Mr. DJ
Member # 85595
I have a ball joint removal kit but it sucks. I'd like to find something that has a inch and three eighths hole in it that is solid mounted. I'm thinking about just having the sleeve that I use with the ball joint tool now welded on. And yes I know, Hammer, socket, vice... But I want something to use on the trail.
MY BUILD ![]() http://pirate4x4.com/forum/showthread.php?t=748821 BUY MY JEEP!!! http://www.pirate4x4.com/forum/vehic...tml?highlight= |
Member # 9994
http://www.amazon.com/OTC-7249-U-Joi.../dp/B0002SRGXY
sounds like you need something like this. what brand is your ball joint kit? i have the OTC kit and it is great. I also have the HF ball joint adapter kit that works well with it. for u-joints, the HF ball joint kit may be OK, and then you could weld whatever you wanted to it.
1984 CJ-8 1986 CJ-7 1981/1992 CJYJ 1994 RAM 1500 4x4 Custom Fabrication Parts: [url]www.troutindustries.com[/url] Last edited by jeepnmatt; 04-05-2011 at 05:27 AM. |
What!? I'm deaf!
Member # 140878
I as well may want to say use HF ball joint kit and just modiify it as you like, like weld the correct adapter on it and weld something to the "C" to mount in the hitch or something to make it stable as you beat on it.
You can't say that you have wheeled hard till you have broken something or gotten stuck.
#4 (permalink) | |
skullfuckery
Member # 29016
$$$$700 from snap on but worth every penny. their new ball joint tool hase locking snap rings so that every adapter clips on to the cframe, the frame is bigger, it has a pin or a flat clip ring head for the screw, and the cframe has a flat spot in the back so it easinly mounts in a bench vice. http://buy1.snapon.com/catalog/item....re&dir=catalog then there is 2 more interchangable head that you can buy, one of with is fuckin perfect for 1480/1485 ujoints in axle shafts.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
Member # 83837
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60/70HD - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 37" Cut & Grooved Boggers Bronco Build Thread |
#6 (permalink) | |
Member # 86582
Mr. DJ
Member # 85595
Air hammer worked wonders tonight. I'd still like some thing for the trail. I'll stop the Snap On man next week.
Wannabe
Member # 3235
The Tiger Tool is the best thing I've used to remove ujoints
YouTube - 10102 - Tiger Tool Heavy Duty U Joint Puller
Jon B. '82 CJ7 some mods. There is no replacement for displacement! |
#9 (permalink) | |
Member # 150595
Price is way better than the Snap On one. http://www.tigertool.com/index.cfm?m...7-05108cd19bf2 Nat
Nat_sters Haul All [url]http://www.pirate4x4.com/forum/showthread.php?t=1004576[/url] Last edited by nat_ster; 04-06-2011 at 01:19 AM. |
#10 (permalink) | |
Wannabe
Member # 3235
Their light truck stuff is all on this page: http://www.tigertool.com/Products/Au...riveline-Tools
Jon B. '82 CJ7 some mods. There is no replacement for displacement! Last edited by J Bruce; 04-06-2011 at 01:24 AM. |
#12 (permalink) |
Member # 99055
maybe stupid question..but why doesn't anybody use the old bench top vice, and socket?
dont have to worry about juggling anything. stick it in the vice, and go to town. no need to worry about setting up tools |
#13 (permalink) |
skullfuckery
Member # 29016
go for it.
and after you spend 1hr shooting the socket across the shop, reseting the axle shaft after every 3-4 whacks, chewing the axle shaft up with the jaws of the vice, and mashing your fingers or getting shrapnel shot into your hand from the socket chipping off or you steel slug shrooming over you understand why. socket trick works good on new ish joints that arent rusted in, but after a few years its a different story.
#14 (permalink) |
Member # 71185
For years I've used a torch to blow the center of the cross out then just tap the caps in, works very well with the rusted crap we get here, sometimes you can't even tell if the c-clips are there or not. I have been wondering recently though if the heat that the axle shaft sees may cause weakness.
That tigertool setup looks pretty nice, I see they have a removal/install combo that looks like it would handle about any issue, might have to get me one. |
#15 (permalink) |
Member # 187806
Hi Everyone,
Our website developer informed me that we were seeing a lot of hits generated from this post so I wanted to stop by and say hello to you all and if anyone has any questions about our products feel free to ask away. Thanks Kevin Scheer Tiger Tool International Inc |
#16 (permalink) | |
Wannabe
Member # 3235
You should consider signing up for a yellow star (become a supporting Vendor). Your product would be very popular here
Jon B. '82 CJ7 some mods. There is no replacement for displacement! Last edited by J Bruce; 04-07-2011 at 04:48 PM. |
#17 (permalink) |
Member # 132811
This guy speaks the truth. That tool would be a life saver on the trail.
1979 Bronco 390 swap c6 in process. Last edited by oldschoolrides; 04-08-2011 at 04:03 AM. |
#18 (permalink) |
The only issue I had with the tigertool was when I had the caps froze in a little too much and the flange was broken instead of the caps coming off. Mostly my own fault for not paying more attention to the caps. I just kept hammering on them with the impact.
2009 RWE Buggy - Lots of broken parts Nice house in Wichita, KS for sale. Big garage and many updates. |
#19 (permalink) | |
Member # 187806
I will look into this as we work with a few other 4x4 forums and have pretty good results. Kevin |
