Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 05-10-2004, 01:09 PM   #1
bigsub
Member # 29634
Bend 4.5" AL pipe with a .125" wall (difference between tubing & pipe)
Do you guys know anyone who can bend 4.5" aluminum .125wall pipe? And don't say muffler shop unless you know a specific one, i've called em all. I don't need a full 90 but i need a big radius and about 30 degrees. I need it to come out smooth. Its a short peice should I go get a tourch and try that? Maybe I can bend it over by propane tank while i'm heating it.
bigsub is offline   Reply With Quote
Old 05-10-2004, 01:17 PM   #2
sceep
SchuitOverBuilt
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
there is no such thing as 4.5 x .125 wall PIPE!
edit: BAAHAHAHAH... i didnt even finish reading your post until now.
please.. please... go fire up your torch, and use it right near your propane tank trying to bend that.
http://www.boogerwelds.com
Scale RC gravelmaker build!!
Originally Posted by Travis Waldher View Post
I hate pussy
sceep is offline   Reply With Quote
Old 05-10-2004, 01:23 PM   #3
bignissan
Member # 14644
yes...go bend it over a PROPANE tank while you heat it.
1986.5 Nissan crawler,2006 Yamaha R1
bignissan is offline   Reply With Quote
Old 05-10-2004, 02:51 PM   #4
bigsub
Member # 29634
Hey Sceep can you explain your little personal picture icon to me i don't get it...... You guys are pathetic. I really didn't think it was necissary to include the little explosion icon in there to idicate my sarcasim but i forgot you read these too. And excuse the heck out of me. Tubing, pipe you know what i was talking about. Its round with a hole in the middle. If you don't have any good advice STFU
Any real advice?
Old 05-10-2004, 03:02 PM   #5
sceep
SchuitOverBuilt
sceep's Avatar
Member # 10798
Any real advice?
uhm.. no actually we have NO FAWKING CLUE what you are talking about. theres no such thing as 4.5 x .125 wall PIPE.
Seeing how there is no such thing are we just supposed to assume that you have a custom 1 off die that is extruding the tube just for you and you want to bend it? or are we supposed to assume that you are in actuallity useing TUBE and possibly recomend useing the wrong type of bender, thus fucking up your expensive ass round stuff with a hole in it.
the answer to your question (Can you bend 4.5" AL .125" wall pipe?) is yes.
yes you can.
how? no fawkin idea.
I hate pussy
Old 05-10-2004, 03:28 PM   #6
TJ99
TJ99's Avatar
Member # 3717
fill it with sand pack it tight and weld the ends shut. then you can heat it and bend it around something without kinking it. never been over 3 inch this way but it should work
97 Jeep TJ Atlas 4.3 with 38.5 tsl/sx's full cage for when it falls over.
TJ99 is offline   Reply With Quote
Old 05-10-2004, 03:45 PM   #7
sasedyota
Member # 29544
yes you can.
Sorry to say but they do make 4.5"x.125 wall pipe
you can get stainless steel from 1/4"-36"OD with a wall thickness up to 1.500" thick. http://www.fedsteel.com/p-stainlessPipeAndTube.html
And they do make benders that can bend that size of pipe and heres a link to a pic to show some of the size benders that are out there. http://www.bendco.com/Bendco's%20B%2036%20induction%20bender.JPG .
and here's a link to some aluminum pipe dimensions http://www.globaltecheng.com/alupipe.htm .
sasedyota is offline   Reply With Quote
Old 05-10-2004, 04:55 PM   #8
bigsub
Member # 29634
Ok let me clarify. Thanks for the help sasedyota. I know that there is a difference between pipe and tube. I'm not sure what the differance is or why there is a difference or what is what(could some one help here?...i don't know everything) But if Sceep would read more carefully before his last post I said I didn't know whether it was pipe or tube. So apparently what i have is aluminum tube. But it definitely measures 4.5 with a .125wall. And its readily available.
So any other ideas?
I like the sand idea, kind of a pain. I just wanna make sure there are no other precautionary measures. Should i leave a little hole in the end to relieve pressure or use a certain type of sand(very dry i guess) I've had a couple things blow up on me when they are buried in the sand and its not a fun thing.
Old 05-10-2004, 05:05 PM   #9
papee
Pirate4x4 Addict!
papee's Avatar
Member # 1041
Send a message via MSN to papee Send a message via Yahoo to papee
just how short is it?
I got nothing
papee is offline   Reply With Quote
Old 05-10-2004, 05:09 PM   #10
indysand
Member # 4382
Might be easier to just go here and buy a piece of prebent tubing. Not .125 wall though. May I ask what you are using it for? Cold air intake perhaps?
http://www.woolfaircraft.com/elbow.htm
indysand is offline   Reply With Quote
Old 05-10-2004, 05:20 PM   #11
bigsub
Member # 29634
Its 36". Hey thanks for that link, that rules. If i don't use it here i will definitely later. I'm using it for a buddies spare tire carrier and part of my roofrack. Also gonna use it for exhaust(i got alot for free)
Old 05-10-2004, 05:36 PM   #12
papee
Pirate4x4 Addict!
papee's Avatar
Member # 1041
It sounds a little short to get in a bender. It may fit when straight but once you start the bend it may be to short for the bender.
I got nothing
Old 05-10-2004, 07:53 PM   #13
bigsub
Member # 29634
I can cut it afterwards. What kind of shop or who has tools to bend it?
Old 05-10-2004, 10:27 PM   #14
SirMrManGuy
Member # 23566
Send a message via AIM to SirMrManGuy
4.5 is pretty big, I doubt any automotive shops would have that kind of bender. Not many of us use anything much over 2.5in tube, so you may be on your own. Start calling industrial places, like shops that do exhaust for big rigs, industrial plumbing places, large iron workers or maybe some place that makes those big signs that go over highways (I've noticed some bends in them driving around, I always wonder what kind of bender does that, some of em look as big as 24in).
95 Nissan Pathfinder, D44 front/H233 rear, dual ARBs, 4.56s, 36 Iroks
SirMrManGuy is offline   Reply With Quote
Old 05-11-2004, 07:31 AM   #15
sceep
SchuitOverBuilt
sceep's Avatar
Member # 10798
I'd start callin deisel exhaust shops.
I hate pussy
Old 05-11-2004, 11:31 AM   #16
Albin
Member # 13342
Pipe = measured from inside out
Tubing = measured from the outside in.
I hope this helps.
'85 Toy 4Runner
'06 F-350 SRW 6.0 PSD
Albin is offline   Reply With Quote
Old 05-11-2004, 01:07 PM   #17
bigsub
Member # 29634
I hope this helps.
You mean one is measured in OD and one in ID? Theres gotta be more differences? Thanks.
Old 05-11-2004, 02:11 PM   #18
ROKTOY
Don't Tread On Me!
ROKTOY's Avatar
Member # 400
I hope this helps.
Nope. They're both measured based on o.d.
All 2" tube is 2" od and all 2" pipe is 2 3/8" od, regardless of wall thickness or id.
Why in the world would someone measure "inside out"?
Jay
Jay's (old) Toyota 4WD Web Page
Built to Grind Rockcrawlers
""If we lose freedom here, there is no place to escape to. This is the last stand on Earth."
Ronald Reagan
ROKTOY is offline   Reply With Quote
Old 05-12-2004, 01:35 AM   #19
bigjeepguy
Member # 15959
pipe is "technically" meant for transport (ie steam or fuel) Tube is "technically" meant for structural usage. Search, this has been hashed to DEATH
bigjeepguy is offline   Reply With Quote
Old 05-12-2004, 01:50 AM   #20
LandCroozer
Member # 16812
You're using aluminum on exhaust? Why does this sound like a bad idea? And 4.5" is huge.. I'm guessing you have a very large, very cool running engine.
-tom
LandCroozer is offline   Reply With Quote
Old 05-12-2004, 02:58 AM   #21
braxton357
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
Make sure your sand is dryer than sceeps vanay-nay sand before doing this or
:edit: I see that you have already adressed this bigsub, good job mang...actually using your brain.
And jesus, are we SERIOUSLY bringing up pipe/tube again!?! And are this many of you STILL clueless asshats on the subject? Pipe =nominal ID, Tube =OD. There are many differences including tensile strength weight etc etc but who teh fawk cares, he is wanting to bend some AL tube.
Bigsub, you say that you are getting a whole lot for cheap...just go ahead and make a jig, heat it, and bend. You could have already tried it and reported back as to weather it worked or not...
In vino veritas
70 turbocharged 351w fastback mustang
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
98 locked beater xj on N20.
braxton357 is offline   Reply With Quote
Old 05-12-2004, 08:33 AM   #22
ROKTOY
Don't Tread On Me!
ROKTOY's Avatar
Member # 400
I think you mean Pipe =nominal OD, Tube =OD
Jay
Ronald Reagan
Old 05-12-2004, 08:35 AM   #23
bigsub
Member # 29634
I know, I've just been putting off buying a tourch and bottles. bling bling. Thanks for all your help guys. Oh and the exhaust is for a desiel
Old 05-12-2004, 11:40 AM   #24
fj40charles
Member # 1926
Why not just run 4 or 5" exhaust. Plenty of exhausts available for diesels. Unless you you're pushing 400+HP at the rear wheels, I don't see a need to larger than a 4" exhaust. Most turbo exhaust housing are smaller than 4"
'69 FJ40 with very few stock parts.
2000 Cummins with some goodies to make it smoke.....
Trail Gear's Bad Ethics=Bad Business.
fj40charles is offline   Reply With Quote
Old 05-12-2004, 02:38 PM   #25
bigsub
Member # 29634
Exhaust was just a side thought. I haven't done the research to see if it will work. I figured it wouldn't be to big for a 8.3 cummins
Forum Jump
