Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Truck and 4Runner
Old 03-23-2005, 12:11 PM   #1
3/4tonYJ
back from otherside
3/4tonYJ's Avatar
Member # 1375
budget A/C to on-board air started, ? about mounting tank and hose hookups
i bought this 3 gallon air tank with guages, 70psi on, 90psi off switch, drain,regulator etc.... i'm planning on mounted it the under or in the bed, (any ideas?)
also got this filter/seperator and adjustable oiler, i'm thinking about mounting the oiler under the hood and the seperator on the tank.......
i'm wondering how everyone "spliced" into the A/c lines, i'm thinking about using unions, but bet there's alot better ideas, anyone?
ideas for intake filter?
pics of your mounting setups would be help.....
thanks
www.52 Ford F-3.com
3/4tonYJ is offline   Reply With Quote
Old 03-23-2005, 12:21 PM   #2
fourwd1
Member # 4842
That tank looks nice, how much/where/part # ?
The separator could be mounted under the hood or at the tank, but the oiler pretty much has to be under the hood to be at the pumps intake.
Do a SEARCH and you'll find plenty of threads with ideas on this.
'80's Toy P/U-Buick 231 V6, Holley 4 bbl, Weiand intake, Downey headers, custom TH350 L/U w/700R4 1st gear, dual tanks, dual batts, ...
84 4Runner SR5-ARBed 5.29's F&R, 4.7 t-case, AP x-over, Chevy's, 2" drv trn lift, 36" TSLs, 30 spl Longs
[URL=http://www.marylandcreepers.com]Maryland Creepers[/URL] [URL=http://www.keystonekrawlers.com]Keystone Krawlers[/URL]
fourwd1 is offline   Reply With Quote
Old 03-23-2005, 12:25 PM   #3
3/4tonYJ
back from otherside
3/4tonYJ's Avatar
Member # 1375
got the tank off ebay from this guy...... http://stores.ebay.com/The-Pump-Plac...eNameZl2QQtZkm
been searching, there is tons of info........still reading through it
www.52 Ford F-3.com
Old 03-23-2005, 03:38 PM   #4
Kyron
Arizona Trail Riders
Kyron's Avatar
Member # 1418
I used an old water fire bottle as an air tank, I mounted it with large hose clamps under the back of my 4runner
To splice the lines I cut them and crimped hydro fittings on the ends........ find a shop that makes hydro lines and your set
You need a Thneed
84 Toyota CJ2a
Get Propane
Kyron is offline   Reply With Quote
Forum Jump
