#1 |
Newbie
Member # 36157
high altitude/stock carb
Last fall my wife and I drove the back trail from Bear River Res. to Silver Lake in the Sierra's. We were at 8,000 to 9,000 feet when the engine started to run bad and would not idle. We were at the "ROCK GARDEN" when this occured and I consequently dented my front pumpkin. Back at camp at Bear River Lake I changed the fuel filter and looked for loose hoses or wires but nothing helped. This conditon lasted a couple of days and then then engine ran ok. We did then entire trail without a sputter. Is there an altitude adjustment for the carb? Is the ECM going bad? Any help would be appreciated.
By the way, this was the week before the opening of deer hunting season and we saw very few people besides hunters on the trail. We also enjoyed the first snow of the season. It was t-shirts and shorts one day and snow the next. Anyway, if there is an altitude problem, and hopefully a solution, I could use the help. Thanks
A WINK IS AS GOOD AS A NOD TO A BLIND HORSE |
#2 | |
Member # 9419
I live at 9,000 feet. Now back in the day, when there was no such thing as an ECM, or fuel injection, everybody KNEW that you had to tweak the carb for that kind of elevation change. What elevation do you normally run at? So here's the deal. Keep it running. Cup your hand over the exhaust pipe for a second or two (so the exhaust blows into the palm of your hand) - don't burn yourself. SMELL your hand. Does it smell like gasoline? You're probably running rich. You need to turn the mixture screw in, until it runs better. Now mind you, you'll have to turn it back OUT the same amount, when you go back down to lower elevations, or it'll run lean, which is way worse than running rich. I wish I could begin to tell you how I adjust a carb, but it's by ear. I did 's Jeep carb. It used to be that lots of people had this knowledge.
Bob Thus spake the village idiot. |
| Sponsored Links |
#3 | ||||||
Member # 29991
Bobzuki asked if this had an ECM. I will assume it does since you are in California and not Canada, and since pert near all zukes here in the USA do have ECMs. Are you aware that this is an electronic carb and that it adjusts for altitude? Automatically the ECM adjusts the mixture as it reads the O2 sensor. As the engine gets richer at altitude the mixture is adjusted so it remaions crisp and smooth. Yes, cuz of less oxygen you will have less power, but at least you won't be throwing gas away. But not all Zukes are running properly, with the ECM controlling the mixture. You may be in 'open-loop mode' which could also be called here the 'limp-home mode'. If say, the O2 sensor was kaput, the ECM would just let the mixture go full-rich and would not adjust for altitude. There is a separate altutude sensor that switches on at 4000'. It does some stuff like kicking in fast idle. And i think some other stuff... maybe turns off the EGR? So, I think you could get the fast idle and the ECM still might be in open-loop mode. Search the archives, there is a lot on this. You can test the O2 sensor. You can determine if you are in closed-loop too. Note that when cold the Zuke starts in open-loop, and at WOT (wide open throttle) (IIRC). Quote:
When I re-jet a motorcycle for altitude I start with the mains and work down. But it is a lot more than turning a screw. Some carbs exist that are fully adjustable but not on a Zuke. Quote:
Pardon me, it is late, everything seems funny to me. I personally doubt that this problem is associated with the ECM.Quote:
"The care of human life and happiness and not their destruction is the first and only legitimate object of good government." --Thomas Jefferson, 1809. |
| Thread Tools | |
| Display Modes | |
