Conversion of my JD2 model 3 to air/hydro and engine stand mount - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-25-2011, 01:29 PM   #1 (permalink)
Member # 7876
Send a message via AIM to Arya Ebrahimi
Figured I'd throw up a few pics of the air/hydro conversion I built for my JD2 and the engine stand mount I put together. Nothing new or ground breaking, just my interpretation of ideas I've seen in the past.
I gotta say, I never would have had the patience to pull this off without my Torchmate. The ability to rapidly prototype and re-prototype parts has completely changed the level of quality I can put into my projects while saving me huge amounts of time. And no, I'm not associated with Torchmate, just LOVE the machine.
DD/Tow-rig: '06 GMC Sierra 2500HD Duramax
Classic Rig: '88 FJ62, 100% stock
In the weeds waiting for resurrection: '94 FZJ80, 33s, locked
Arya Ebrahimi is offline   Reply With Quote
Old 06-25-2011, 01:32 PM   #2 (permalink)
Member # 7876
Here are a few detailed pics of the mount to the stand, the ram mount and the die rack.
I added the die rack at the end of the that leg to serve as ballast. The stand was very unstable without any ballast and I feared it would fall over at a very inopportune moment if I didn't do something to stabilize it.
The rack is welded to a piece of receiver tubing so it slides up and down that leg. I did that for two reasons, I wanted to be able to make it as compact as possible for storage, but more importantly I wanted to be able to use this as an engine stand in the future if the need arose.
Old 06-25-2011, 01:57 PM   #3 (permalink)
Member # 96014
Are you able to bend tube with the bender in the vertical and horizontal postion? It looks like in the down postion the tube isn't horizontal.
V
The American Indians found out what happens when you don't control imagration.
Milky is offline   Reply With Quote
Old 06-25-2011, 02:05 PM   #4 (permalink)
Member # 7876
V
Yes, it works in both the horizontal position as well as vertically. I've always used it horizontally due it being manually operated. I'm looking forward to using it vertically.
It will just barely do 90* if the spring back isn't too bad before I have to repin the die.
Old 06-25-2011, 04:48 PM   #5 (permalink)
White Trash Fab
smewhtguy's Avatar
Member # 100827
Send a message via AIM to smewhtguy
Are you interested in cutting me out just the pieces for the ram clamp?
"If you are gonna live life on the edge you better have good balance"
06 Tundra DC
The "Trifecta" 3 seat yota buggy
http://pirate4x4.com/forum/showthread.php?t=1027210
http://www.AddictedOffroad.com/
www.ruffstuffspecialties.com
http://f-o-a.com
smewhtguy is offline   Reply With Quote
Old 06-25-2011, 05:23 PM   #6 (permalink)
Member # 7876
What exactly would you want? Just the 1/4" plate pieces for the clamp? or the sleeves for the bolts, the bolts themselves, etc?
Old 06-25-2011, 05:40 PM   #7 (permalink)
White Trash Fab
smewhtguy's Avatar
Member # 100827
All the parts except the bolts and little tubes, in the second pic post 2. I want to change my homemade setup to go both verti and hori and get more bend on a repin current setup only goes 60 deg before having to repin.
06 Tundra DC
http://f-o-a.com
