Spraying Rustoleum Hammered paint? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-09-2011, 08:20 AM   #1 (permalink)
Member # 7876
Send a message via AIM to Arya Ebrahimi
Anyone done it?
I'm getting ready to paint a trailer frame and am looking to purchase a spray gun. I use Rustoleum's Hammered paints in rattle cans for just about everything and love the finish and durability. Any tips for selecting a spray gun or for spraying the stuff? How does the finish compare to rattle cans?
Thanks
DD/Tow-rig: '06 GMC Sierra 2500HD Duramax
Classic Rig: '88 FJ62, 100% stock
In the weeds waiting for resurrection: '94 FZJ80, 33s, locked
Arya Ebrahimi is offline   Reply With Quote
Old 03-09-2011, 09:07 AM   #2 (permalink)
Member # 182470
Originally Posted by Arya Ebrahimi View Post
Anyone done it?
Thanks
I would use a foam brush. I have also heard about rolling it ,so I decided to try it when I painted my cherry picker. I didnt like the outcome with the roller, it had a texture but it was all one color and didnt have any of the black in the low spots. The foam brush works well and looks good.
I would worry that reducing it to spray and then spraying would net the same results I had with the roller ,one color and just a bit of texture
ERV JR is offline   Reply With Quote
Old 03-09-2011, 09:25 AM   #3 (permalink)
White Trash Fab
smewhtguy's Avatar
Member # 100827
Send a message via AIM to smewhtguy
Use no reducer and a bigger tip/nozzle it will spray fine.
"If you are gonna live life on the edge you better have good balance"
06 Tundra DC
The "Trifecta" 3 seat yota buggy
http://pirate4x4.com/forum/showthread.php?t=1027210
http://www.AddictedOffroad.com/
www.ruffstuffspecialties.com
http://f-o-a.com
smewhtguy is offline   Reply With Quote
Old 03-09-2011, 10:00 AM   #4 (permalink)
Member # 53557
I didn't use hammered, but did use rustoleum satin black on my M725 the last time it was painted. Used an HVLP gun and just thinned it to nearly 50% IIRC. Sprayed and turned out reasonably well.
There's a few parts shinier than other's because I wasn't as consistent with the thinning as I should have been, and shot them at different times with drastically different shop temps. Overal it turned out decent.
I'd think the stuff in the rustoleam cans (non-spray) that are meant for brushing are a hair thick to shoot even with a different tip, but I didn't try either.
Finish: about the same as the cans.. But like 300x easier and faster to do a bigger area.
Jason
alosix is offline   Reply With Quote
Old 03-09-2011, 10:25 AM   #5 (permalink)
Member # 182470
what size tip ? that stuff is thick as shit. It wont spray out a 1.8 and doubt a 2.2 would net good results
Old 03-09-2011, 10:30 AM   #6 (permalink)
Member # 182470
Jason
spraying a the satin black or the pro black isnt a problem, you can reduce it with acetone and spray it. I have sprayed that stuff a ton,but the hammered is super thick and think the hammered look will change with thinning. For a trailer I say brush or roll it and be easy to touch up later.
How about a raptor liner kit http://cgi.ebay.com/ebaymotors/U-Pol...motiveQ5fTools
Old 03-09-2011, 02:53 PM   #7 (permalink)
TLCObsession's Avatar
Member # 3245
I did it with Hammerite - just thinned it with Xylene and shot it. It was not an HVLP gun, just a conventional spray gun - same one I used to shoot other automotive paints.
Never subscribe to a conspiracy theory when the stupidity theory will suffice.
TLCObsession is offline   Reply With Quote
Old 03-09-2011, 03:04 PM   #8 (permalink)
Member # 73188
I did it with a harbor freight gun and some thinner, came out nice.
DRTRAYDEUCE is offline   Reply With Quote
Old 03-09-2011, 03:05 PM   #9 (permalink)
White Trash Fab
smewhtguy's Avatar
Member # 100827
I used a conventional gun as well, the same old junk gun I use to spray med/high build primer. Not sure on the tip size but it layed down in one coat and still had the hammered look.
06 Tundra DC
http://f-o-a.com
Old 03-09-2011, 04:49 PM   #10 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
I've used a roller with the Hammerite paint and it comes out nicely. Can you get the Rustoleum Hammered in cans? I've only seen it in spray cans.
GET INVOLVED - Join the Blue Ribbon Coalition
SIGN THE PETITION - SAVETHEHAMMERS - #85
'93 Chevrolet 6.5TD K2500 NV4500 Std. Cab Longbed 170K
'85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild)
PAToyota is offline   Reply With Quote
Old 03-09-2011, 06:18 PM   #11 (permalink)
Member # 182470
yeah you can get it in a qt, lowes, hoem depot, and wal mart all have it
Old 03-10-2011, 06:47 AM   #12 (permalink)
Member # 22501
X2 thin 50:50 acetone I tried 10% and had to remove the whole thing and start over.
1968 Baha Bug with 2.2 ecotec motor 170 hp, king coil-overs,etc
1998.5 Dodge 2500 4x4 Cummins
Ed ke6bnl is offline   Reply With Quote
Old 03-10-2011, 10:25 AM   #13 (permalink)
Member # 7876
Yup!
Sounds good, I'll have to give it a shot! No put intended.
Old 03-10-2011, 05:43 PM   #14 (permalink)
Member # 52710
Thin with Xylene only (read the can), and use any type of sprayer you want. It goes on just fine. I did my axles that way.
Slowly building:
[url]http://pirate4x4.com/forum/showthread.php?t=530478[/url]
jpmassey is offline   Reply With Quote
Old 03-10-2011, 07:34 PM   #15 (permalink)
Member # 144203
Xylene is hard to get in some areas. I know I can't find it around here so I use acetone and it works fine.
1987 s10 blazer with way too much work done to it and way to much left to do.
neo71665 is offline   Reply With Quote
Old 03-11-2011, 05:45 AM   #16 (permalink)
Member # 73188
I also used acetone,
Old 03-11-2011, 07:10 AM   #17 (permalink)
Member # 7876
Xylene is available everywhere around here, so I'll just use what is recommended.
Old 03-11-2011, 07:24 AM   #18 (permalink)
85f150dsel's Avatar
Member # 43079
Yep it was in the same isle at Lowes when I picked it up
smileysarmory.com
85f150dsel is offline   Reply With Quote
Old 03-11-2011, 10:04 AM   #19 (permalink)
Member # 182470
well I read the back of a rustoleum satin black qt and it says acetone
Old 03-11-2011, 10:05 AM   #20 (permalink)
Member # 182470
well I read the back of a rustoleum satin black qt and it says acetone :mad3
BTW anyone have pics of it after spraying
