#1 |
Member # 2463
Cheap extended diff breather tech
Thanks to the weekly downpours here in AZ, river crossing has become an art. So has changing milkshaked oil. I've been meaning to install some extended diff breathers for a while, but the AZ sun made me rarely think about it.
All parts are available at any Napa, ACE, Home Depot, etc. etc.. The thread on the stock toyota vents is a 10mm x1.00mm pitch, but an 1/8" standard american pipe thread is so close it may as well be metric. It is 1/8" x 1.00 pitch for all the tech geeks. All you need to do is to source a couple of grease gun hoses, Lubrimatic or any other brand will work, they're all the same for standard grease guns. The Napa part # is 715-1229, they're about $6 for a 18" extension. If you need more than an 18" diff breather lift, pick up 2 1/8" female couplers for each axle and another length of hose. If you are just going up 18" from stock, pick up one 1/8" coupler. Teflon tape the threads of the hoses and then thread one end into your differential's opening after removing the stock breather vent. Once the hose is installed, put a coupler on the other end and screw the stock vent right into it. Tighten and you're done. Route the lines out of the way and secure. Done deal, no more milkshakes. An 18" extension/coupler should cost you under $10 per axle, 36" extension like mine under $15. Far cheaper than draining and resealing the diff after submersion, ask me how I know. There you go, some tech. This more than makes up for the flaming I've been doing lately.
#2 |
Member # 2463
The 36" one for my junk. I routed my rear up my limiting strap for the 4 link with a little slack just in case. Secured it to my ammo can full of spares, a full 30" above stock.
| Sponsored Links |
#3 |
Member # 2463
Installed pic on my junk.
#4 |
Member # 16662
Nice. I had a spare hose (heater or fuel or somthin like that) Layin around so I sqeezed it over the stock port and used a hose clamp. It worked well also, But your Idea is definatly nicer.
Kevin
CALIFORNIA CREEEPERS www.calcreepers.com |
#5 |
chicken fucker
Member # 2931
my front is still milkshake from my last fordyce run in november
nice linked up rear, how you like it?
http://www.diamondaxle.com http://www.F-O-A.com http://www.12voltguy.com http://www.addictedoffroad.com wanted: (2) 12''x3''x250# coilover springs 2002 diamond axled coilover/linked tacoma v6 4door rock taxi with dual cases and beadlocked 37s |
#6 |
Member # 4716
I've been running 1/8" NPT fittings in my axles since 1997 or so. They fit well, cost very litle and you have a wide choice of sizes, shapes, angles, etc.:
http://www.4crawler.com/4x4/CheapTri...html#Breathers |
#7 |
I broke one of those orange 3/8" air lines from home depot. Took the caps off the stock breathers, shoved the 3/8" line over the top, 2 hose clamps, some zip ties and I am done. Since I had alot of line, I ran both into my engine bay.I may tie into my trans and TC breathers later on.
Garrett Matt Performance Driving & I4WDTA Certified Off Road Training |
#8 | |
Banned
Member # 3933
#9 |
Member # 24921
Great idea on the hoses!!! ,thanks, ill add these to my build up sheet!
88 TOY 4RUNNER 22re SAS'd 85 front axle Hysteer front detroit locker. 35" TOYO Mud-terrain tires Marlin MC07 92 toy 4x4 xtr-cab(sold) 83 toy 4x4 (sold) 81 toy 4x4 (sold) |
#10 | |
Pirate4x4 Addict!
ditto, bout a buck which is much cheaper than $15 ![]() I put loops on the end of the breather and the rear one goes to the tool box and the front wound up in the engine compartment. Both have cheap vw filters on the end
This Space for rent! |
#11 |
Attention Whore
if you want extra bling on the cheap, go to home depot and get a refrigerator ice maker hose. they are about $10 and are steel braided line
#12 |
Member # 22539
even cheaper and a complete bolt-on same 10mm x1.00mm pitch as toy but longer on the side that you put the rubber hose, is the diff breather of a nissan from the 80s and I paid like 2.29$cad each with taxes at the steallership!!!
it extend like 1-1.5" to put the hose on it
84 runner 4" lift,fender triming,36 tsl 5.29,rebuilt 22r with torquer cam and changed back to stock carb UNDER RECONSTRUCTION [URL=http://www.toyota4x4.net]toyota-4x4.net[/URL] [URL=http://www.toyota-4x4.net/forum/index.php]forum[/URL] |
#13 | |
Pirate4x4 Addict!
#14 |
Member # 16741
diff breather.
brandon, what part of the rig i can get this part of? it was mentioned before
that it is the exhaust but i looked my 22r carb, there is nothing i see. thanx Last edited by ray zapanta; 01-28-2005 at 02:58 PM. |
#15 | |
Member # 40586
Beard- The lazy man's Goatee '85 Toyota Truggy- Locked, Duals, 37" MT/R's on Stazworks 17's... '04 Tacoma Double cab |
#16 |
Member # 26872
if you guys go to pick n pull and see some izuzu troopers there look on the right side of the rear axle... if the diff breather has a hose bingo... merry christmas... the threads are the same as a toy axle and there are a million troopers.... oh yah 4x4 nissan pickups had the same ones as well....
85 ex cab injected... sittin on 60s and an empty wallet... |
#17 |
Member # 21134
Since this has become a competition of cheapness...Just rip off the cap from the stock breather, find any tubing that fits over it (I used this clear plastic stuff from the hardwear store) and hose clamp it on. On the other side stick a cheap fuel filter in the tube and clamp it on.
'93 4Runner V6, Auto, SAS, e-locker, arb | www.ultimateyota.com |
#18 |
boulder buddha
Member # 3886
i used the nissan fittings with clear hose and cheap fuel filters.
it works sweet.
hold this... |
#19 | |
UltimateYota Junkie
Even with Toyota parts it's like $10. Rear: ![]() Up behind the gas cap: ![]() Front (IFS ) - snug fit![]() ![]() Up in the engine bay:
JeepsLimited.com - Jeep Writeups, FSM's and Parts Lists
UZswap.com - A site dedicated to swapping the Toyota/Lexus UZ (V8) engines. TOOLandFAB.com - A site dedicated to tools, fabrication & workshops. Also see my My JD2 Bender Hydro Conversion |
#20 | |
Member # 21134
#21 |
War Damn Eagle
Member # 2497
All this diff breather artwork aint worth snot if you let the felt wipers on the backside of the knuckles get worn and leaky. You will have nice diff oil and birfs lubed by green baby-shit goo. Like this.....
Yall are just awakening to what us southern boys have been a-larnin' for years.
Buy Rescue Tellico stuff! Profits go to Rescue Tellico fund. 86 4Rnr (orig owner), SAS, inchworm, lotsa doghair Rocket City Rock Crawlers If you didnt buy your 1'st gen 4runner new, then YOU are a newbie! |
#22 |
Member # 3101
Another cheap part is the brake booster fitting on the intake and it's the same thread. Just go to the U-Pull-It and snag one.
00 Dodge QuadCab CTD 97 TJ on 33's for now |
#23 | |
Member # 16125
Location: People's Republic of California, Southern Sector
Mark Matthews 84 4Runner with lots of stuff 86 Toyota Pickup SAS with 4.3L Vortec All that is gold does not glitter, Not all those who wander are lost. |
#24 | |
Member # 20208
Location: Pollock Pines, but dont worry, I decided to keep my full set of teeth, unlike most everyone else up here...
We call that shit "diff pudding" where I come from......
[QUOTE=Myanarchy;6682920] Thanks for the tips, I think I'm gonna stick it between max volume and his boyfriend's pelvis. The force of their love could crush a bowling ball[/QUOTE] |
| Thread Tools | |
| Display Modes | |
