angle of break to produce stronger results. I.e why I did them at 45*, they work so far and that'd be good enuff for me to sleep at night. Haha. Thaynks for the input.
Old 10-16-2010, 12:14 PM   #8 (permalink)
Member # 146273
For materials for dimple dies I use old hydraulic ram rods which can be got for free from repair shops .Normaly en8 or other good quality steel
junkbuilder is offline   Reply With Quote Quick reply to this message
Old 10-16-2010, 06:14 PM   #9 (permalink)
Member # 123182
I work with heavy equipment daily and I use non hardened pins out of excavators for the stick linkage For some of the material for these dies. Most cylinder rods are industrial chromed and the outside 1/4" of the rod will dull any bandsaw w/o carbide teeth. And will break lathe bits aswell.
Old 10-17-2010, 01:55 PM   #10 (permalink)
Member # 146273
I , and every hydraulic shop I know use a power hacksaw for the cutting of chrome rod, and I reject any of the case/induction hardened stuff for re use.Never had any trouble in machining the stuff(including 10 years of making rams)
Old 10-17-2010, 03:18 PM   #11 (permalink)
Member # 54522
lathe bits are carbide so why do you think it will brake them when the carbide saw will cut the rod?
Old 10-17-2010, 03:20 PM   #12 (permalink)
Member # 54522
if all you are dimpling is sheet metal then 45* wont give you much problem. i have dimpled 3/16 with my 3/4in die in a 20ton press, with a 30-35* bevel.
Old 10-17-2010, 08:58 PM   #13 (permalink)
Member # 123182
I'm not sure why but I thought lathe but ment drill. My mistake. Carbide concrete drill bits work though.
If the two inch 45* die gives me trouble on the thick stuff tomorrow I will turn it down to 35*ish.
