#1 |
Member # 10290
4 Link critique
I have read ALOT about front 4 links, and have come to this point in my mock up (see pics) Keep in mind that at some point in time perfect placement must be compromised due to pesky items like the engine block, starter, and where to hang a Driveshaft.. Heres a run down... 2x3x .187 frame, 350 TBI,TH350, 203-205 and 404 Mogs on Hummer Rims with 42" swampers.TJ tub and 107" WB. I will be installing Johnny joints on the frame ends of the links (vs the wire ties)
I asked for the critique, lets have it..LINK PICS WEPS
build pics at www.wepsoffroad.com |
#2 |
Member # 10290
| Sponsored Links |
#3 |
Member # 18628
All the anti-squat, weight transfer tech doesn't work for the front axle the same as the rear. From what I have played with that would be a killer rear set up if that's the actual height it will sit at. It should work fine in your front end too but it may dive when you get on the brakes hard. Making the front links more parralel has helped keep mine from diving. If you don't plan on going fast don't worry about it. Weld it up.
#4 |
Member # 10290
Thanks, I can move the top link up a bit more to get it more parallel. I was trying to consider the torque rotation difference of the Portal vs. "regular" axle, and was trying to get some more preload that way... Yes, that is pretty much the set ride height. Top link is 34" lower is 32" vert. separation is "around" 9"
WEPS
build pics at www.wepsoffroad.com Last edited by weps; 06-11-2003 at 09:18 PM. |
#5 |
Member # 9222
side view for all to see.
#6 |
Member # 18671
Looks like a good start. I want to coil my Scout sooooobad but I have a major lack of funds
Oh well when the time is right.Keep on updating.
no sig |
#7 |
Tech Editor
Member # 1656
more separation at the frame will also help keep your steering geometry more correct though the full range of travel. looks good
tinbenders.org For info on the Forumla Toyota and the full tube X chassis. Click here to visit Hendrix Motorsports camo is my hero, even if he is gay DirtChoppers.net |
#8 | ||
Cardboard Killer
Member # 5776
#9 |
Member # 10290
I did some adjusting this a.m., and can easily get the top link horizontal. This may shorten it up to about 32" and be the same (or darn close)to the lowers length. 260 views and no ones kicking me in the bag?
Could it be all of the reading (Including the "god of suspension" thread) is paying off? Come on PIG, and TPIjeep....I'm hoping the day crew will check this out. For me, its bedtime! WEPS
#10 |
Member # 19754
What size tubing did you use? looks beefy.
'57 Ranchero + stroked 460 + 8-71 blower + 24R21's = too bad for the little guys |
#11 |
Member # 2538
This isn't a critique. From what I can tell (admittedly I don't know much about 4 links) it looks kick ass.
I have more of a question/observation. I notice your upper link when veiwed from the side angles down from the axle toward the frame. It sounds like a few of the respondents feel that will cause excessive pinion rotation throught the travel of the suspension. What I've noticed is that John Gilleland's buggy (and the Karnivore copys by Avalanche) do their links the same way, although they look as if the upper link is still angled downward but just not quite as much. So, is this really that bad a setup? Sean |
#12 |
Member # 10290
I was hoping for a few more comments, bringing this back up for the last time before I start making things permanent
Thanks for looking. Links are 1.5" sch 80 (.218 wall)WEPS
#13 | ||
Cardboard Killer
Member # 5776
![]() I don't think .218 would be a thick enough wall for a lower link unless it was at least 2.25" OD. You're probably fine on the uppers.
#14 | |
Low Range Drifter
Member # 7903
2001 TJ Now with 4.7 V8 power : 1975 Wagoneer |
#15 |
Donkey Hunter
This is what happend to my 1.5" sch 80 links the first time I landed hard on a rock....
This is what I did to prevent it from happening again. 3/16" by 1.5" angle. My rear links are made from the same stuff, and with almost two years of runs, I never managed to bend one. Butt, if I ever get a chance to take the lowers off, they will be getting the same treatment as the fronts.
#16 |
2InDaPink&1InDaStink
Member # 4502
Pipe is for poop.
www.POLYPERFORMANCE.com Click the sig for everything you need to build a tube car... 805-783-2060 NEW PRODUCTS ADDED DAILY !!! |
#17 |
Hmmm I usually use a pipe to smoke with PIG, we should probably talk.......
Not sure what kind of Anti-dive you are looking for or AS for that matter, but your vertical sepreation difference between the axle and the frame (if they are mocked up where you are going to leave them) leads me to believe that you are shooting for somewhere over 100%, and it looks like your somewhere in the range of 100 to 125 (guessing) . Personally I might add a little height to that upper controll arm mount at the frame. 9 inches of vert sep at the axle sounds great though. nice job! Ryan Last edited by YeeP; 06-17-2003 at 09:07 PM. |
#18 |
1.5" 1/4" wall DOM just went on our CJ. I'll post up tomorrow with pics. Should be more than strong enough.
In between trucks right now..... |
#19 |
Member # 10290
I kinda like the angle iron addition to the links (or have thought of that too) also "MAY" allow for some more "Slidage" (new word) on an obstacle
Thanks for the Approval, and if PIG only hates the Pipe portion of it, I must be on the right track..... I may just go ahead and use some 1.5-2" DOM for the lowers now. I WILL raise the link up at the frame end so that it IS Parallel. I think that the oil pan to diff clearance looks good, 4" TJ springs for now....... Thanks for the help PBB! WEPS
#20 |
Donkey Hunter
If you made your links from 2" solid 4140, you could still bend them. Pipe works great for those of us that aren't made of money like PIG seems to be.
Make your links out of the 1.5" sch80, then slap a lenght of angle on it, and wheel it. If it bends, go with something heavier/stronger.
#21 | |
Cardboard Killer
Member # 5776
I seriously think my links will be .250 wall *square* tubing with a bushing at the frame end, and a RE joint at the other. Just to piss people off.
Plus, Square is just plain harder to bend than same dia/wall round. It's just not as sexy.
#22 |
Here's what we have going on....all 1/4" wall DOM. Bushings came from POLY:
#23 |
Another:
#24 |
Member # 18222
Rock Toy
That is one hell of a D-Line!
LOL....
Lil slightly modified '88 zook. "Family man's ATV" |
#25 | |
Cardboard Killer
Member # 5776
Do you have a side shot?
| Thread Tools | |
| Display Modes | |
