Harbor Freight Mini mill #44991 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-11-2011, 10:41 PM   #1 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
ya I know but its a fawking Seig X2 clone the same as the one from grizzly, wholesale tool and everyone else. Just better shipping charges and a R8 collet.
So can anyone else think of a PORTABLE mill for doing gunsmithing work for $600ish? Advice on this SIZE mill?
I want this to become my "inside" mill for doing shit like milling dovetails, sights and small gunsmithing work with nothing over a 1/2" endmill.
I see littlemachineshop offers thier what I can assume "modified" version of it with a belt drive and brushless http://littlemachineshop.com/3900 but is it worth it plus shipping? Eventualy I was going to convert the HF unit to belt drive but who knows.
also advice on the cheapest for sets of collets/endmills? Its been a while since I had to buy my own
Thanks
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 12:57 AM   #2 (permalink)
Member # 2143
http://www.shars.com
Shars.com for the collet sets
as far as the chinese mini mills go they all need a little tweaking for accuracy anyways... mostly the "nicer" ones just have a better bondo job on the castings and shiny paint
if you have to pull it apart and clean the sand out of the spindle bearings and deburr the gibs you might as well pay less for the iron
AIRZUKI is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 04:20 AM   #3 (permalink)
86 slo-vo's Avatar
Member # 148322
my buddy bought one, brought it home, chucked a piece of steel in, and took it back.
he said it was terrible, fresh out of the box it was a piece of junk. (an he like i are always buying HF)
94 ranger, d35 8.8, 4.10's detroit locker/truetrac, duff long arm, chevy 63's 36 sx's
86 slo-vo is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 04:35 AM   #4 (permalink)
Member # 190591
Aww, its cute. I dont know how much actual milling you plan to do with it, but I would have my doubts about how well that thing would handle a 1/2" endmill. Kinda of suprising that has an R8 considing its size.
smythfarm is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 08:30 AM   #5 (permalink)
Member # 108445
Mini-lathe/mini-mill page
http://groups.yahoo.com/group/GrizHFMinimill/
(there are many mini mill yahoo groups, but most have <50 posts/month, effectively dead)
rocket flier is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 11:50 AM   #6 (permalink)
Member # 87941
Given the need for portability, I might be tempted to go with these over the HF piece - http://www.sherlinedirect.com/index....&category_id=2
If you can get past that need, an old knee mill for the same price will be an infinitely better machine.
DILYSI Dave is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 12:13 PM   #7 (permalink)
BigBlue&Goldie's Avatar
Member # 113019
I have the Micromark version (I think it has different X,Y graduations than the HF), and it's great for doing light work on guns. I purchased it used on Craigslist in mint condition for around $300 or $400. I use it for drilling small holes in hardened pieces with carbide bits and for drilling precise patterns. I also use it to chuck pieces up for polishing (guide rods, pins, etc.). I'm also going to start using it for trimming brass once I get the proper shit.
I have never used it for milling as I don't believe it is rigid enough to mill through hardened steel (like dovetails for sights), but I could be wrong. Overall, I like the mill, but if I was going to be using it for any serious gunsmithing work, I would upgrade to a full size unit. It's not a precision mill, but it beats the shit out of a drill press becuase of the table.
BigBlue&Goldie is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 12:14 PM   #8 (permalink)
Member # 46175
I just got rid of an old "Benchcraft" mill that was pretty nice for its size. Try to find one of those instead. Heavy as hell and will last a lifetime.
http://i102.photobucket.com/albums/m...ullfrontal.jpg
They are rare, but might be worth tracking down.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST
Specializing in Axles and Transfercases
Mh4Runner is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 12:20 PM   #9 (permalink)
Member # 12499
Spend a little more and get a real mill/drill.
PTSchram is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 01:25 PM   #10 (permalink)
billybob_81067's Avatar
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
I got one from Homier (parking lot truck sale) it was only like $300 bucks. It's alright for what it is. I did change it over to belt drive with the kit from littlemachineshop.com and added the gas cylinder lift upgrade too. Also put some epoxy in the column and built a big thick washer for the back of the column where it swivels to spread the load from the nut over a wider area. Most of these upgrades are mentioned on that yahoo group posted above.
I have used mine quite a bit for different random crap. Most the time when I am facing something I use a carbide insert face mill type tool that's about 1.25" and it works great.
Just don't go making huge cuts and hogging stuff out... Take your time and it'll do pretty well! Works really well on plastic and pretty good on aluminum. Steel can be a slow process sometimes. Drilling anything larger than about a half inch hole is pretty much annoying as hell cause you will overload the motor protection and have to reset it a hundred times to get through.
I think they are pretty hard to beat for gunsmithing and other small stuff. I have used mine for r/c cars and paintball related stuff a lot.
billybob_81067 is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 01:32 PM   #11 (permalink)
Member # 52710
I wouldn't let a gun anywhere near that thing. I consider a 'mini' mill something like a Powermatic.
Slowly building:
jpmassey is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 01:45 PM   #12 (permalink)
Member # 103610
Send a message via AIM to jeep937
Don't do it!!!!!!!
jeep937 is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 02:41 PM   #13 (permalink)
usmcdoc14's Avatar
Member # 13344
Ok, READ the post please
Small mill, PORTABLE, that means under 300lbs ish. Around $600 bucks.
If i am spending more than that i am buying a REAL mill, used, from a wide assortment of places. If i am buying a mill larger than that and i will be getting a full size mill, not a halfway inbetween.
Small, benchtop mill.
People are making these cnc, they cant suck that bad
Old 08-12-2011, 03:08 PM   #14 (permalink)
Member # 29644
Send a message via AIM to 71Dauntless
I know you only want to spend $600 but this one is slightly more and is getting pretty good reviews. Its also pretty easy to convert to a 3 axis CNC machine. R-8 taper and VFD included and its 290 lbs.
http://www.grizzly.com/products/Dril...th-Stand/G0704
1971 CJ5
2006 Toyota Tundra
71Dauntless is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 03:17 PM   #15 (permalink)
D60
Member # 6398
Uh huh, and what are they running for feed rates, depth of cut, and in what material?
Even smaller dovetails get into a lot of tool contact in a hurry. Have others done this with this unit?
R8 collets, $65 for the set, comes with the rotary holder which I think is kinda handy:
http://www.use-enco.com/CGI/INSRIT?P...PARTPG=INLMK32
fscaug will get you free shipping
You know it gets better, so of course it gets worse.
D60 is offline   Reply With Quote Quick reply to this message
Old 08-13-2011, 01:03 AM   #16 (permalink)
Hate keeps me warm
Grumpy356's Avatar
Member # 151139
Have you considered an old Unimat sl 100 or db 200 or are they to small?
I have one, they come on a nice wood box and for small jobs ( and I do mean small) they are cool.
Mass quantities of anxiety, internal conflict and discontent, all balled up in one short, tattooed body.
Grumpy356 is offline   Reply With Quote Quick reply to this message
Old 08-13-2011, 11:28 AM   #17 (permalink)
Member # 12499
I'm the first one to counter the argument to buy American old iron for a number of reasons, but in this case, I think it's gonna be too small to be of any real use.
Harbor Freight used to sell a glorified drill press with R-8 spindle and draw bar that was way better than those tiny little toys. Sadly, I'm afraid they've discontinued them, but that would be a good compromise between a tiny little toy and a 1000# mill/drill and the price would likely be close.
When cutting dovetails, that thing would either bog down, or have to cut so slowly that you'd be better with a file and hacksaw.
edit-the one I'm referring to is listed on this page, scroll down a bit. http://www.mini-lathe.com/Mini_mill/...s/versions.htm it's the HF 33686
Old 08-13-2011, 04:26 PM   #18 (permalink)
usmcdoc14's Avatar
Member # 13344
dammit...
save more money and suck it up and wait
Old 08-14-2011, 08:48 AM   #19 (permalink)
Member # 12499
dammit...
'tis better to have $ in the bank for when a good one comes along than not have $ and be pissed off at what you bought.
Old 08-14-2011, 09:20 PM   #20 (permalink)
usmcdoc14's Avatar
Member # 13344
what about this?
http://sandiego.craigslist.org/csd/tls/2545850216.html
(btw, please no one be a dick and snatch it from under me )
what is it a clone of and what price should I offer this dude?
Old 08-14-2011, 09:44 PM   #21 (permalink)
Member # 113019
what about this?
Thanks, I picked it up this morning!
On a more serious note, that would be light years ahead of the mini mill.
Old 08-14-2011, 10:04 PM   #22 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
what about this?
Much better than anything HF has to offer...
edit- and I wouldnt pay more than $600 IF I was wanting something that size..
Azzy2000 is offline   Reply With Quote Quick reply to this message
Old 08-14-2011, 10:17 PM   #23 (permalink)
Member # 108445
I was going to say 6-800 depending on the area
See:
http://www.grizzly.com/products/2-HP-Mill-Drill/G1006
http://www.use-enco.com/CGI/INSRIT?P...&PARTPG=INLMK3
http://www.amazon.com/350017-JMD-15-...ata/B0009H5TA0
Magna Mill Drill small shop home shop mill drill from Industrial machinery - YouTube
{edit} HF one:
http://www.harborfreight.com/1-1-2-h...ine-33686.html
Old 08-15-2011, 11:09 AM   #24 (permalink)
usmcdoc14's Avatar
Member # 13344
dude wants 1200, ya fuck that. I can get a new unit with support for that cash
Old 08-15-2011, 11:36 AM   #25 (permalink)
Member # 12499
what about this?
Weighs close to 700 pounds, is that portable enough for you?
Those are pretty rare to see used as everyone that has one has three or fifty friends who either want to use it in their shop, or buy it when they're ready to sell. Around here, used they sell for as much as brand new although I did find one yesterday for $600. No, I'm not saying a word about its location as I'm waiting for a check so I can go pick it up!
The round column is less desirable than the square column as it's difficult to keep the head true if you move the head up and down much, but it's a huge PITA to move the head up and down so most leave them put.
Edit-H-F sells damned near the same thing, as does Enco, Wholesale Tool, Homier, etc. If you want a good one, get a Rong-Fu. Yeah, I know, who'd think with a name like that it would be any good?
