Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Jeep - Hardcore Tech
Old 03-22-2005, 01:59 PM   #1
LAWNMAN323
Member # 23741
Send a message via AIM to LAWNMAN323
Arrow Scout T19 to Buick 231, what bellhousing to use?
I've got a close ratio 4:1 first T19 out of a Scout that has studs off the front of it. I was told that the Jeep T98 had the same bell bolt pattern, and was pumped when I got a bellhousing for $40 to mate it to a buick V6. However, the bell to trans patters were different when I fitted them together. Now I'm stumped and pissed.
What's the cheapest way to mate the T19 to the Buick? My whole plan was to avoid buying adapters. And I know I have to have the input shaft machined. I think Mo has some experience with T19s, from my search. Going into a '3A if it matters.
Thanks for any help.
Edit: I searched some more, AA makes an adapter, but someone also re-drilled the bellhousing to fit the tranny. Are there any problems with the strength of the new holes because the aluminum is not as thick as in the original locations?
'89 MJ, 60/14, 39's
CJ3A - in many pieces, awaiting parts.
LAWNMAN323 is offline   Reply With Quote
Forum Jump
