Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Land Cruiser
Old 01-16-2004, 07:16 AM   #1
Deep South Cruisers
Deep South Cruisers's Avatar
Member # 3514
Arrow El-diablo strikes again - Late to work
the saga continues...
my patience wears thin as I arrived late to work this morning - The first morning I decided to drive my FJ45 to work and it's 28 degrees out side, luck is on my side as she actually fires up in the cold morning air and I realize my booty-fab heater actually works... a little.
Running painfull low on fuel I wheel into the Chevron parking lot to get some go juice and a Mt. Dew, I consider leaving her running for the heat but feeling confident I stall the engine and fill her up. Hell hath no fury like El-Diablo on an outing with me behind the wheel, climbing back into the drivers seat I twist the key only to hear that familiar drag-click associated with a dead $100 Optima battery.
The Cruiser gods surely must have heard my muttering curse words and idle threats as I raised the hood to check connections and confirm what I already knew... I was stranded. CERTAIN that I would face anger and ridicule if I dared to call the wife and drag her out of the sack at 6:00 a.m. to rescue me I sat in the drivers seat and waited for a unsuspecting soul to help me push start the beast.
After only a few minutes I spotted my helper and approached him inside the store, he was happy to help but the rolling start ended with a chirp of the tires and the end of the parking lot. After some discussion he returned from his truck with a used battery and gave it to me! my faith in man restored I wrenched down the battery and fired the engine, I was back on the road.
The rest of the 5 mile ride to work was filled with foul language that would make a sailor blush (as if thinking it wasn't enough) and when I rolled into the parking lot at work I was actually only about 10 minutes late but people were waiting for me, several of my co-workers had been harassing me wanting to see the truck and they came out to the parking lot to check it out.
Standing in the parking lot like a proud papa the compliments started (I smiled through clenched teeth) they had no idea the pain and suffering this truck has caused on every outing! The compliments continued..."never seen one of those" "you should restore it" and then the closer "do you want to sell it"............................................... .................................................. ........................."No" I replied, "I'll keep her" (even if she is an ungrateful bitch )
Jerry Hocutt
I'm Schizophrenic and so am I!
Deep South Cruisers is offline   Reply With Quote
Old 01-16-2004, 07:58 AM   #2
mantis
mantis's Avatar
Member # 13322
Sounds like you could use a beer
Are you keeping a journal of these episodes? After a few years you could probably have a pretty thick book that you could sell to a publisher. You know anything that comes out about cruisers is sure to sell a few hundred copies to us die hard owners.
-mike.
[URL="http://www.wunderground.com/swf/Rapid_Fire.swf?units=both&station=KTXSUGAR4"]My back yard weather[/URL] :cookie:
mantis is offline   Reply With Quote
Old 01-16-2004, 08:08 AM   #3
Deep South Cruisers
Member # 3514
-mike.
PBB is my journal
I might start submitting to TT if they show any interest. I post here so folks can laugh at my pain
Old 01-16-2004, 08:21 AM   #4
GloNDark
Pirate4x4 Addict!
GloNDark's Avatar
Member # 2482
BEAUTIFUL!!!
I quickly learned with my cruiser, it didn't matter what battery, what alternator I had with me......Jumper cables were absolutely necessary. Then my dad bought me a jumper box from Costco. Never leave home with out it.
GET IT Dave!!
save me a spot bro......i'll miss you...
GloNDark is offline   Reply With Quote
Old 01-16-2004, 08:35 AM   #5
texican
texican's Avatar
Member # 12349
Re: El-diablo strikes again - Late to work
Jerry Hocutt
Jerry you should have been singing praise to the kind soul that gave you a battery, instead of cursing the situation..........
Butch
Conflict is inevitable.....
Combat is optional....
Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set.
[URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL]
[URL=http://www.khyi.com/]Support Texas Music[/URL]
texican is offline   Reply With Quote
Old 01-16-2004, 08:37 AM   #6
Eskimo
Eskimo's Avatar
Member # 10429
A friend of mine has a very similar problem with his 40... I started poking and prodding... his alternator charge wire was attached by the insulation on the wire... the copper inside was completely broken.
As a trail fix, we stripped the wire back, and wrapped it around the stud of the Alt., and he was good to go.
Or is there more to the story I don't know about?
Rich Q.
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/42's
Eskimo is offline   Reply With Quote
Old 01-16-2004, 09:17 AM   #7
Deep South Cruisers
Member # 3514
Re: Re: El-diablo strikes again - Late to work
Butch
I did say my faith in man was restored! just not my faith in the 45, she took some horrible verbal abuse this morning
I tried to give the battery back and even offered to leave it at the store for him after I got it started but he wouldn't hear of it!
Eskimo, not sure if the system is not charging or what, it fired right up in my driveway!!! that Optima red top is less than 2 weeks old
Old 01-16-2004, 09:37 AM   #8
kling-on
Kool Arrow
kling-on's Avatar
Member # 13666
my red top wont start my 60 in the drive way when it 32*f or less after setting more that 3 days..... but when it warms up VAROOOOOOM pisses me off
82 FJ60 5.3, 4L60E, OME Heavy 33BFG's 410's & quicklock ARB bull & side bars and warn 12k
85FJ60 Trail beater SM 420 crawler box lockers 456,4d's bobed & choped with a Metal Tech cage
GIT-R-DONE!!!!
low riders want SWITCHES... 4 wheelers want SHIFTERS
www.jkcustoms.com
kling-on is offline   Reply With Quote
Old 01-16-2004, 01:01 PM   #9
Deep South Cruisers
Member # 3514
I'm about to fire that beyatch up for the ride home...wish me luck!
Old 01-16-2004, 01:39 PM   #10
texican
texican's Avatar
Member # 12349
Re: Re: Re: El-diablo strikes again - Late to work
mad:
Send me your address and I'll come rescue that poor truck from this abuse.
LCPS
Land Cruiser Protective Services
Butch
Old 01-16-2004, 01:52 PM   #11
Deep South Cruisers
Member # 3514
Re: Re: Re: Re: El-diablo strikes again - Late to work
LCPS
Butch
I give and give and all she does is fawk me.
After working hard on her for 3 days I whispered sweet nothings and promised future upgrades and improvements to make her happy. I even moved the FJ60 and parked her in the garage... Cleaned the glass and fixed the wipers. She's a merciless old goat but I couldn't bring myself to get rid of her...unless she leaves me stranded ONE MORE F*^%^&g time
Old 01-16-2004, 02:51 PM   #12
GloNDark
Pirate4x4 Addict!
GloNDark's Avatar
Member # 2482
Re: Re: Re: Re: Re: El-diablo strikes again - Late to work
If she is anything like my cruiser........talk dirty to her, she'll like it better. The rougher the better........
GET IT Dave!!
Old 01-16-2004, 03:05 PM   #13
wngrog
Moderating Midget
wngrog's Avatar
Member # 1154
Send a message via AIM to wngrog
my patience wears thin as blah, blah, blah..I am a whiney bitch that has not signed up for the Lone Star Cruiser Roundup, Blah, Blah, Blah....... heater actually works... a little.
Running painfull low on fuel I blah, blah, blah..I am a whiney bitch that has not signed up for the Lone Star Cruiser Roundup, Blah, Blah, Blah....... with a dead $100 Optima battery.
The Cruiser gods surely blah, blah, blah..I am a whiney bitch that has not signed up for the Lone Star Cruiser Roundup, Blah, Blah, Blah....... e I sat in the drivers seat and waited for a unsuspecting soul to help me push start the beast.
After blah, blah, blah..I am a whiney bitch that has not signed up for the Lone Star Cruiser Roundup, Blah, Blah, Blah....... I wrenched down the battery and fired the engine, I was back on the road.
The blah, blah, blah..I am a whiney bitch that has not signed up for the Lone Star Cruiser Roundup, Blah, Blah, Blah....... it out.
Standing in blah, blah, blah..I am a whiney bitch that has not signed up for the Lone Star Cruiser Roundup, Blah, Blah, Blah....... one of those" "you should restore it" and then the closer "do you want to sell it"............................................... .................................................. ........................."No" I replied, "I'll keep her" (even if she is an ungrateful bitch )
Jerry Hocutt
Buy a Honda.
Nolen Grogan
CottonLand Cruisers
www.rockmidgetphotography.com
blacksheep4x4.com
USAF Veteran 1988-1998 GOD Bless America
wngrog is offline   Reply With Quote
Old 01-16-2004, 03:21 PM   #14
Eskimo
Eskimo's Avatar
Member # 10429
best thing I've seen all day!
Rich Q.
Old 01-16-2004, 07:00 PM   #15
BJ On Roids
Member # 6588
My work ute lost its clutch entirely
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR]
[COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR]
BJ On Roids is offline   Reply With Quote
Old 01-16-2004, 08:23 PM   #16
Cruzzr
Member # 15969
Mount a second battery. I did. It doesn't drain like it use to. If I didn't start it every 3 days I would have to charge the battery. Now it is fixed.
MUD.....It's whats for dinner
Show us your BLING BLING
Tommy
86' FJ60 V8/700R Auto
ARB f/r rear discs 4:56 gears
13" SOA
36x14.5x15 TSL radials
www.lslc.org
Cruzzr is offline   Reply With Quote
Old 01-17-2004, 03:08 AM   #17
HybridPOS
HybridPOS's Avatar
Member # 14442
Send a message via Yahoo to HybridPOS
For some reason there isn't as much "juice" in the Gel cell batteries in extreme cold (yeah, that's extreme for me). The deep cell optimas will do you better in the cold weather, I would do a blue top before the Yellow for a daily driver though. However, I would keep the red top and buy a blue top and paralell them or buy one of the kits for dual batteries. That way you can switch from one to two, or you can charge one while you operate on the other... .and so on....
That thing is cool..... For a Toyota....
83 CJ-7, 360 .030 over, shaved heads on the pane.
105 inches of noise and booger welds.
HybridPOS is offline   Reply With Quote
Old 01-17-2004, 07:12 AM   #18
Bertha the Cruiser
Member # 15705
Send a message via AIM to Bertha the Cruiser
-mike.
I work for Red Wheel weiser....we publish Delil-books...send me a manuscript
[b]In the mornin you go gunnin'
For the man who stole your water
[/b]
Bertha the Cruiser is offline   Reply With Quote
Old 01-17-2004, 08:32 AM   #19
kling-on
Kool Arrow
kling-on's Avatar
Member # 13666
sad thing is i have a second red top and a wrangler silanoid (sp) all i need is wire(and time) ...need to get this FAWKIN house done so i can get back to work on the cruiser .... dam things months over on time GAWD DAM CONTRACTOR
GIT-R-DONE!!!!
www.jkcustoms.com
Old 01-18-2004, 03:05 AM   #20
AIRZUKI
Member # 2143
Go get the crank from under the seat of a FJ55....
My Bro used to always crank start his 55 when these kinda things happened....you know that's why there is a hole in the grill and a funny looking nut on the harmonic .....
Besides people tend to stand the hell back from you after you just crank started your truck
Outlaw , 604 539 1818
AIRZUKI is offline   Reply With Quote
Old 01-18-2004, 09:36 AM   #21
Myanarchy
Myanarchy's Avatar
Member # 14059
I'm going to do my civic duty here. In concern for your blood pressure, and possible health risks associated with said landcruiser I deem it condemned..... When should I haul it off
"free 71PA_Highboy!"
Myanarchy is offline   Reply With Quote
Old 01-18-2004, 10:16 AM   #22
kling-on
Kool Arrow
kling-on's Avatar
Member # 13666
GIT-R-DONE!!!!
www.jkcustoms.com
Old 01-18-2004, 12:20 PM   #23
CaverInaCruiser
Member # 11492
Send a message via AIM to CaverInaCruiser
Hrm... I noticed that my truck won't start after 3 days in the cold... I thought it was a bad Optima (replaced it, under warranty, hehehe). Haven't had the issue since, but then again, I haven' tlet my truck sit for longer than 24 hours in the cold.
-James H
-76FJ40 HiPo2FSM420OMELockRite35's
"You're the guy from the Hamburger train, right?"
CaverInaCruiser is offline   Reply With Quote
Forum Jump
