#1 |
Member # 38212
80 chevy 1 ton pathfinder van ???
I found an 80 Chevy 1 ton van Pathfinder coversion aguy it parting out and was wondering what axels it would have.I assume a d60/14 bolt or did Pathfinder use something different that Gm stuff? It's a a good distance away so I don't want to take a long drive for nothing.
#2 | |
there's a possibility, but i'd guess it would be a driver drop low pinion dana 44.
| Sponsored Links |
#3 |
Member # 38212
The guy said the hubs not the lockouts, were 3 1/2"-4" in diameter.I had thought d44 originally but after hearing that I figured d60.
#4 |
Member # 28043
I have had several of the pathfinder vans. All of them have had the drivers drop low pinion d-60hd. They must have gotten a hell of a deal on divorced np205's w/ driver drop and the 60hd's. The rears have been 35 spline d-70's w/ the factory limited-slip. The most common gears are 4.10. All the one's I've had come with 35" tires and about 8-10" of lift.
good luck on your find. |
#5 |
Member # 38212
He said it was a married case.I may call him back and see what side the pumpkin is on.
#6 |
Member # 38212
It's a married case behind a th400 auto.Is it going to be a 205 or something else.
#7 |
Member # 38212
Apparently it's a large hub furd d44 and a furd 205.Dumb conversion company,I thought I had something.
| Thread Tools | |
| Display Modes | |
