#1 |
Member # 4157
OBA for the cheap bastard
I'm trying to finish my oba project for the least amount of cash possible.
Here is what I've done so far: 1. Pulled a york at the junkyard: $20.00 2. Machined the double-v pulley to fit my serpentine belt. $0.00 3. Built the mounting bracket out of a scrap piece of stainless 'cause I'm too cheap to paint it. $0.00 4. Had to remove my air-box to make room for the york, so I cut the factory air-tube and slapped on a conical filter. $38.00 (splash guard coming soon). I've also searched the archives and found out that instead of buying Kilby's 1/2"npt replacement flanges for $25 that I can just remove the flanges and tap the inlet/outlet ports with 3/8"npt and use a 3/8"npt elbow. That should cost $6 including the tap. I'm also looking for an air-brake-tank to use as a tank. Anyone know of a big-rig wrecking yard in the Portland area that I could get one from? What other cheap solutions or suppliers have you found for your oba project?
that sound is normal...don't worry about it. |
#2 |
Member # 6425
wow.........
hey dude tell me , when you walk do you squeek real bad?
THERE'S ONLY ONE TJ-7 |
| Sponsored Links |
#3 |
Member # 2290
pinch a penny til it screams!!!
Jackass Wheelers |
#4 |
Member # 4157
While we are on the topic of cheap bastards...I see that neither of you wasted any time putting in for this month's free driveline.
Enough chit-chat...how about some tech.
#5 |
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1874973098
Here ya go I found a couple on ebay but none of them at a good price
#36. If I wanted to drive a foreign 4x I would move to another country. 80 cj 5 104" wb rockwell 16"kings 39.5 tsl AND 1995 Hummer H1 Wagon buy my stuff |
#6 |
or how bout one of these $12
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2080187561
#7 |
Member # 9739
Plumbing you tank is going to double your costs.
one-way check valve, shut-off switch, safety valve, hose, fittings,inlet filter,oil separator Yep, costs will double but you will have spent a lot less than others have.
95 YJ, 37" that look smaller every day all powered by 4 Squirrels in a cast iron cage. --colorado4x4.org-- |
| Thread Tools | |
| Display Modes | |
