Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Suzuki
Old 10-18-2004, 10:52 PM   #1
YotaAtieToo
YotaAtieToo's Avatar
Member # 25632
Overall length diff between swb & lwb
I was thinking about lengthening the rear of the tub on my swb sami so I could gain allot of wb and use a lwb top but am not sure of the length dif
I found that the overall length of a lwb is 158" but I dont know the overall length of a swb?
YotaAtieToo is offline   Reply With Quote
Old 10-18-2004, 11:05 PM   #2
scwafish
Member # 977
FYI-the lwb top is
eXtreme web-wheeler!
scwafish is offline   Reply With Quote
Old 10-18-2004, 11:37 PM   #3
YotaAtieToo
Member # 25632
um wtf, why? I do allot of snow and would like to beable to sleep in the back of it and I figure a lwb base top would be better then a fully custom one espcially since I want a hard top
Old 10-19-2004, 08:12 AM   #4
Tusker
Member # 2752
What he means is the lwb hard top is geakish looking. Kinda like the two-piece swb tops but worse. Your idea is good, but the soft tops look cooler that's all.
If you "have" a swb, why do you need someone else to measure it for you If you want to proceed with your plan, you would be better off getting a lwb top and doing your own math and measuring. If you end up even a half-inch off, you wasted your time. Don't trust us with your rig
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, .............
Hey, if this rig is for wheelin', what are all these animal parts doin' in here?
Tusker is offline   Reply With Quote
Old 10-19-2004, 09:13 AM   #5
OKIE ZUK
OKIE ZUK's Avatar
Member # 14812
Let me try, 13" longer wb and 13" more over hang. But like Tusker says a half inch can mean alot.
'94 Samurai, EFI, 6.1 t-case, twin sticks, 5.29 locked and shaved Toys, RS9000X's, HS9500i, OBA, Coiled, 36" IROK's, 94" WB, etc, etc.
OKIE ZUK is offline   Reply With Quote
Old 10-19-2004, 01:54 PM   #6
xamtex
Member # 25613
lwb is 12.5 inches longer wheelbase and 23.5 inches longer overall.
"95 mk2" 91 SAMMY LWB "LOCKED AND LOADED"
xamtex is offline   Reply With Quote
Old 10-19-2004, 02:57 PM   #7
Tusker
Member # 2752
See, I told you. 13", 12.5", do I hear 12"???
Old 10-19-2004, 03:06 PM   #8
zukanuba
Member # 28861
Send a message via AIM to zukanuba Send a message via MSN to zukanuba Send a message via Yahoo to zukanuba
how about 13.32345675437885764627278486746378574737562524125 63474"
zukanuba is offline   Reply With Quote
Old 10-19-2004, 10:58 PM   #9
YotaAtieToo
Member # 25632
I think I will "look" allot cooler (warmer?) on snow runs with a hard top then with a soft top
Well I couldnt find a tape Well really I wasnt to sure where the measurements were takin from. And I wasnt waiting for a measurement so I could go weld my sami back together I was just wanting to get an idea if I want to do this or bob the tub so it has simular space to a newer xtra cab toyota
EDIT: hey scrawfish did bryan get a hard top with your zuk when he bought it?
Old 10-20-2004, 12:22 AM   #10
redzook
Member # 15738
i get 13.6
swb= 79.9
lwb= 93.5
redzook is offline   Reply With Quote
Forum Jump
