Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Land Rover
Thread Tools Display Modes
Old 11-07-2009, 07:37 PM   #51
mdlimy55
Member # 144332
Send a message via AIM to mdlimy55
But are there any passenger off set rear toyota axles other than fj axles?
89 range rover, lt230 swap, currently linking and swapping d44s.
mdlimy55 is offline   Reply With Quote
Old 11-07-2009, 09:23 PM   #52
Buckon37s
Buckon37s's Avatar
Member # 20394
This is against my better judgement, but I am going to offer advice anyway. The path you are currently on is fubar. In order to get the axle to stuff, or even to link it properly, you are going to have to torch most the truss off and near start over.
Then once you do that and you fill those 44's completely full of chromoly, not only will you have an expensive axle, but ones that are on the edge of breaking on you're 36in tires. I know you have posted several times that you will not break it because you don't push things. Then why do this in the first place?
And finally, the ONLY thing that a 44 does better than a toy is turn sharper, but with you're 1in skinnier axles and 36in tires, you will need to run a 4in spacer to get a decent turning radius. Then the inner C will break. Yea!
Sell them. Maybe you can find a flat biller to buy them. Go to the junk yard and buy a 60 for the rear. Run it stock. You can get one for $250-$300 If you look around for it. Don't even bother with the passenger side drop, it doesn't matter. But with your shop, cutting it down would be easy if you wanted to. Then for the front leave the stock rover axle on there and stuff it with Toy stuff from Keith.
This option will run cheaper than the path you're on and be way stronger. And WAY less gay.
Or, keep doing what you're doing, post up lots of pics, and we'll flame you relentlessly. One is a win for you, the other is a win for us. Cheers.
2009 King of the Hammers
BUCK Wild Racing
Team 911
Driver: Me
Co-Driver: Pat Quirk
Rover Tracks www.rovertracks.com
PSC www.racesteering.com
DJ Safety www.djsafety.com
West Coast Rovers www.westcoastrovers.com
Spidertrax www.spidertrax.com
JE Reel www.reeldriveline.com
Buckon37s is offline   Reply With Quote
Old 11-08-2009, 10:33 AM   #53
PTSchram
Member # 12499
Location: In the office writing letters to Land Rover's attorney, trying to stay in business,
The question that has not been asked yet is what's wrong with what's under the truck now?
Why not just convert to 24-spline and wheel it like a Rental car with the damage waiver paid?
The early Rangies have plenty of room for tires with minimal if any lift. It already has the 230, yadda, yadda, yadda.
Stuff it with 24 spline stuff and break it, THEN make big changes.
Wrenchin' to riches!
PTSchram is offline   Reply With Quote
Old 11-08-2009, 05:47 PM   #54
BigBlueToy
Member # 88052
Th sad part is how much time and steel went into ruining a perfectly good set of Dana 44s
Wheel it stock til shit starts breaking, then do what Buck said.
BigBlueToy is offline   Reply With Quote
Old 11-09-2009, 11:59 PM   #55
Grimace
Member # 27639
Back on topic - 3" front and 4" rear springs. Works a treat for me!
DONATIONS WELCOME ! ! !
Grimace is offline   Reply With Quote
Old 11-10-2009, 12:59 AM   #56
mdlimy55
Member # 144332
thank you, always admired youre 2 white rangies. what else goes along with the springs?
Old 11-10-2009, 03:41 AM   #57
Micka
Member # 56916
3" springs and 1.5" body lift with 37" Creepies.
GET HAMMERED!
Rock Hammer Racing [url]www.rockhammerracing.com[/url]
Micka is offline   Reply With Quote
Old 11-10-2009, 11:44 AM   #58
mongosd2
Member # 16003
3" lift overall...
it's a land rover, what did you expect...
01 D2 FZJ80 axles ARB/Detroit 37" Iroks, 14" 9100 Coilovers 14" 9100 rear 1.6 lt230 PSC hydro steering and a suspension built by me with parts and pieces from BallisticFabrication.com
96 D1...stock
mongosd2 is offline   Reply With Quote
Old 11-10-2009, 03:34 PM   #59
BigBlueToy
Member # 88052
I ve got slight wheel arch trimming for 9.00-r16s, But my FFR D90 already has beefier springs than a civvy truck. Coil sprung land rovers only need a slight boost to clear serious rubber. Unless its a Disco or Rangie with sacked springs! But thats more of wear and tear issue.
Old 11-11-2009, 10:46 PM   #60
Grimace
Member # 27639
Thanks!
I fitted rovertym rear links & raised rear shock mounts. I also have a 2" ball joint spacer fitted to the aframe.
I originally ordered more rovertym gear but unfortunately I got messed around a bit (irrelevant story), so I ended up with some custom made front radius arms cranked by Dale @ 2DExtreme.
Extended brake lines are a must, as well as extended bump stops. The guards needed a lot of clearing and the tyres still rub hard (but I like it like that )
I also sourced some double cardon driveshafts (front and rear) from Tom Woods as I had slight vibrations at certain speeds when on the black top.
At the moment I am running 10" front bilsteins (a touch too short), and some cheap Boss 14" (almost) travel shocks in the rear (a touch too big).
The front flex is aided by the haultech holey bushes.
Spring rates are 220lb front (lovells RRR-03) and 186lb rear (dobinson unknowns), I initially thought the 186lb rears would be way too soft but they actually seem to be holding up quiet well. Springs are held in by heavey duty lower retainers and hose clamps to retain the tops, I am a big fan of retained springs.
Things to come are a 1" body lift (to get me back some of my lost uptravel), and some 7100 series short body billys (12" front and 14' rear). Maybe some 30mm wheel spacers, and am currently looking for some sticky compound treads.
Old 11-11-2009, 11:47 PM   #61
michaels
Member # 99425
(14' rear)
shoot for the stars! what kind of springs and cutting you running to fit those.
michaels is offline   Reply With Quote
Old 11-12-2009, 03:58 PM   #62
Grimace
Member # 27639
Read the rest of the post, I even have a picture in my original post just for the illiterate child in all of us !
I got sick of my shocks limiting my down travel, now they just limit my up travel along with my tyres
I don't do any jumping or high speed work so it's fine... for now. .
Old 11-12-2009, 04:46 PM   #63
williambrea
Member # 141589
Im sitting right now with a 1inch body lift and a 2 inch RTE lift with ome shocks
This is a meh flex shot, ive taken it higher but this is what I have on my photobucket
williambrea is offline   Reply With Quote
Old 11-12-2009, 05:24 PM   #64
michaels
Member # 99425
lol. i was commenting on your typo. 14 foot rear shocks! wow!
there does that help you old man?or maybe i should buy you some bifocals!
Old 11-12-2009, 05:36 PM   #65
BigBlueToy
Member # 88052
Thanks!
... Springs are held in by heavey duty lower retainers and hose clamps to retain the tops, I am a big fan of retained springs.
I am a big fan of hose clamps!!!
...and duct tape, and bailing wire. The well stocked Rover tool box should never be without these items!
Old 11-12-2009, 06:17 PM   #66
michaels
Member # 99425
i use hose clamps and zip ties.
Old 11-12-2009, 06:59 PM   #67
Grimace
Member # 27639
I thought you were commenting on the current boss shocks so didnt see the typo!
Now where am I gonna find some 14 foot shocks!
Most definately, I have run out of bailing wire. Forgot to replace it last time I used it to brace a bent rear link.
I have millions of these in my toolkit. Never know when your gonna need zipcuffs and some cawk rings!
Old 11-19-2009, 07:31 PM   #68
rover4x4
Member # 14681
Send a message via AIM to rover4x4 Send a message via Yahoo to rover4x4
How are those MTR's?
uh........
rover4x4 is offline   Reply With Quote
Old 11-20-2009, 07:07 PM   #69
BigBlueToy
Member # 88052
ouch!!!!
Old 11-20-2009, 07:09 PM   #70
BigBlueToy
Member # 88052
Need some advice, who sells the best 3 inch springs and shocks for a D90?
I dont haul much in it, I want flexy, but not slinkys. My homemade Ghetto lift is getting old.
Old Yesterday, 06:35 AM   #71
Kyle_T
Member # 69765
rears? look at the RRC Police red/whites for the rear. fronts, well i dont know.
~ Kyle
1999 Land Rover Discovery II - Lift, Tires, Stuff.
Kyle_T is offline   Reply With Quote
