Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Jeep - Hardcore Tech
Old 11-13-2001, 02:07 PM   #1
olivesman
Member # 3964
jeep t18 main shaft into a ford t18
here's the ? has anyone ever attempted putting a jeep truck t18 main into a ford t18? i am asking b/c i really don't want to have to buy the AA kit for my ford t18 (going into my cj) in order to bolt up the jee d20 transfercase. the jeep t18 is from a '76, but i'm not sure about the ford.
thanks a lot- russel
<>< GoAgainstTheFlow
76 CJ7 project- complete change in plans..........2 years in the making and it don't even roll yet.......
olivesman is offline   Reply With Quote
Old 11-14-2001, 01:04 AM   #2
Sillyneck
Pirate4x4 Addict!
Sillyneck's Avatar
Member # 517
Send a message via ICQ to Sillyneck Send a message via AIM to Sillyneck Send a message via Yahoo to Sillyneck
why swap them at all? the bolt patterns should be the same at the front. If some next level sh!t is going on then yea the jeep shaft will happily go into the t-18....all the cases should have been the same, and as long as they were both wide ratio I can't see any reason for a difference. There were 13 or 14 different 18's created...long and short snout, input out put, wide, close ratio, but the case remained the same as far as I know.
www.myspace.com/sillyneck
www.sillyfabservice.com
www.rockzombies4x4.com
ECV 7-11
ROCKZOMBIE
Sillyfab- FREE SHIRT WITH ANY PURCHASE OVER 1 MILLION DOLLARS 916 635 3485
Sillyneck is offline   Reply With Quote
Old 11-14-2001, 03:01 AM   #3
ozarkjeep
Member # 695
do you already have teh Jeep T18 mainshaft?
it seems that would be pretty hard to find, by itsef at least.
either way it should swap if both are wide ratio, and the same reverse pattern
too small to be seen, and too big to control, and treated like a walking bomb...
ozarkjeep is offline   Reply With Quote
Old 11-14-2001, 10:04 AM   #4
Grandpa Jeep
Grandpa Jeep's Avatar
Member # 1868
Send a message via MSN to Grandpa Jeep
Do you have the complete Jeep T-18? If so, I would put the Ford input shaft in that. It's a lot easier to swap the input shaft than the output shaft, and the Jeep case will already be drilled for the adapter. Also, this may not be a consideration, but the PTO port on the Ford case is on the worng side and would would interfere with the front driveshaft it you use a PTO.
Otherwise, the output shaft should swap just fine as long as it's really a T-18 shaft and not a T-98 shaft.
'50 CJ-3A, SVO Turbo 2.3L, T-98, D18, Warn OD, PTO Winch, D30, FFD44, lockrites in both
Jeeps, they're not just a hobby, they're a freakin adventure :D
:usa:
Grandpa Jeep is offline   Reply With Quote
Old 11-14-2001, 03:13 PM   #5
olivesman
Member # 3964
thanks guys-
yeah, i do have both trannies. and i thik GRANDPA understands exactly what i want. i need to swap them b/c i'm putting a 5.0 in my cj and i want to back it w/ a t18 and since i already have two of them to work w/, i don't want to spend $500 on an adapter for the jeep d20 transfer case i'm going to use. my problem is: the ford t18 will bolt to the motor but not to the transfer case and visa-versa w/ the jeep t18. so, i was hoping i could combine them to get what i need. thanks a lot again guys-russel
Forum Jump
