#1 |
Member # 11961
Taurus fan control
One of the issues that needs to be addressed when installing a Taurus fan is the wiring. The fans draw near 80 amps at start up then simmers down to a mere 30 amps of continuous draw. These awesome fans pull around 3000 cfm, more than enough to cool even the meanest jeep motor.
I first ran mine through a relay that came on when the ignition was on. This cooled the jeep great, but two problems were evident. The fan was on high all the time, which made it very loud, and my jeep likes to run around 190 degrees, and it took extra long to get it up to operating temperature. The type of wheeling I do means stopping and starting a lot. I will get out of my jeep and spot for someone, leaving my jeep sometimes for an hour or more. The fan on continuously from start up means the jeep takes a long time to warm up. In steps DC Controls, www.dccontrol.com has designed and built a controller unlike any switch on the market. Designed for the Taurus fans, it has a simple probe into the radiator to determine temperature and is set to come on at 180 degrees. There are prongs on the controller and jumpers that will increase or decrease the motor temp by 14 and 28 degrees respectively. I set mine to come on at 166 degrees. The fan comes on gradually so there is no voltage spike to contend with. When the jeep is warming up, the fan does not come on. The controller adjusts the speed of the fan to what it needs, so it runs quiet most of the time. There is a wire for A/C that turns the fan on to 50% power when the A/C come on, which I hooked to the OBA compressor. There is an ignition wire that can be hooked up to either the ignition or 12v to run the fan even after the ignition is turned off. I opted to run it 12v hot all the time, to cool the jeep when it is off. The fan stays on for about 90 seconds until it has cooled the radiator to below 166 degrees. The kit contains wires for the fan, to the battery, to the A/C and the ignition, as well as the jumpers to adjust the temperature setings. The kit I bought contained the probe, wiring and controller for $110. You could very well buy just the controller for $80 and probe for $15, but the wiring kit sure made things easy. Here are a couple pics of the mounting and the unit. Special thanks to Randii on the board for turning me on to the product.
#2 |
Member # 16699
Nice................. thanks
Can this be turned off manually ? For deep water ?
__________________ The clock is laughing in my face. Last edited by rockmup; 10-15-2004 at 12:50 PM. |
| Sponsored Links |
#3 |
Can you wire it into both of the fans inputs (hi and lo) or is it either or? I'm assuming the latter.
You mentioned that the controller adjusts the speed of the fan. Does it step it's speed based on the 'base' temp and go up from there? ie.. every 10 degrees above 166 (in your case) up the fan speed by another say 15%.
'93 YJ 4Banger |
#4 |
Member # 11961
If you connect the (yellow) ignition wire to a switch, you could turn it off for deep water. I wheel in the desert and have never seen water past my tires, so I didn't need to.
The Taurus fans are designed to run on either or field, but not both. They actually run faster on just high as opposed to low and high at the same time. By the time my engine is at 180-190 it is at full speed, so yes, it steps up quickly as needed. |
#5 |
www.12voltguy.com
Member # 40
Adj. Fan Thermostat, Auto Zone, Imperial Automotive Products (Hayden) p/n:226203, cheapest I have found yet that is reliable and works decent $17
LOTS of GUNS 4sale ! 12voltguy.com / ![]() Click here to email me New # 530.532.4529![]() http://www.davezoffroadperformance.com/ OFN Fab BB -89 1 ton bronco on 47" LTB's-![]() Hard work often pays off after time, but laziness always pays off right now. |
#6 | |
Member # 14687
i run the same setup and it works great. |
#7 |
Member # 11961
The Hayden controllers are a decent option, but not intended for the amp draw of a taurus fan. So add two $25 relays and you are close. I saw 3 Hayden controllers go bad last year, that's why I wanted a better option.
#8 |
Pirate4x4 Addict!
Member # 347
Glad it worked out for you -- I was tickled with mine. There's some more details in this thread, but I think you pretty much hit the highlights above:
http://www.pirate4x4.com/forum/showt...ght=controller Getting the coolant up to temp fast and STAYING there is perfect for EFI -- perfect for the pulse-width modulation that they use in these controllers. Smart move hooking the fan up to a constant 12V -- the electronic thermostat will shut it off, if everything works well. Far simpler than the setup I installed!Randii
Pack it *ALL* out... you pick up after your dog, so clean up after YOU, too. - VIRTUAL RALLY for the HAMMER TRAILS in JOHNSON VALLEY Post 1349 - VIRTUAL RALLY for TELLICO Post 716 and Post 924 - KOH Pledge Drive: for 4405 KOH Pledge #4 |
#9 |
Pirate4x4 Addict!
To get this straight, this box takes the place of:
-Thermal switch -relay -circuit breaker as in wire it up and you are good to go?
ECV 7-11 Serving up a Tsunami of Swagger |
#10 | |
www.12voltguy.com
Member # 40
P.S. org post, nice controller
#11 | |
Member # 11961
Like Randii said in the other post, there are cheaper options, but IMHO, few better. |
#12 |
Member # 6957
how do you install the probe into the radiator????
#13 |
Member # 14584
Ive seen alot of posts about the Taurus fans but dont remember anybody saying they got the controls from the car. I realize all the pieces might not be there but if you got the controls from the car you know it would handle the load. Wire the relay with a switch and your good to go.
Is there something about the controls that I dont now about that would make it more complicated?
Yes my truck is environmentally friendly. It lets most of the environment in the truck with you! |
#14 | |
Pirate4x4 Addict!
Member # 347
DCC also has some sort of inductive heat sensor that you can bolt to the thermostat housing. Both are solid state, variable resistance sensors, not fluid-based bulb/capillaries. Randii
#15 |
Member # 5787
Model FK-35 is all you need to run a Mark VIII or Taurus fan. With the Taurus fan, you only use the high speed wire (yel/brn) and ground (blk) and leave the low speed disconnected. It regulates the speed of the fan depending on the temps from the probe that sticks in the fins of the radiator.
Jim Yes I'm in the Navy. F/A-18 Jet Engine Mechanic. “MICROSOFT: Where do you want to go today? APPLE: Where do you want to go tomorrow? LINUX: Are you coming or what?” |
#16 |
I Also purchased the dc control for my road racing mustang , very very simple to wire up and very clean without alot of crap like relays and such . Havent fired the car up as of yet . I have read many raving reviews of this product and it is just so damn simple . Plus you can wire in a switch , hook it up to AC or any other accesory that you want to activate the fan . purchased the LED light so i know that it is running for sure , hard to hear with straight pipes
NorCal Tree Expert Co. (530)527-2844 Need tree trimming/removal , need defensible space ? Call us ,insured and licensed . Serving Tehama, Glenn, Shasta and Butte County |
#17 | |
Huah!Hah!Huah!AwBaby
97 TJ with some stuff 1 man Pirate RC race team in Oly running a Arrr See Ate Tee ![]() Ultimate TJ Build Ups and Swaps Thread Everything you need to know about your TJ |
#18 |
Hope it works , just remember you get what you pay for . dont mean to sound rude , but if your gonna be that anal about it you might as well wire the fan directly to a battery kill switch and control it manually . Maybe i'm being a bit pssimistic , but thats my style
#19 |
Member # 1919
you do not "get what you pay for"
you get what you deserve |
#20 |
www.12voltguy.com
Member # 40
The $17 unit works very well, hell a big relay through the ignition works great too, FORD seems to think so.....& they have not had trouble with it in how many years of the taurus?
#21 | |
I am very interested in this mod..... -Rock
[url=www.twistedsteel4x4.com][color=lime]Twisted Steel 4x4[/color][/url] |
#22 | |
Spork Wrath
never had it leak and is very accurate. also it does not damage your radiator fins and can not be knocked out/ vibrated loose
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage. |
#23 | |
www.12voltguy.com
Member # 40
#24 |
Member # 47448
I dont see the difficulty in using a continuous duty Solenoid, and putting a cab mounted switch in the 12v trigger. Keep it switched off on dead cold starts until she's ready for the hurricane. $17 Isn't bad if there reliable and work good though.
98 Durango - Rockwells, 4 wheel steer, 53" michelins. www.webarchitectural.com |
#25 |
www.12voltguy.com
Member # 40
Funny I was just asked about this from an Ebay customer this morning.
Here is same thing I told him I do not offer a kit & I have run this fan in a jeep before, GREAT FAN! I never hooked up the t-stat controller, just had it on with ignition, but found out about this T-Stat controller on the net Adj. Fan Thermostat, Auto Zone, Imperial Automotive Products (Hayden) p/n:226203, cheapest I have found yet that is reliable and works decent $17 that and a 3 position switch on-off-on & a 70amp or better relay I have 70 amp relays $20each 2 required with a 3 way switch, at least the way I came up with, see drawing attached 3 position Neopreme O-Ring sealed & a rubber boot too DPDT toggle $20 $6 shipping $66 + go get the T-stat control at Auto zone there are many ways to hook up a fan, this is just another way
| Thread Tools | |
| Display Modes | |
