Member # 53528
12 ton press good enough?
yes i suck at the search apparently because i know this has been covered so please bare with me here. i need to setup some 14 bolt gears and install a set of trunnion bearing eliminators in my hi steer arms, i can get this http://www.harborfreight.com/garage-...ess-33497.html for around the same price i could pay someone with a press to do it for me so i figure i should just buy it so next time i need to press something i wont have to shell out any $$
12 ton strong enough to do basic things like i listed? Last edited by rockyota83; 12-26-2010 at 03:20 PM. |
#2 (permalink) | |
Addicted to Gear Oil
Member # 56050
Get the 20T. 14BFF pinion crush sleeve can be a bitch.
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016 |
Tonka Truck Driver
http://www.harborfreight.com/20-ton-...ess-32879.html
Go ahead and spend a little extra on the 20ton. It has a welded frame, whereas the 12ton's frame is bolted together with grade 5 bolts. Plus, you will have that extra 8ton when you need it.
What happens in the Cooking Forum, stays in the Cooking Forum. www.facebook.com/kenneth.rivenbark |
Member # 53528
i would but that takes me from 140$ shipped for the 12 ton up to 306$ shipped for the 20 ton which i cant afford (spent 4500$ on parts for my truck this month) so its either pay someone 100$ or buy the 12 ton press for 140$
will the 12 ton do it? or just pay someone? yes i want the 20 ton so i could dimple stuff but cant$ right now. Last edited by rockyota83; 12-26-2010 at 05:00 PM. |
#7 (permalink) | |
Tonka Truck Driver
Jacks wasted life
Member # 145196
when I got mine they had a bunch in the storage units out back - it will come in like 3 or 4 different boxes
I got mine at the one in fresno,ca .. had to drive an hour to get it but where I live you got to drive an hour to everything you could always call .. but I didnt
Member # 53528
yea mines about 1 1/2 hrs i will give the store a call before i go, where do i score a 20% coupon links in the thread in this forum seem to not work, i signed up to their website maybe they will send me coupon via email.
thanks guys |
#11 (permalink) | |
Tonka Truck Driver
this coupon is valid until 12/31/10. Print it out and take it in the store. Also, print out one of the other free item coupon. Only one free item per visit per day. If you search for HFT 20% coupon, I'm sure you will fond others.
#12 (permalink) | |
Jacks wasted life
Member # 145196
EDIT:not sure if this week has it but thats where it was when I got it a few months back Last edited by primate60; 12-26-2010 at 05:54 PM. |
#14 (permalink) | |
Jacks wasted life
Member # 145196
how do you think I felt!![]() I had a sign set up in front of me as a barricade ... it actually went really smoothly tho |
#15 (permalink) |
Member # 108445
I posted a 25% for new years in the HF coupon thread. In a prior post, I posted a link to the HF thread at slickdeals. 20%s off and free items. Plus the ITC coupons which they've accepted with the top torn off (remove ITC).
[edit] I just ran the ads and the after new years has the 12t for $99 (as a coupon). I don't see the 20t anywhere. Last edited by rocket flier; 12-26-2010 at 07:11 PM. |
#16 (permalink) |
Member # 46175
I usually try to not hold up a pinion support by the flange like that.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST Specializing in Axles and Transfercases |
#17 (permalink) |
Jacks wasted life
Member # 145196
it worked just fine for me fawker came right out didnt even hesitate ... that being said id do it again
have you ever cracked/broke any 14 bolt flanges in a 20 ton press by doing it this way - or even known of it to happen in a 20 ton press? |
#18 (permalink) |
Tonka Truck Driver
http://www.pirate4x4.com/forum/showp...&postcount=108
hey rock, here is a 25% for new years day only.
#19 (permalink) | |
Member # 12499
The 12-ton presses are junk. There is a huge difference between the 12 and 20 ton units. My 12-ton collapsed the upper beam and the movable beam disassembling the spline on a driveshaft ![]() Both of my 20-ton presses get used almost daily and do what I need them to do.
Wrenchin' to riches! If you want peace, prepare for war. |
#20 (permalink) |
White Trash Fab
You guys just talked me into the 20t I was gonna buy the 12t this week.
"If you are gonna live life on the edge you better have good balance" 06 Tundra DC The "Trifecta" 3 seat yota buggy ![]() http://pirate4x4.com/forum/showthread.php?t=1027210 http://www.AddictedOffroad.com/ www.ruffstuffspecialties.com http://f-o-a.com |
#21 (permalink) |
I wish I had spent the extra $$ for the 20T press but at the time it was all I could do. It gets most jobs done for me but I have run into it's limitations many times in both size and strenght. So far it has a bent cross bar, has been welded together to keep from getting out of rack, the press shaft has bent, the jack shit the sheets, and I've added casters.
All that being said, make the drive to the store, get a coupon, and buy the 20T or build it yourself but chances are you can't build it for what you could buy one for.
[QUOTE=Myanarchy;9475039]maybe if more kids got involved in projects we'd have less kids living in projects:flipoff2:[/QUOTE] |
#22 (permalink) | |
Member # 46175
Those 14 bolt crush sleeves are a PITA, and I always use the press start to get it crushed.
#23 (permalink) | |
Jacks wasted life
Member # 145196
Basically everything EXCEPT the crush sleeve, I had a machinist/ring&pinion guy do that for me - $15 dollars well spent
#24 (permalink) |
Member # 3236
We have a pneumatically controlled valve with quick connects on the air hoses so you can be as far away as you want from the 80 ton press for a reason, I was straightening the forks from the bobcat this morning and I was a good 15' away.
[QUOTE=Roxywheels]The trolls always out themselves :laughing: :roxy:[/QUOTE] |
#25 (permalink) | |
Jacks wasted life
Member # 145196
![]() I did upgrade to an engine block/bigger sign combo
