#1 |
Member # 88131
im looking to get rid of my stock carburetor from the strait 6 f motor on my fj40 and im thinking about geting a holly for it but what kinde should i get? i have a friend that has a holly 400 on his fj40 and likes it, but i would like to no what other people have on theres and what they like or do not like about it. im planning on haveing it as a light wheeler and a DD.
#2 |
Member # 105563
go with the downey tbi conversion. Increased milage,hp, and torque . Nor do they flood on extreme angles.
#3 |
Member # 10429
The best carb has fuel injectors sticking out of it.
q-jet is a distant second, with everything else behind it.
Rich Q. FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/42's |
#4 |
Member # 263
Aisin carbs are very well engineered for the vehicle. I would just rebuild it.
BTW, welcome Noob ![]() Phil
1966 FJ45 LPB 1973 FJ40, beeropener http://www.mta4x4.com TLCA Chapter Delegate, TLCA#9166 Increasing my post numbers one pad at a time... Support the innovators of our sport, buy from Marlin Crawler http://www.marlincrawler.com Last edited by PJohnson; 04-10-2008 at 08:41 AM. |
#5 |
Desert Rat
Member # 27432
There are places on the web where you can post up that you are willing to trade your Aisan carb for an aftermarket and you will get plenty of offers for just about any aftermarket carb you desire. Makes you stop to wonder what they know that you don't.
MarksOffRoad.net Originally Posted by lc tpi ...if I have to buy them from Trail Gear I guess I dont need them. 65SWB45, 64LWB45, 68FJ40, 72VJ40, 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer tlca #1086 member: Trail Crew-L.A. TLCA, Elwood Chapter, TLCA |
#6 |
Member # 104239
With the stock 6 I liked the weber, i have heard a lot of things on the Holley if you drop the float 1/8 and extend the overflow at a 90 that it is a great carb also. I was just told that by a few people dont really know from experience though.
1978 FJ40,383 stroker, 350,205,corp 14,dana 60 detroits 5.13's 42" Irocs, and a little tubing. 1971 FJ55,om617,sm420 in the process 2004 F250 http://www.delalbright.com/Rubicon/buy.htm http://www.sharetrails.org/ |
#7 | |
4X4HIM.COM
Member # 34369
Holley carbs SUCK on a wheeler... Period...
![]() ![]() ![]() ![]() If you want to have your carb rebuilt and made to work the way Toyota intended it call this guy; http://www.marksoffroad.net/index2.html Chris
#8 |
Super Moderator
For performance, I like the weber 38mm, but it'll cost you over $400 to get started, then it'll rape you at the gas pump. I've retrofitted a couple Motorcraft 2bl's on F engines with very good results, you can pick them rebuilt from you're local parts house for under a $100 and either use a Holley adapter or make you're own. Motorcrafts work as good as quadrajets off road, and you can get them in the 350 cfm range unlike a quadrajet which I think is more like 600-750 cfm.
Jeff Fretwell |
#9 | |
Member # 1926
'69 FJ40 with very few stock parts. 2000 Cummins with some goodies to make it smoke..... Trail Gear's Bad Ethics=Bad Business. |
#10 |
Trail Riding Life
Member # 16988
I had a Weber.... ate fuel like crazy.
Stock ran well and worked well offroad once rebuilt (went this route a couple times from Marks and Jim C.).... overall, a great choice. Then I got a diesel and... ![]() I had the downey EFI kit... PO installed it, didn't idle right, I could not get it right.... Consider a a 3FE FI conversion from junkyard stuff... intake, sensors, air intake, fuel pump and computer...not 100% sure it would work on an F but 2F is documented. Have any pics of yer 40? I could opinionate moreif I saw it
#11 |
Webber 38 runs great once you tweek them, they are almost always jetted too rich, i stepped mine down a bunch, but I am also a mile high. Milage was good the last time I drove it on the road. You need to drop the float level so they don't flood at angles, and breather extensions are a good idea also although I have yet to do that.
The stock carbs work very well when in good condition, they are a bit more complex though. Getting your stock unit rebuilt by a pro is your best bet.
1970 FJ40 rollin on foDees! HOMEGROWN |
#12 |
Member # 14712
[quote=wayneraintree;8125073]
Consider a a 3FE FI conversion from junkyard stuff... intake, sensors, air intake, fuel pump and computer...not 100% sure it would work on an F but 2F is documented.[quote] Any links to some threads on a N/A Fuel Injected 2F using 3FE stuff??
Needed: Volvo chromo portal gears |
#13 | |
Trail Riding Life
Member # 16988
[quote=Killerpee;8125374][quote=wayneraintree;8125073]
Consider a a 3FE FI conversion from junkyard stuff... intake, sensors, air intake, fuel pump and computer...not 100% sure it would work on an F but 2F is documented. Quote:
Here is the article from Toyota Trails: 2005 J/A Arron Thompson FJ62, Version 2F-E MUD thread with a whirrlllllllll http://forum.ih8mud.com/40-55-series...o-my-fj40.htmlmore Pirate cruiser discussion: http://pirate4x4.com/forum/showthrea...&highlight=2FE |
#14 |
Trail Riding Life
Member # 16988
http://forum.ih8mud.com/40-55-series...king-2f-e.html
more discussion: looks like you need later 2F flat top piston, just one of a few issues to address... |
