#1 |
Member # 17316
30 and 35 spline Maxi Drive Sals/D60 lockers
I just got off the phone to Mal Story from Maxi-Drive.
Some of you may know that I have bought a pair of 30 spline longfields (and other bits) from Keith (rovertracks) and am going to build a hybrid Salisbury/toy (CV) axle with rover hubs/spindles. I spoke to Mal about building 30 (or 35) spline (Dana 60 spline) lockers for my salisbury (since I already have an MD locker, I like the quality and simplicity, and the hytuff axles are about the strongest available). Mal said they have already built a couple of 30 spline salisbury lockers for US customers and that it wouldn't be too difficult. He said that a 35 spline Salisbury locker would also be possible but it would be more $$$ since it would mean a completely new locking dog, rather than just a modification of the existing one. If more people want these axles/lockers, it will only bring the cost down. The lockers are simpler and more reliable than an ARB and the HYTUFF (AMS6418) axles are second only to 300m (and HYTUFF axles are supplied instead of 300m axles by sandy cone (CTM) when he can't get 300m)). Mal doesn't do the internet thing, so you can't email him, but his contact details are below... He said they generally make the lockers in a one year (or more) batch at a time, so if you are serious (but not in a hurry) that is OK. 4 Ryecroft St, Carrara, Qld, Australia, 4211 Phone: 0061 7 5530 3934 Fax: 0061 7 5530 3932 http://www.4wdworld.com.au/products/maxidrive/ I should add that I have no relationship with Mal, other than I give him $$$ and he gives me shiny metal bits. If a lot of people are interested, this will be a very cheap axle option that is stronger than a stock 30 spline D60 and maybe as strong as astock 35 spline D60. My build will cost me an estimated... (all USD) $250 - 2x 30 spline longfields $1400 - 30 spline locker and 2x30 spline hytuf axles (toy 30 spl one end, dana 30 spl the other) - This price will come down if more people order... $150 - Salisbury centre (SIII 109, 4.7 ratio). $30 - 2x 30 spl D60 side gears (MD locker uses stock side gears Fitting of locker and toy CV's - free (for me). Whichever way you look at it that is a cheap front end for the strength. And a rear maxi-drive 30 spline would be even less.
Cheers, Ben. Last edited by ISUZUROVER; 05-02-2005 at 04:47 PM. |
#2 |
Member # 20109
So, Ben, are you saying you putting together a Salisbury front axle?? Where is the axle housing coming from or how are you building it. I ASSUME the $1400 includes 30 spline flanges??
1991 D90 ex-MOD |
| Sponsored Links |
#3 | |
Member # 17316
Cheers, Ben. |
#4 |
Member # 20109
Why not pick up some coiler outers at least and get disc brakes if you are going to all that trouble. Must be easy to find.
1991 D90 ex-MOD |
#5 |
Member # 7755
Ah, why bother with custom maxi-drive locker (I see the point for the axles etc) when a D60 ARB is available off the shelf.
:evil: |
#6 | |
Member # 17316
Cheers, Ben. |
#7 | |
Member # 17316
(1) They are the simplest, most reliable and most well built locker (plenty of ARB o-ring failures - never happens with MD). (2) 30 spline HYTUF axles - IMHO basically as good as 300m. (3) If enough people buy them they will become off-the-shelf. (4) In the unlikely event you ever need parts and can't get them from MD, all the componnts are evtremely simple and would able to be made by just about any machine shop.
Cheers, Ben. |
#8 | |
Member # 20394
BUCK Wild Racing Team 911 Thank you all for your support and friendship. Rover Tracks www.rovertracks.com PSC www.racesteering.com DJ Safety www.djsafety.com West Coast Rovers www.westcoastrovers.com Spidertrax www.spidertrax.com JE Reel www.reeldriveline.com |
#9 | |
Member # 13876
Grayson |
#10 |
Buckon37s How much were the 9 inchers under your 90? Do they have rover outers?
Ben, The axle project sounds very cool. keep us posted.
I am what I am - Popeye |
#11 |
Member # 14136
Buckon37s,
The reason for this is the difficulty getting D60's in Aus.
John |
#12 | |
Member # 17316
However, the recent testing seems to show that my setup will be way stronger than a stock 30 spline D60 and also stronger than a stock 35 spline as well.
Cheers, Ben. |
#13 |
Member # 44677
If I already have a couple front salisbury axles (actually have three, but one is promised to someone), what pieces do I need from Mal to put 35 spline lockers up front?
#14 |
Member # 20394
Okay,
Makes sense. Didn't realize the excessive price of the 60's. I still don't believe for a second that these are stronger than a 35 spline 60, but only time will tell I guess. "Buckon37s How much were the 9 inchers under your 90? Do they have rover outers?" I think the total cost was around $6500 for both. Rear has rover outers. Front has D60 outers with a rover bolt pattern.
#15 | |
Member # 17316
If you want to go 35 spline it is a bit more work than 30 spline (but still possible). But what CV's will you run? If they are AEU2522's then it would be best to replace them with longfield 30 spline axles and run 30 spline. If they have 101 CV's then I think Mal has already made lockers in the 1.45" (ish) 21 spline of the 101's. Assuming you want to fit 30 spline longfields and 30 (or 35) spline lockers, the bits you need are: A pair of 30 spline longfields Bored (slightly) rover spindles (any machine shop) 2xdrive flanges and 2x brass bushes (rovertracks or macnamara) Then comes the MD bits 2 inner axles with 30 spline toy outer splines and 30 or 35 spline Dana inner splines locking dog locking actuator new hemisphere half (or new sleeve for the locking dog to engage with for OZ market maxi-drive lockers) lines and switches All of the above is part of the normal Salisbury locker kit, just that the inner axles and the locking dog are different from the normal 24 spline setup. If you want to go to 35 splines you will also need to swap one of the carrier bearings to one with a larger i.d. to allow for a larger diameter locking dog. This option would cost a bit more - as it is further from the current locker. But the 30 spline HYTUFF axles should be easily as strong as stock dana 35 spline axles.
Cheers, Ben. |
#16 | |
Member # 17316
And sure it isn't comparing apples to apples, but this setup is a hell of a lot cheaper than buying CTM's and alloy 35 spline shafts to fit in a D60.
Cheers, Ben. Last edited by ISUZUROVER; 05-03-2005 at 09:00 AM. |
#17 |
Member # 20396
Sweet.
Could I get some info on the 30 spline shafts you have for the rear? I want to upgrade my rear Series 3 109 salisbury axle (already has a detroit). What about the outer flanges? How much $$ we looking at here? |
#18 | |
I make guns
Member # 14561
Both have the tech you need. www.rovertracks.com www.greatbasinrovers.com To go 30 spline inner and outer you will need a new locker (or can you replace the sides of a detroit to get new splines?). I believe that both Kieths and Bills rear axles can be had in a one piece design, no need for a flange then. |
#19 | |
Member # 7962
Sam
Land Rover SIIa, 302W, NP435, NP205, MOG404s, 42in Swamper TSLs, 112in WB "An expert is somebody who learns more and more about less and less until one day they know absolutely everything about nothing." Outerlimits4x4.com - home of aussie rock crawling. |
#20 | |
Member # 20394
#21 | |
Member # 17316
The prices I am talking about for MD includes the locker. Add an ARB locker to that is another $700ish, then add the base price for a stock D60 front $500-1000. That brings you to at least $2000US I estimate that my front axle will set me back about the same or less for everything ($1350US (axles and locker), $100US Sals centre, $450US longfields). I agree with you that with the D60 with 35 spline alloy shafts you would have a slightly stronger setup (with CTM's a lot stronger), but the way I see it I am getting equivalent strength for the same or less $$$, and at the same time keeping rover hubs, brakes and steering. In the US though I agree with you that the D60 would probably be a better option, unless you can get hold of some SIII salisburies very cheaply or you want to keep the rover hubs.
Cheers, Ben. |
#22 | |
Member # 17316
Cheers, Ben. |
#23 | |
Member # 7962
I think your strength will be similar to a built toy 8in axle and nothing like a 35 spline D60. This axle will still be alot stronger than a stock rover axle though. Sam
#24 | |
Member # 17316
And I am sure that MD HYTUFF 30 spline inners will have equivalent strength and fatigue properties to longfield 30 spline 4340 inners. The toyota guys are breaking ring and pinions and hubs now but not longfields. The sals ring should be much stronger (about the same strength as a D60), and the rover hubs seem to be stronger than toyota.
Cheers, Ben. Last edited by ISUZUROVER; 05-04-2005 at 07:53 AM. |
#25 | |
Larry [url]www.columbiaoverland.com[/url] |
| Thread Tools | |
| Display Modes | |
