Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Truck and 4Runner
Old 03-01-2005, 05:29 PM   #1
gtxracer
Huah!Hah!Huah!AwBaby
gtxracer's Avatar
Member # 25303
Send a message via AIM to gtxracer Send a message via Yahoo to gtxracer
Homemade Cowl Hood/Snorkel System - pics
Alright, this is for us poor men/students who can't afford to buy a $240 snorkel system or any other units because of the $$$ flow. I started this idea a long time ago but just got around to starting it.
My plan is:
Make a nice cowl hood that is small enough to fit a Toy hood
Make it a cowl induction/snorkel
the cowl part isn't as important as the snorkel, this is explained later
the snorkel part will be a hole in the hood, also explained
must be made by me and be cheap!
Ok, now to explain I run a Weber 40 with adaptor on my 83 pickup, so it's already about 1/2" away from the hood. That's good! I will be ditching the Downey air filter setup and making my own 1/8" plate for that. I will be using weather stripping on the hood so when I slam it down, it seals the intake system and will not allow water to come in even if the engine is complete under. Of course, the carb is on the passengers side, so how will I still make the cowl center? Simple, offset the plate The snorkel part will be on the passengers side of the cowl and probably only use 1/2 of the actual cowl induction area if that makes any sense. Progress might be a little slow, but it will have a nice finish. I will most likely use some plastic funnel-shaped plastic on the hood, bolted down and with some silicone sealant at the top. On the bottom, that's where the weather stripping goes.
Now, some of you might be confused how this works. So I've made a little drawing to show WTF I'm talking about
Here 'tis:
Also, the sides will be tilted out and the front will have a "dovetail". One more thing: There will be "lips" on the outsides of this cowl. They will block the rain and water from coming into the setup. The top part of this cowl will be longer on top so no rain has a chance of entering. I still have to decide on an air filter but I will use one.
Here's what I've gotten cut out so car. Plasma is goooooood
(and no, that's not a LARGER basketball )
03.5 MazdaSpeed Protege DD
97 TJ with some stuff
Ultimate TJ Build Ups and Swaps Thread
Everything you need to know about your TJ
gtxracer is offline   Reply With Quote
Old 03-01-2005, 10:04 PM   #2
Psychojimmy
Member # 43144
Send a message via AIM to Psychojimmy Send a message via Yahoo to Psychojimmy
if your going under water and water runs up the hood won't it make a ses-pool and go straight down your hood into your motor?...not trying to be a dick but good luck welding that 1/8' to the 16 gauge hood with out warping it...trust me i practiced on an old hood i had and i'm a fabricator for a living and it warped and oil canned like crazy
Psychojimmy is offline   Reply With Quote
Old 03-01-2005, 10:39 PM   #3
gtxracer
gtxracer's Avatar
Member # 25303
Nope, not welding the cowl to the hood. It will have tabs on the inside of the cowl, hidden
Yes, water CAN overflow onto the hood and get into it, but I don't go into THAT much water. Besides, I plan on buying some nice rubber hose to connect up if I need to go that deep. Anything deeper than my floorboards floods into my cab anyways, so I try to stay away from stuff that deep.
Now, if I blast through a waterhole while going up a local trail I might get water splashed up over the hood a little bit. That's where the ridges and raised sides come into play. It's not a bad design actually...
Old 03-02-2005, 02:23 PM   #4
gtxracer
gtxracer's Avatar
Member # 25303
Tacked it together today and primered it up so it won't rust-
Old 03-02-2005, 02:42 PM   #5
FrankenToy
Lobstetrician
FrankenToy's Avatar
Member # 36822
Seems like a lot of work for what basically amounts to cold-air intake. A simple piece of duct tube from a speed shop might be easier, it's what I used but on a different engine. Also, with that cowl on your hood you might be obstructing your already limited view while wheeling. I would also be concerned with rain (and snow if you lived up here, hurricanes down where you're at ). The set-up you've described does work great for drag racing though. I'm just sayin'.....
"Having sex makes straight people gay and turns gays into Mexicans. Everyone goes down a notch." - Peter Griffin
White, straight and Conservative. How else may I piss you off today???
I'll keep my money, guns and Freedom. You can keep the "CHANGE"...
FrankenToy is offline   Reply With Quote
Old 03-02-2005, 02:46 PM   #6
Al Kaholick
Member # 6421
Send a message via ICQ to Al Kaholick Send a message via AIM to Al Kaholick
nice skidplate
[QUOTE=anvil]
your very informative reply has been noted. I think this is the same type of logic you used to draw your conclusion.
Place banana in your ear.
Observe that there is no alligators around.
Conclude bananas placed in ears keep aligators away.
[/QUOTE]
Al Kaholick is offline   Reply With Quote
Old 03-02-2005, 02:49 PM   #7
longboy
Member # 14770
Send a message via AIM to longboy
Originally Posted by Al Kaholick
nice skidplate
needs a paintjob!
'83 CJ7
longboy is offline   Reply With Quote
Old 03-02-2005, 03:59 PM   #8
gtxracer
gtxracer's Avatar
Member # 25303
That's messed up
Old 03-03-2005, 09:33 AM   #9
KacksterK5
KacksterK5's Avatar
Member # 5851
Send a message via AIM to KacksterK5
if u want a snorkel. 3 letters PVC
"If you ain't first, you're last"
86 4Raisin A bunch of stuff under it
02 Chevy 2500 HD Tow Rig
KacksterK5 is offline   Reply With Quote
Old 03-03-2005, 10:11 AM   #10
Sundowner
Member # 8203
so how much more than the rest of your hood does that scoop weigh?
super cool turbo 4runner
Sundowner is offline   Reply With Quote
Old 03-03-2005, 11:06 AM   #11
gtxracer
gtxracer's Avatar
Member # 25303
Like I want to run PVC all over my hood and engine bay
The scoops doesn't weigh much at all. I could throw it pretty far
Old 03-03-2005, 11:28 AM   #12
HomeGrown
HomeGrown's Avatar
Member # 23015
i give you props for being different. lets see it on the truck now.
HomeGrown is offline   Reply With Quote
Old 03-03-2005, 12:06 PM   #13
Chopperman
Cage Fighter
Chopperman's Avatar
Member # 2634
what is that shiat 1/4" ?
Chopperman is offline   Reply With Quote
Old 03-03-2005, 12:41 PM   #14
erg801
Member # 18513
Send a message via AIM to erg801
Doesnt look like you cleaned up the rust before you primered it
94 Toy P/U - SASd - 5.29s locked f&r - Stock Duals - 35" Trxus
erg801 is offline   Reply With Quote
Old 03-03-2005, 01:33 PM   #15
gtxracer
gtxracer's Avatar
Member # 25303
Uhh....and who said I was finished? Where's your custom fab?
It's 1/8" sheet.
Old 03-03-2005, 01:45 PM   #16
gtxracer
gtxracer's Avatar
Member # 25303
Excuse the fawked up welds...the MIG wasn't being very nice I finally got it adjusted at the end, so I'm gonna have to grind off the old welds and go over all the holes. I with my buddy wouldn't have turned off the gas 1/2 way through! I've only been welding for a few months so I'm doing decent. Gotta start somewhere
Just placed on the truck...I still have to do some trimming and get the inside tabs welded on-
I'm going to move it back as far as I can. I gotta take some measurements to see where the scoop would hit the glass.
Old 03-03-2005, 02:36 PM   #17
DBrown2
DBrown2's Avatar
Member # 17590
AHHH each is to its own......... But serious that is kinda FUGLY or better yet Gay Racerish
85 Toy gone, 73 FJ 40 Stroked Caged, locked and tubed. Yota Buggy is now complete after 3 years.
DBrown2 is offline   Reply With Quote
Old 03-03-2005, 02:48 PM   #18
TatonkaII
TatonkaII's Avatar
Member # 12454
Send a message via AIM to TatonkaII
well, maybe the baseball douche had a point.. you need to put some more hours into that thing... or start over.
85 3.4 V6, 38s, Longs, 4.7 Marlins, 5" AP springs.. almost done..www.chucktownlowdown.com
TatonkaII is online now   Reply With Quote
Old 03-03-2005, 02:49 PM   #19
FrankenToy
Lobstetrician
FrankenToy's Avatar
Member # 36822
What size are them freakin' tires??????
Old 03-03-2005, 02:55 PM   #20
waverider
waverider's Avatar
Member # 11971
Am I missing something? I don't see the snorkel. Where is the air filter? What is the point?
LUCKY 13 OFF ROAD
waverider is offline   Reply With Quote
Old 03-03-2005, 02:58 PM   #21
TatonkaII
TatonkaII's Avatar
Member # 12454
another post said 35s
Old 03-03-2005, 03:10 PM   #22
John Smith
Member # 5257
Believe it or not that is exactly what most people do when they want a snorkel and don't want to pay Safari's price. I personally would not be caught dead with your creation on my hood but that is just my personal preference. Now realize this comes from someone with PVC all over my engine bay.
Next week are you going to demonstrate your mad fab skills and make a wing for the rear of the truck?
John Smith
79 FJ40 & 78 FJ55 TLCA #9074 CLCC
John Smith is offline   Reply With Quote
Old 03-03-2005, 03:16 PM   #23
gtxracer
gtxracer's Avatar
Member # 25303
Yeah, 35s. They're the 16" wide Boggers I like 'em so far.
I wish you guys wouldn't judge my work before I finish it I will be putting more time into it, these are just pics someone requested. I still have a lot of trimming and grinding to do. I won't make something hack...
The snorkel part will be cut out of the hood. See the air filter in this pic, there will be a hole and a "funnel-shaped" cylinder leading up to the hood/cutout area.
I tried to draw it but it's hard to explain. Basically, when I open my hood it will look like a standard carb with no air filter on. When you look at the hood as I pop it open, you will see the air filter and how the system works. It's easier shown that said... Trust me, it will work once I get it all done
I'm not a conventional guy and I don't like being just like everyone else. What's the point in that? So my truck will look just like the next?
John - My wing is going on the cab, you douche
Old 03-03-2005, 10:08 PM   #24
Psychojimmy
Member # 43144
before you bust out the gas axe on your hood you have a very clean looking truck that is not going to get any better or trail worthy with rookie welder projects tacted all over the place
Old 03-03-2005, 10:27 PM   #25
84yota4x4
Member # 43751
Hey man... looks good... nice truck to...... i dont know about the green though.
I dont understand why people dont like things that are different, maybe they are affraid that it might actually look good and it wasnt there idea.
84yota4x4 is offline   Reply With Quote
Forum Jump
